SolarPoweredPickles Samba Member
Joined: May 13, 2009 Posts: 1264 Location: California
Posted: Thu Nov 09, 2017 2:49 pm Post subject: Engine won't start after hiccup |
Hey peeps,
My engine isn't starting.
Recently I dropped a washer down one of my dual carbs, I had to pull the engine, and the head to get the washer out. It put a couple dings on the inside of the head, not damaging the valve, or cylinder or piston/ rings look fine. I reassembled everything, did a valve job, put everything back to the way it was.
I was low on fuel and it wasn't starting so I added another 1.5 gallons, I have close to 3 gallons in the tank, plenty to start a dry system, I would assume?
I'm curious what it may be, or things to check. I had done a full valve job a few months ago. So this time around I only did a valve job on the side I pulled apart, driver side. When removing a head, does that somehow throw things off on both sides? The #3 is where I dropped the washer, the spark plug tip was pushed it, I just re-gapped it and cleaned it off and reused it, it didn't look bad.
I did get a sputter to where it almost started before I added more fuel, so I would scratch the possibility of getting spark. I triple checked my wires, and dist. wires, fuel lines aren't crossed.
What to check? What I possibly damaged? It just keeps turning over, it sounds like a healthy turn over, if that means anything.
Thanks all. |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 25979 Location: Olympia Wash Rinse & Repeat
Posted: Thu Nov 09, 2017 3:23 pm Post subject: Re: Engine won't start after hiccup |
Check for fuel and spark. _________________ In Stereo, Where Available! |
Posted: Thu Nov 09, 2017 4:14 pm Post subject: Re: Engine won't start after hiccup |
Like pop off a fuel hose and see if it's pumping? Fuel gallons I know I have, but check to see if it's pumping? It doesn't smell flooded, and it probably should, so maybe its fuel issue. |
Posted: Thu Nov 09, 2017 4:46 pm Post subject: Re: Engine won't start after hiccup |
If you have a small mirror, you can use it to peer down the carb throat to see if the accelerator nozzle sprays fuel when the throttle position arm is pulled to the rear. _________________ In Stereo, Where Available! |
Who.Me? Samba Member
Joined: July 14, 2014 Posts: 2538 Location: UK (South)
Posted: Fri Nov 10, 2017 12:21 am Post subject: Re: Engine won't start after hiccup |
Did you take the distributor off? If so, did you rotate the engine at all while it was out? If so, could you have put it back with the engine half a cycle on from where you took it out? (180ยบ out?)
Alternatively; it does take a lot of cranking to fill an empty carb bowl. You could fill it carefully with a funnel on some fuel hose to prime it. Once the engine fires, the pump pumps a lot faster and will refill the bowl before it drains. _________________ Andy
Looking for info on my truck's history. Are you from Campbell California or nearby. Do you recognise it? ... http://www.thesamba.com/vw/forum/viewtopic.php?t=636786 |
xcoldgrimjimx Samba Member
Posted: Fri Nov 10, 2017 3:01 am Post subject: Re: Engine won't start after hiccup |
^^^^ THIS ya dude it sounds like a timing issue  _________________ ya it's rusty...but it's MINE!!!!! |
gwal Samba Member
Joined: January 20, 2008 Posts: 25 Location: cambridge, england
Posted: Fri Nov 10, 2017 5:19 am Post subject: Re: Engine won't start after hiccup |
Have you left the fuel line clamp on the bottom of the tank? |
Posted: Fri Nov 10, 2017 7:49 pm Post subject: Re: Engine won't start after hiccup |
Fuel line clamp? Hmmm, not sure what that is.
I never took the distributor out, and my dist. cables are all correct. I didn't touch that much when I pulled things apart. By now I would normally have poured a big of gas down the carbs to get things going. I havent had a lot of time this week, tomorrow I'll put the air filters off and see if gas is shooting out of the carbs. I hope it's something goofy I missed. It all looks good. What the heck... |
D-train Samba Member
Posted: Sat Nov 11, 2017 12:00 am Post subject: Re: Engine won't start after hiccup |
-rotor button on?
-wires from coil to distributor correct?
-reserve tap not half on? (If u have one)
-condenser ok?
-carbon bush in the middle of the cap still there an not broken off?
-fuel pump push rod still in it? (If you took the pump off) _________________ shiny paint doesnt make it worth any more |
Posted: Sat Nov 11, 2017 11:26 am Post subject: Re: Engine won't start after hiccup |
Checked a couple things this morning. Made sure I didn't blow out the little distributor cap buttom, that's ok. Fuel pump never came off, only the fuel lines. Aside from replacing one side of fuel hose from the "T" to the carb, all was put back the same.
I popped off the air cleaners and sure enough, pulling on the throttle no fuel is spraying into the carbs. Why, I am quite unsure.... sigh. But I have the issue! Now to solve it. |
Posted: Sat Nov 11, 2017 11:41 am Post subject: Re: Engine won't start after hiccup |
Good to hear! Lots easier if you can narrow it down like you have. _________________ In Stereo, Where Available! |
Posted: Sat Nov 11, 2017 12:03 pm Post subject: Re: Engine won't start after hiccup |
What motor and what pump?
Have u got the lines on the right pump fitting? In an out to carbs? _________________ shiny paint doesnt make it worth any more |
Posted: Sun Nov 12, 2017 11:43 am Post subject: Re: Engine won't start after hiccup |
It's a 1776, I can't remember which pump this is. The line from the fuel tank goes to the fuel filter, then to the top port on this fuel pump. Each carb is connected with a "T" in the center, and that "T" goes to the bottom port on the fuel pump. I thought this is how it was before but I may have accidentally crossed something?
heimlich  VWNOS.com
Joined: November 20, 2016 Posts: 7502 Location: Houston, Texas
Posted: Sun Nov 12, 2017 1:13 pm Post subject: Re: Engine won't start after hiccup |
Check that the fuel pump is pumping when you are turning over the engine. _________________ www.vwnos.com [email protected]
Posted: Sun Nov 12, 2017 1:50 pm Post subject: Re: Engine won't start after hiccup |
kawfee wrote: |
Check that the fuel pump is pumping when you are turning over the engine. |
Take off the send/out line and put it in a jar or something? Not sure how to check this. |
Posted: Sun Nov 12, 2017 2:51 pm Post subject: Re: Engine won't start after hiccup |
electronictofu wrote: |
kawfee wrote: |
Just turn the motor by hand and it should pump out, usually has an arrow on some indicating the outlet. _________________ shiny paint doesnt make it worth any more |
Posted: Sun Nov 12, 2017 5:38 pm Post subject: Re: Engine won't start after hiccup |
Fuel pump is pumping! I cranked it by hand and the send/out is the one on the bottom, which is going to the "T" then the carbs. I poured 1/2 of a spray paint cap full of gas down one of the carbs and it started up for a second but died. Im sure it all needs to be tuned but getting it started TO TUNE is proving to be a challenge. I've been cranking it over a lot. |
Posted: Sun Nov 12, 2017 5:47 pm Post subject: Re: Engine won't start after hiccup |
Update. A little more juice straight down the carb and its running like a top again! Thanks for the help guys, I guess it just needed a lot more fuel. Time to sync and tune and drive again. |
EverettB  Administrator
Joined: April 11, 2000 Posts: 71539 Location: Phoenix 602
kawfee wrote: |
Yes, this is what I have done.
Or I have a helper watch while I crank.
I usually pull the coil wire so there's no electrics to spark anything, even though this is probably unlikely. _________________ How to Post Photos
