76 bus, new starter noise
cellobus1
cellobus1 is offline
PostPosted: Sat May 12, 2018 6:55 am    Post subject: 76 bus, new starter noise Reply with quote
Hi, all, many questions these days.
Just recently, my (stock) starter has been making a strange new noise. It starts to crank normally, then about 4 or 5 revs in, it starts screeching and the speed of the starter motor decreases. It starts the car, but the noise just before it does sounds more like a motorcycle starter than a VW. Any idears?
Thanks,
Andy
1976 unrestored daily driver Standard bus, "Stella"
formerly, 1959 Standard bus
formerly, 1973 transporter which was 4 years old when it taught me to drive
Abscate Premium Member
Abscate is offline
PostPosted: Sat May 12, 2018 8:45 am    Post subject: Re: 76 bus, new starter noise Reply with quote
I would get it out and bench test it pronto.
If it’s mucking up the flywheel or pilot, an early fix will be a lot cheaper
Tcash
Tcash is offline
PostPosted: Sat May 12, 2018 1:13 pm    Post subject: Re: 76 bus, new starter noise Reply with quote
Starter
As posted, time for a new starter pinion shaft bushing.
Or a rebuilt starter and new bushing.
Good luck
Tcash
SGKent Premium Member
SGKent is offline
PostPosted: Sat May 12, 2018 1:19 pm    Post subject: Re: 76 bus, new starter noise Reply with quote
new bushing - unless one has a spare bell housing, or starter jig one cannot bench test a bus starter. It needs the bushing in the bell housing to hold the armature centered.
cellobus1
PostPosted: Sat May 12, 2018 2:59 pm    Post subject: Re: 76 bus, new starter noise Reply with quote
I heard that you can't just hook a battery up to a loose starter, just didn't know why. New bushing seems to be a good idea anyway. This might be the original starter. Thanks, guys!
cellobus1
PostPosted: Mon May 21, 2018 7:38 pm    Post subject: Re: 76 bus, new starter noise Reply with quote
I finally got some time where my hands didn't have to be clean and got under the bus. I had suspected a loose, unlubricated bushing heated up and came loose, but this is what I found. The remaining screw seemed tight enough. Also including a picture of the pilot shaft for your amusement or scrutiny.
Thanks,
Andy
Abscate is offline
PostPosted: Mon May 21, 2018 11:20 pm    Post subject: Re: 76 bus, new starter noise Reply with quote
Starter jig...wood with hole in it in vice lubricated by spit.
Good for up to e^pi seconds, shown by Goldbach in a recent paper
SGKent is offline
PostPosted: Tue May 22, 2018 10:13 am    Post subject: Re: 76 bus, new starter noise Reply with quote
that broken bolt would let the armature move around. Might be able to pull the other one, take it to an electric shop and see if they have a matching one.
cellobus1
PostPosted: Tue May 22, 2018 2:46 pm    Post subject: Re: 76 bus, new starter noise Reply with quote
It wasn't broken it was just missing. I brought it to my friend Jim Keck today. He had such a bolt laying around in his shop. Screwed it in to the starter and he tried it out on a spare bellhousing he had. It seemed to work ok, but that was with no load. I may be able to install it tomorrow for the real test.
cellobus1
PostPosted: Wed May 23, 2018 5:14 pm    Post subject: Re: 76 bus, new starter noise Reply with quote
Okay, everything's back in and the problem seems to have gone away. The starter seems to spin faster now, too. If it comes back, then I'll have to rebuild my "old growth" starter.
Thanks for the help!
Andy
SGKent is offline
PostPosted: Wed May 23, 2018 6:29 pm    Post subject: Re: 76 bus, new starter noise Reply with quote
that was it. The starter housing was twisting with one bolt gone.
