markcm2 Samba Member
Joined: September 02, 2015 Posts: 505 Location: Bellingham, Washington
Posted: Sun Mar 25, 2018 7:54 pm Post subject: What is the wheezing vacuum leak sound from brake pedal switch? |
I’m on a road trip and when coasting down hill, foot off the accelerator, we occasionally hear a whistle wheezing sound from the switch on the brake pedal. It will last a few seconds and/or it stops if I depress the accelerator.
What is this switch and any idea why it whistles when coasting down hill? |
JMB3 Samba Member
Posted: Sun Mar 25, 2018 11:10 pm Post subject: Re: What is the wheezing vacuum leak sound from brake pedal switch? |
markcm2 wrote: |
There are two switches on the brake pedal. One cancels the cruise control. It is a dual function switch. It breaks an electrical connection, so it has wires coming into it, and it opens a vacuum to the atmosphere, so it has a vacuum line attached. http://vweurovan.wikia.com/wiki/Cruise_Control_Brake_Switch |
Posted: Mon Mar 26, 2018 6:51 am Post subject: Re: What is the wheezing vacuum leak sound from brake pedal switch? |
Thank you for the info! |
Zeitgeist 13 Samba Member
Joined: March 05, 2009 Posts: 12167 Location: Port Manteau
Posted: Mon Mar 26, 2018 10:25 am Post subject: Re: What is the wheezing vacuum leak sound from brake pedal switch? |
The vacuum switch was my first thought, but then I remembered that this is a drive by wire engine, so there isn't any vacuum actuator used. Does it still use the vacuum switch? _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
Marshall277 Samba Member
Posted: Wed Dec 13, 2023 10:07 pm Post subject: Re: What is the wheezing vacuum leak sound from brake pedal switch? |
Hi - has anyone resolved this?
I recently purchased a one-owner, 2002 Eurovan MV Westfalia that's in great condition. A few days ago it started making this high pitch noise, and I'm wondering if anyone here found a resolution.
Thanks! |
TheOneTrueQuux Samba Member
Posted: Thu Dec 14, 2023 8:17 am Post subject: Re: What is the wheezing vacuum leak sound from brake pedal switch? |
Marshall277 wrote: |
Thanks! |
It is likely a leaky brake booster. |
Posted: Thu Dec 14, 2023 10:48 am Post subject: Re: What is the wheezing vacuum leak sound from brake pedal switch? |
TheOneTrueQuux wrote: |
Thanks! |
Nice - do I need to replace the booster or can I spray something on it or replace a seal or repair it in any way? Thank you! |
Posted: Thu Dec 14, 2023 4:02 pm Post subject: Re: What is the wheezing vacuum leak sound from brake pedal switch? |
Thanks! |
First confirm the diagnosis by disconnecting and plugging the vacuum line to the booster. If the noise goes away, you've found it.
The usual failure is that the diaphraghm inside gets a tear in it, replacement is usually the only option. |
Posted: Thu Dec 14, 2023 4:11 pm Post subject: Re: What is the wheezing vacuum leak sound from brake pedal switch? |
Thanks! |
This is very helpful. Thank you so much! |
