maloneduke Samba Member
Joined: April 13, 2012 Posts: 94 Location: imperial bch ca
Posted: Sun Apr 22, 2018 2:10 pm Post subject: Transmission woes |
I have a 69 standard bug with a swngaxle. And am using an empi trigger shifter. Drove this morning and now im having trouble fimding first gear. And second gear is just non existent. First at least grinds but second just isnt there. Any ideas on where to start? |
glutamodo  The Android
Joined: July 13, 2004 Posts: 26530 Location: Douglas, WY
Posted: Sun Apr 22, 2018 2:23 pm Post subject: Re: Transmission woes |
Not yet... im just making sure i shouldnt immediately assume the transmission is toast. |
joey1320 Samba Member
Joined: September 12, 2006 Posts: 2338 Location: Cleveland, OH
Posted: Sun Apr 22, 2018 2:49 pm Post subject: Re: Transmission woes |
glutamodo wrote: |
Well, the basics for any shift problem are to inspect the shift rod bushing up front and the coupler cage in back... did you look at those? |
^^^ this before anything else. _________________ 1971 Super - Sold
1984 Puma GTC - Sold
1971 Campmobile |
Posted: Mon Apr 23, 2018 9:24 am Post subject: Re: Transmission woes |
WENT OUT THIS MORNING AND CHECKED THE COUPLER UNDER THE BACK SEAT. I REPLACED IT LAST YEAR, EVERYTHING LOOKED OK. BUT THERE IS A LITTLE SLACK IN THE JOINT BETWEEN THE SHIFT ROD AND COUPLER. I TRIED TIGHTENING THE SCREW ON THE SIDE BUT IT JUST SPINS. SO ITS STRIPPED FOR SURE. OTHER THAN THAT THE RUBBER LOOKS GOOD AND IT IS FIRMLY ATTACHED TO THE ROD COMING FROM THE TRANSMISSION. I CANT CHECK THE TUNNEL BUSHING TILL TOMORROW BUT I REPLACED IT WHEN I DID THE COUPLER SO THERE SHOULD BE NO PROBLEMS THERE EITHER. |
Posted: Mon Apr 23, 2018 9:29 am Post subject: Re: Transmission woes |
ALSO THIS MORNING WHILE DRIVING I DID GET INTO FIRST BUT AS I SHIFTED INTO THIRD IT GOT ALL WHACKY AND WOULDNT GO INTO ANY GEAR. IT ACTED LIKE I DIDNT HAVE THE CLUTCH ENGAGED. I WAS ABLE TO ROLL TO THE SIDE AND TURN THE CAR OFF THEN MOVED THROUGH THE GEARS AND STARTED BACK UP AND SHE ACTED FINE, CONSIDERING STILL NO SECOND GEAR AND FIRST GEAR A GRINDING MYSTERY. THE CLUTCH IS BRAND NEW AS WELL. |
Posted: Mon Apr 23, 2018 3:58 pm Post subject: Re: Transmission woes |
Okay, I didn't mention this because on Bugs it a rare condition, but the needle bearing in the "gland nut" of the honking big bolt that holds the flywheel on, if that bearing goes bad, it "grabs" the input shaft and makes it so the transaxle is always spinning, and that makes for difficult shifting. However this one of those things that shows up worst in first gear, somewhat in 2nd and much less so in 3rd and 4th. _________________ Andy T.
"What is Glutamodo, Horror of Toyko, besides total, fiendish, quality-a-you brain!" |
mukluk Samba Member
Joined: October 18, 2012 Posts: 7452 Location: Clyde, TX
Posted: Mon Apr 23, 2018 6:47 pm Post subject: Re: Transmission woes |
Have you checked the transaxle fluid level and condition? Fluid should be right at the bottom of the fill port, brownish in colour, and not appear to be full of glitter. _________________ 1960 Ragtop w/Semaphores "Inga" |
Posted: Mon Apr 23, 2018 7:11 pm Post subject: Re: Transmission woes |
Made it over to the vw shop by my work. He checked it out and i had everything in right and adjusted properly. Something went foul inside the box. So i nursed her home and she'll sit till i find a new tranny and the dough to put it in.... |
Joined: May 17, 2003 Posts: 4876 Location: Harmony, PA
Posted: Tue Apr 24, 2018 4:32 am Post subject: Re: Transmission woes |
I would look more into the clutch components. I have a car with the trigger type shifter, and had somewhat similar issues of difficulty getting into 1st/2nd. My issue was the cable end at the pedal/pedal hook were severely worn, which wasn't allowing the pedal to fully disengage the clutch. 3rd/4th gears can have the drive hubs come loose, and freewheel, but you don't just simply "lose" 2nd without some sort of catastrophic failure involving missing teeth. |
mukluk Samba Member
Posted: Tue Apr 24, 2018 8:55 am Post subject: Re: Transmission woes |
maloneduke wrote: |
No mention of checking the trans fluid yet.  _________________ 1960 Ragtop w/Semaphores "Inga" |
Posted: Wed Apr 25, 2018 11:02 am Post subject: Re: Transmission woes |
fluid level was fine. i had a leak about two weeks ago on the rear driver side axle cover on the drum, i resealed and topped off my fluid and let it sit overnight with the plug out to make sure it wasnt overfilled. checked fluid this mornibng and level was still fine and didnt look like glitter. honestly i cant keep fixing it. ive had the motor out and apart five times in the last year chasing problems. i finally got the motor right and it wore out what ever was weak in the tranny. its time to accept that i have to rip it all out and start from scratch with all new stuff. only way ill have peace of mind to continue with this madness. |
Posted: Wed Apr 25, 2018 2:58 pm Post subject: Re: Transmission woes |
That's fine if you've decided on a rebuilt trans, but I would still do a little more looking into the issue. If it's something to do with the pedal, or shifting mechanism, it could very well do the same thing with a rebuilt trans. Worse yet, it could damage it. |
Posted: Thu May 03, 2018 4:35 pm Post subject: Re: Transmission woes |
so yeah got in and checked and rechecked everything and all connections are fine, either way i have to rip everything out. while limping my way home my rods and crank blew out the top and sides of the case. so finally at the end of the road for this beast for now. i made the mistake of buying a rebuilt motor from a guy here in town later to find out he was a scam... so i feel the ole girl deserves new legs and a new heart, well at least rebuilt ones from someone with a known reputation. that way i can finally start dressing her up with no further worries... |
