barefootjohnny Samba Member
Posted: Thu Jan 18, 2018 12:16 am Post subject: oil cooler install |
I watched a youtube video where a man ran hoses from original oil cooler to an oil filter (attached under the bus, two hoses) from the filter he ran two hoses to an additional under bus oil cooler.
Is this correct? one hose takes oil to filter and then to oil cooler, 2nd hose takes oil from cooler back to the original cooler up near the motor.
Is this the best way to do this? What part do I need to attach to original cooler so that i can run to a separate under bus cooler.
Want to update cooler system without removing engine or having to remove old cooler. _________________ 1977 VW Baywindow |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 13628 Location: West Coast, USA
Posted: Thu Jan 18, 2018 1:01 am Post subject: Re: oil cooler install |
Was this on a Volkswagen of some kind??
Kidding aside, we would need to know if it was a type 1 or type 4 engine. They have slightly different cooling systems.
The Type 4 engine has never had major problems with oil cooling, so not many parts exist on the aftermarket today to outfit them.
The Type 1 engine has no problems with oil cooling, but it was more popular back in the day so a lot of garbage aftermarket parts exist these days that will create a problem with oil cooling to sell you an oil cooler.
Robbie
PS, what part of Kansas? _________________ One-on-one tech help for your vintage Volkswagen:
www.airschooled.com
Road trip reports and tech blog:
https://www.patreon.com/airschooled |
Posted: Thu Jan 18, 2018 4:02 am Post subject: Re: oil cooler install |
Your engine came new from the factory with an oil filtration system and oil cooling system that worked very well. Make sure you have all of the parts for the system that you have and that they work as the factory intended. Read up on the effects of oil viscosity on the oil temperatures. The VW oil cooling system is designed to maintain the oil at a certain viscosity, if the oil is thicker than the engine needs the engine will just let the oil get hotter and hotter until the oil thins to were it wants it.
Forget about all the fancy doodads you can buy for your engine, most offer little or NOTHING over the stock setup. |
Posted: Thu Jan 18, 2018 9:50 am Post subject: Re: oil cooler install |
Thank you, I will be removing the thought of a new oil cooler. After reading your replies, well it makes sense not to mess with it.
Robbie, I am in Topeka.
Once again Thank you, both. _________________ 1977 VW Baywindow |
Spike0180 Samba Member
Joined: June 06, 2015 Posts: 2270 Location: Detroit, Michigan
Posted: Thu Jan 18, 2018 9:56 am Post subject: Re: oil cooler install |
| Wildthings wrote: |
In oil trainer is far from an current day oil filter. Maybe if they have oil filters we wouldn't have so many completely trashed engine cases.
As far as cooling, I agree for a stock engine or mild engine. But if you are putting a 2000cc+ engine in, I understand an external oil cooler. _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Current State: Projects never truly end...
Other cars: 2003 F150, 2003 Jetta GLI vr6-6sp
Sambastic: adj; the quality of being nit picky, elitist, expecting everyone to do things the way they believe is best with no regard to situation, "sambastic" |
Posted: Thu Jan 18, 2018 10:10 am Post subject: Re: oil cooler install |
| Spike0180 wrote: |
As far as cooling, I agree for a stock engine or mild engine. But if you are putting a 2000cc+ engine in, I understand an external oil cooler. |
The OP shows a '77 in his signature line, which would mean a Type 4 engine with stock full flow oil filter and a sufficiently sized cooler for any stock sized engine. He just has the new owner jitters that can make one expend a lot of money and end up with a rig that is less dependable than if the work had not been done. |
Posted: Thu Jan 18, 2018 11:42 am Post subject: Re: oil cooler install |
| Wildthings wrote: |
| Spike0180 wrote: |
Ah, my bad. I went off on the type 1 rant.
I agree the type 4 cooler and filter is sufficient for most any build you would want to do. _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Posted: Thu Jan 18, 2018 3:22 pm Post subject: Re: oil cooler install |
new owner jitters indeed. Thanks everyone for saving me some money _________________ 1977 VW Baywindow |
