Testing fridge/sink double relay keyed ignition
AZ_CreamPuff
AZ_CreamPuff is offline
PostPosted: Thu Oct 12, 2017 6:23 pm    Post subject: Testing fridge/sink double relay keyed ignition Reply with quote
I don't think I am getting power to the fridge or signaling the battery isolator to "turn off" when the engine is running. I tested the terminal on the relay using a multimeter and 0's across the board when the van is off and on. Bad relay or poor process?
Timwhy
Timwhy is offline
PostPosted: Fri Oct 13, 2017 2:49 am    Post subject: Re: Testing fridge/sink double relay keyed ignition Reply with quote
Did you test the fuses in the little black box behind the drivers seat too?
'15 Audi A3 Quattro
'09 VW Tiguan (dead)
'87 VW Westy
'91 Tin Top
'90 Cabby
MarkWard
MarkWard is offline
PostPosted: Fri Oct 13, 2017 10:08 am    Post subject: Re: Testing fridge/sink double relay keyed ignition Reply with quote
Year of van and you mention isolator. Are you referring to the stock relay under the driver's seat or something that has been added on?
AZ_CreamPuff
PostPosted: Mon Oct 16, 2017 7:27 pm    Post subject: Re: Testing fridge/sink double relay keyed ignition Reply with quote
It's the stock relay. I have the gowesty auxiliary setup. For now. Needs to keyed ignition pin, which I think is #30 to essentially turn the isolator off and allow both batteries to charge. Fuses are good.
Vanagon Nut
Vanagon Nut is offline
PostPosted: Tue Oct 17, 2017 9:14 am    Post subject: Re: Testing fridge/sink double relay keyed ignition Reply with quote
If youre referring to 30 on the stock "fridge" relay, that 30 is connected to the 30 buss (circuit) of the van. On a vw, 30 is constant positive; its not switched. And, turning key to ignition on will not open or close that relay. That relay is controlled by power from alternator D+ coming through the blue wire. When engine is running, that relay closes allowing positive to flow inside relay from relay 30 to relay 87 then from 87 out to fuse then to fridge.
With engine off, your meter set to proper dc range, black probe to clean ground, red probe on fridge relay 30, you should see battery voltage. Moving only the red probe, to fridge relay 87, you should see no voltage. Engine running, you should then see battery voltage (or slightly higher) at relay 87.
If the battery isolator is not connecting the batteries when engine is running, assuming your fridge positive wire connects to the aux battery, when driving with fridge in, that battery will get discharged; it wont be getting lower from the alternator.
1981 Westy DIY 15º ABA
(VW Gas I4)
1988 Westy DIY 50º ABA
VE7TBN
crazyvwvanman
crazyvwvanman is offline
PostPosted: Tue Oct 17, 2017 9:27 am    Post subject: Re: Testing fridge/sink double relay keyed ignition Reply with quote
Not true in this case. For the under seat fridge relay VW reversed the main power terminals of the relay. Look at the Westy wiring diagram. Power in on 87 and out to the fridge on 30. They did this so a dual 87 pin relay could act as a junction (splitter) and a relay.
Mark
Vanagon Nut wrote:
..If youre referring to 30 on the stock "fridge" relay, that 30 is connected to the 30 buss (circuit) of the van. On a vw, 30 is constant positive; its not switched. And, turning key to ignition on will not open or close that relay. That relay is controlled by power from alternator D+ coming through the blue wire. When engine is running, that relay closes allowing positive to flow inside relay from relay 30 to relay 87 then from 87 out to fuse then to fridge...
Vanagon Nut
PostPosted: Tue Oct 17, 2017 1:51 pm    Post subject: Re: Testing fridge/sink double relay keyed ignition Reply with quote
Dag nab it. First time I don't consult my Bentley..... Wink Thanks Mark.
My apologies to the OP.
Regarding the OP's "fridge/sink" in subject the other 87 pin on that relay should show "always on" (constant) power and supplies that fused power to sink pump, battery/water level indicator, and fridge fan.
Neil.
Mark
(VW Gas I4)
VE7TBN
AZ_CreamPuff
PostPosted: Wed Oct 18, 2017 10:27 am    Post subject: Re: Testing fridge/sink double relay keyed ignition Reply with quote
Thanks guys. Just got back from my trip. Going to head to the FLAPS to procure a relay if they have it. Luckily when I wired up the auction battery I made everything reversible. Made me nervous running everything on the start battery but that was the only hiccup all trip. Can't complain
