bustedtype2 Samba Member
Joined: May 07, 2005 Posts: 418 Location: The arm pit of california
Posted: Thu Nov 23, 2017 4:09 pm Post subject: 1973 Bad smell after driving! Help |
I have a 1973 bay window bus that I just got done doing some normal maintenance.
New front pads
Repacked bearings
Bled and adjusted brakes
WD40 back brake mechanism “Not shoes”
Fixed exhaust leak with new gasket and high heat silicone between exhaust and header.
Added small amount of gear fluid to trans until it came out the side hole.
Took for a test drive and now it smells like burnt rubber. The farther I drive the worst the smell gets.
Stops fine
Brakes do not get hot, clutch dose not slip or chatter. No smoke or fire. It’s been about a week now. It dose not smell like burnt oil. What can this be??? Need help!
Thank you _________________ Gas, Grass or Ass ? No one rides to the show for free!! |
Posted: Thu Nov 23, 2017 4:41 pm Post subject: Re: 1973 Bad smell after driving! Help |
| You probably are smoking the silicone. May not have been fully set and can't handle exhaust temps no matter what. Oil and grease from you hands will get on to the exhaust pipes when you touch them and take a while to burn off as well. |
Double post, delete
SGKent  Samba Member
Joined: October 30, 2007 Posts: 42993 Location: at the beach in Northern Wokistan
Posted: Thu Nov 23, 2017 5:22 pm Post subject: Re: 1973 Bad smell after driving! Help |
put your hands palm open near the hubcaps but DO NOT TOUCH THEM to see if there is excessive heat coming off the brakes. You can instead use an R gun if you have one to check temps.
Do the same for the fronts _________________
Canned Water - the new California approved parts cleaner (except in a drought in which case rub it with sand).
George Carlin:
Skills@EuroCarsPlus:
"never time to do it right but always time to do it twice"
1971 deluxe (sold)
1977 deluxe |
Posted: Thu Nov 23, 2017 5:36 pm Post subject: Re: 1973 Bad smell after driving! Help |
I checked the brakes and all still cool. Would high heat silicone smell like that? I have used it before and never had this problem. Is it possible for the gear oil I put in make it to the clutch and that’s what’s burning? Don’t think I put that much in but you never no. _________________ Gas, Grass or Ass ? No one rides to the show for free!! |
pioneer1 Samba Member
Joined: February 11, 2008 Posts: 2074 Location: Ontario Canada
Posted: Thu Nov 23, 2017 6:21 pm Post subject: Re: 1973 Bad smell after driving! Help |
Did you paint or introduce any cleaners to the insides of the heat exchagers _________________ "Always waiting for tomorrow ruined everything"
'85 Porsche 911 Targa
'76 Westfalia project |
Posted: Thu Nov 23, 2017 8:53 pm Post subject: Re: 1973 Bad smell after driving! Help |
I may have got some silicone on them. I did paint the exhaust with high heat BBQ paint. But I have done that before without a smell. _________________ Gas, Grass or Ass ? No one rides to the show for free!! |
Joined: January 01, 2007 Posts: 17995 Location: sticksville, ct.
Posted: Thu Nov 23, 2017 8:56 pm Post subject: Re: 1973 Bad smell after driving! Help |
| bustedtype2 wrote: |
Thank you |
hold your bus up to the computer. I can't smell it from here _________________
| gprudenciop wrote: |
| Jake Raby wrote: |
| Thanks for the correction. I used to be a nice guy, then I ruined it by exposing myself to the public. |
| Brian wrote: |
| Also the fact that people are agreeing with Skills, it's a turn of events for samba history |
Posted: Thu Nov 23, 2017 9:05 pm Post subject: Re: 1973 Bad smell after driving! Help |
| skills@eurocarsplus wrote: |
Thank you |
hold your bus up to the computer. I can't smell it from here |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 23574 Location: Oklahoma City
Posted: Thu Nov 23, 2017 10:27 pm Post subject: Re: 1973 Bad smell after driving! Help |
| I may have got some silicone on them. I did paint the exhaust with high heat BBQ paint. But I have done that before without a smell. |
Question....what are you using WD-40 for? There ks actually nothing anywhere in the brakr syztem it has any use for....and it WILL attack EPDM rubber....which is what all brake seals, wheel cylinder boots and rubber parts are made of.
WD-40 is a solvant and water dispersant but has virtually no use as a lubricant long term and especially not in hot conditions.
But ..nasty as it smells when burning off....its not that nasty and should be gone quickly. I don think that is your problem. If you have a leaky wheel cylinder boot.....brakr fluid smells nasty when burning off.
Ray |
Posted: Fri Nov 24, 2017 12:45 am Post subject: Re: 1973 Bad smell after driving! Help |
Thank you Ray
I will check the wheel cylinders tomorrow. The emergency brake lever was rusty so I hit it with WD40 thanks for the instruction much appreciated. Question if a clutch was burning and smelling would it still do it’s job perfectly ? _________________ Gas, Grass or Ass ? No one rides to the show for free!! |
Posted: Fri Nov 24, 2017 3:13 am Post subject: Re: 1973 Bad smell after driving! Help |
| A clutch isn't going to get hot unless it is slipping either because you are using it to get going or because there is something wrong with the clutch adjustment or there is some kind of failure going on. |
Abscate Samba Member
Joined: October 05, 2014 Posts: 24506 Location: NYC/Upstate/ROW
Posted: Fri Nov 24, 2017 5:17 am Post subject: Re: 1973 Bad smell after driving! Help |
Silicone burn off.
I’ve found computers in the new made on the new place quite smell, but the old factory ones smell just fine. _________________ 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🍊 🍊 🍊 |
