parker007 Samba Member
Joined: December 21, 2011 Posts: 132 Location: california
Posted: Mon Oct 30, 2017 7:16 am Post subject: 55 W emblem |
I just purchased used 4 tab w emblem from samba member and it is about 6mm to large. my hood is 2 bolt and has 4 tab slots, so was there 2 sizes of hood emblems, if so what one do i search for? any info appreciated. |
Posted: Mon Oct 30, 2017 7:20 pm Post subject: Re: 55 W emblem |
does anybody have the outside measurement for 53 to 55 hood emblem? |
motofly196 Samba Member
Joined: June 01, 2008 Posts: 1467 Location: Eastern WA
Posted: Mon Oct 30, 2017 7:41 pm Post subject: Re: 55 W emblem |
Do you have a pic of the emblem and hood? Under side pics of the hood will help. |
Posted: Tue Oct 31, 2017 3:40 pm Post subject: Re: 55 W emblem |
maybe this help
Posted: Tue Oct 31, 2017 4:07 pm Post subject: Re: 55 W emblem |
Well, you've got an early 4 tab hood for certain. The emblem looks correct too. There is a shadow on the hood from the previous emblem, is that not lining up? Sometimes you have to bend the tabs slightly to get them to line up again. Just be careful, they break off easily. |
Posted: Tue Oct 31, 2017 4:27 pm Post subject: Re: 55 W emblem |
emblem is 5mm bigger than slots |
Posted: Tue Oct 31, 2017 8:40 pm Post subject: Re: 55 W emblem |
Is the emblem an aftermarket or original? That could be part of the problem. I've never had an original not fit. |
Jonnyla Samba Member
Joined: November 11, 2013 Posts: 101 Location: Mesa, AZ
Posted: Tue Oct 31, 2017 9:03 pm Post subject: Re: 55 W emblem |
Asking cause I don't know... is that a 55 hood or a later hood? I thought '55 hoods had the fifth bolt hole for the hood prop and didn't share a hinge bolt. Or am I thinking of a 54 hood? If this was the case would that make a difference in the fit of the emblem? Meaning was as '56 hood emblem different? _________________ '55 3 fold sedan, stock with lower stance (project)
'57 sedan, future old speed outlaw style (project) |
Posted: Tue Oct 31, 2017 9:12 pm Post subject: Re: 55 W emblem |
i just buy emblem but think original, does anybody have dimensions of original emblem on 55 or earlier ? i have zwitter siting next to oval and it same hood dimensions but no w emblem also. |
Posted: Tue Oct 31, 2017 9:15 pm Post subject: Re: 55 W emblem |
motofly196 wrote: |
you noticed where old dust is from w emblem, im sure past owner remove before i get so i know the right emblem will fit pre 55 just not one i have. |
Posted: Tue Oct 31, 2017 9:52 pm Post subject: Re: 55 W emblem |
Jonnyla wrote: |
Asking cause I don't know... is that a 55 hood or a later hood? I thought '55 hoods had the fifth bolt hole for the hood prop and didn't share a hinge bolt. Or am I thinking of a 54 hood? If this was the case would that make a difference in the fit of the emblem? Meaning was as '56 hood emblem different? |
That's a 56-57 hood. As far as I know, there's no difference between the emblems.You are right, 54 and early 55 hoods have 3 holes on the drivers side, 3rd hole is for the hood prop. 2 bolt hinges. |
Posted: Wed Nov 01, 2017 6:24 am Post subject: Re: 55 W emblem |
I have a 54 hood with original 4 tab. I also have an after market Four tab emblem. I'll compare them for you later today to see if there is any difference as far a size. _________________ '55 3 fold sedan, stock with lower stance (project)
janerick3 Samba Member
Posted: Wed Nov 01, 2017 7:48 am Post subject: Re: 55 W emblem |
Is this a mid '61-'62 emblem? I think the originals were two-piece construction and you are missing the bottom piece with the three pins. _________________ Thanks,
Jan K. |
Posted: Wed Nov 01, 2017 8:08 am Post subject: Re: 55 W emblem |
thats what im thinking, emblem is right at 80mm hood slots about 75mm |
Posted: Mon Nov 13, 2017 3:59 pm Post subject: Re: 55 W emblem |
yes exactly so what emblem is 75mm? |
