Color help
John cilia
John cilia is offline
PostPosted: Fri Jun 29, 2018 4:03 pm    Post subject: Color help Reply with quote
Would anyone know the paint color number for the color on seat frames, steering column, shifter and brake handle.
Thanks John.
Currently restoring a 1953 11g in metallic blue.
The most important thing on a Tombstone is the Dash between the 2 dates.
virtanen
virtanen is offline
PostPosted: Fri Jun 29, 2018 11:11 pm    Post subject: Re: Color help Reply with quote
I have used RAL 8025 with a small white addition. This is not correct color for azurblau cars or standards.
Emergency lever was also originally painted like this for late 1951 car with rubber bellows.
Mika
Split beetle restoration panels
Oval beetle restoration panels
New projects
Ovally
Ovally is offline
PostPosted: Sat Jun 30, 2018 9:24 am    Post subject: Re: Color help Reply with quote
VW-color L71 beige paint can be found on the inside of many of the splits and early ovals.
http://paintref.com/cgi-bin/colorcodedisplay.cgi?code=L71&manuf=Volkswagen&rows=50
I used Lada color 509 for my Oval 1953 and is very close to VW color L71.
Regards.
VW Bug Oval 1953
VW Bug 1200 D motor
Porsche 911S MFI 1970
Mazda 929 Hardtop 1977
Mercedes SLC 180 Roadster 2018
beetlekey
beetlekey is offline
PostPosted: Sun Jul 01, 2018 12:57 am    Post subject: Re: Color help Reply with quote
Regards.
That color is wrong for the split!
Hebmüller 581
1953 oval Typ 11G metalblue
1966 1300
If you are searching for vintage keys, look here:
https://www.facebook.com/WagenmanufakturHO
John cilia
PostPosted: Sun Jul 01, 2018 2:46 am    Post subject: Re: Color help Reply with quote
What's right ?
virtanen
virtanen is offline
PostPosted: Sun Jul 01, 2018 4:11 am    Post subject: Re: Color help Reply with quote
Azurblue export split beetle has the parts light beige/grey, but other colors has light brown.
Not to be too easy the rear luggage rails has different color than other inner parts.
Here the light beige luggage rails for brown export beetle Nov. 1951, other inner parts are light brown. (Forget the hubcaps).
Mika
New projects
Ovally
Ovally is offline
PostPosted: Sun Jul 01, 2018 4:17 am    Post subject: Re: Color help Reply with quote
Thanks John.
Should be as Mika said : RAL 8025 with a small white addition for the Spilts but I can't see this color in your picture, maybe only the steering wheel which looks darker.
I my early Oval I used the Lada color 509 which came close to the original VW paint.
I'm not sure it's original but I saw pictures of Split/Zwitters which had the same color as my Oval.
Regards.
VW Bug Oval 1953
VW Bug 1200 D motor
