Do early transmissions have different gaiters / rubber boots?
vwjim
vwjim is offline
PostPosted: Thu Mar 22, 2018 2:37 pm    Post subject: Do early transmissions have different gaiters / rubber boots? Reply with quote
I'm working on a Split bus, with a SA conversion, so its got a Bug transmission.
When changing the driveshaft gaiters, I found one side the flange diameter was approx' 88mm which is normal and fits the gaiter properly. But the other side the flange is approx' 84mm so the gaiter is baggy on that side.
Any ideas? I've never seen flanges anything other than the larger size.
Thanks
splitjunkie
splitjunkie is offline
PostPosted: Fri Mar 23, 2018 8:18 am    Post subject: Re: Do early transmissions have different gaiters / rubber boots? Reply with quote
Split case transmissions had the smaller diameter. I'm not sure if that was the case for all of them or when the change to the larger ones took place. Progressive Refinements should document that change.
https://www.thesamba.com/vw/archives/manuals/progressive_refinements/index.php
in Jan of '61 the split rear axle boot spare part was changed from 85mm to 89mm so the change on the flanges must have been somewhere not too long before that.
Chris
vwjim
vwjim is offline
PostPosted: Sat Mar 24, 2018 11:55 am    Post subject: Re: Do early transmissions have different gaiters / rubber boots? Reply with quote
Perfect. Thanks for the detailed reply.
