1964 VW bug how low can you go in the rear?
DcWHaT
DcWHaT is offline
PostPosted: Mon Jul 30, 2018 7:46 pm    Post subject: 1964 VW bug how low can you go in the rear? Reply with quote
Hey all my VW peeps, I have a 64 bug and it is already lowered in the rear. I was curious at what is the lowest degree you can go before u have to do a tranny raise, or remount the shift linkage? Thank you everyone!
TDCTDI
Samba Advocatus Diaboli
TDCTDI is offline
PostPosted: Tue Jul 31, 2018 3:43 am    Post subject: Re: 1964 VW bug how low can you go in the rear? Reply with quote
Depends on how often you want to replace tires.
Canadian VW
Canadian VW is offline
PostPosted: Tue Jul 31, 2018 5:30 am    Post subject: Re: 1964 VW bug how low can you go in the rear? Reply with quote
If the vehicle is static you can run into tire wear issues, fulcrum plates/axles wont be happy, stripping the center out of the rear brake drums is pretty common and the wheel bearings have a tendency to go dry since no oil will travel up the axle tube to lubricate them.
A 1" trans raise will help a bit and keep the shift linkage in the tunnel. A 2" or 3" raise will lead to rear luggage tray modifications, linkage above the tunnel and your engine sitting high in the engine compartment (the engine sitting high is a clearance for the doghouse and if you run dual carbs issue).
Driving with excessive rear camber is a little dodgy, the back end follows every little imperfection in the road. Driving in the wet/rain is a whole new experience as well.
I love the look of a slammed Beetle but just wanted to be honest about what problems you can expect if you are driving it often.
Mine sits very low but I am on air ride and generally don't drive completely lowered unless I am going under 20 KPH (shows/parking lots)
Patrick
Instagram: patrick_macpherson
Samba 67 Beetle build thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=607949&highlight=
slalombuggy
slalombuggy is offline
PostPosted: Tue Jul 31, 2018 6:24 am    Post subject: Re: 1964 VW bug how low can you go in the rear? Reply with quote
You can go so low that you can tear the sump plate off on manhole covers, but I wouldn't recommend it.....
brad
DcWHaT
DcWHaT is offline
PostPosted: Tue Jul 31, 2018 10:05 am    Post subject: Re: 1964 VW bug how low can you go in the rear? Reply with quote
Ok is anyone reading my question I know I can just drop it wear out my tires blah blah blah, I asked at what degree of the is the lowest before i have to do a tranny raise.
DcWHaT
DcWHaT is offline
PostPosted: Tue Jul 31, 2018 10:06 am    Post subject: Re: 1964 VW bug how low can you go in the rear? Reply with quote
Always one smart ass that doesn’t know shit
DcWHaT
DcWHaT is offline
PostPosted: Tue Jul 31, 2018 10:07 am    Post subject: Re: 1964 VW bug how low can you go in the rear? Reply with quote
Patrick
Thank you for actually answering my question somewhat. I know everything u just said was just asking for a number for a level VW for rear spring plate angle, 0 10 5 15? What
Luft kühl
Luft kühl is offline
PostPosted: Tue Jul 31, 2018 11:17 am    Post subject: Re: 1964 VW bug how low can you go in the rear? Reply with quote
So you are saying that if you are stupid enough to have your car that low, that it will not cause premature tire wear ?
Thanks for clearing that up for us.
TDCTDI
TDCTDI is offline
That's better than the dumb ass that thinks he does. Laughing
The further that you lower a swing axle car, the more that the toe and camber are affected, this leads to accelerated tire wear, the further out it is, the faster the tires will wear & the worse the handling will become.
Canadian VW
PostPosted: Tue Jul 31, 2018 12:59 pm    Post subject: Re: 1964 VW bug how low can you go in the rear? Reply with quote
When you are asking for the lowest degree is that degree of camber on the wheel or the degree of the angle of the rear spring plates? I wont have an answer either way since mine is adjustable with air but it might help get you closer to an answer.
Mark Evans Premium Member
Mark Evans is offline
PostPosted: Tue Jul 31, 2018 1:55 pm    Post subject: Re: 1964 VW bug how low can you go in the rear? Reply with quote
The spring plates will only go so low, then hit the stop, unless you get adjustable or lowered plates.
'63 Ragtop
DcWHaT
DcWHaT is offline
PostPosted: Tue Jul 31, 2018 2:36 pm    Post subject: Re: 1964 VW bug how low can you go in the rear? Reply with quote
was just curious, was just a question, I have drop plates on the rear, I trimmed my bump stops down.
DcWHaT
DcWHaT is offline
PostPosted: Tue Jul 31, 2018 2:38 pm    Post subject: Re: 1964 VW bug how low can you go in the rear? Reply with quote
lol you funny, it was just a question of degree that was it. But I guess people from North Carolina can’t read. I know you wear tires and have shitty handling. One day will be able to read.
DcWHaT
DcWHaT is offline
PostPosted: Tue Jul 31, 2018 2:39 pm    Post subject: Re: 1964 VW bug how low can you go in the rear? Reply with quote
pretty much. But it will look awesome
TDCTDI
TDCTDI is offline
PostPosted: Tue Jul 31, 2018 2:49 pm    Post subject: Re: 1964 VW bug how low can you go in the rear? Reply with quote
Rolling Eyes Laughing
But if you try to phonetically pronounce your screen name three times fast it suddenly becomes quite fitting.
DcWHaT
DcWHaT is offline
PostPosted: Tue Jul 31, 2018 4:18 pm    Post subject: Re: 1964 VW bug how low can you go in the rear? Reply with quote
googling words won’t make you smarter.
Luft kühl
PostPosted: Tue Jul 31, 2018 4:41 pm    Post subject: Re: 1964 VW bug how low can you go in the rear? Reply with quote
I am glad that all of the other children will think that your car looks cool .
Who knows, you might finally get all of the attention that you seem to need.
TDCTDI
TDCTDI is offline
PostPosted: Tue Jul 31, 2018 4:53 pm    Post subject: Re: 1964 VW bug how low can you go in the rear? Reply with quote
Google? Wha dat? We hick ass Southnahs don't know about google & we used up all the books to wipe our asses after we visit them there shit shacks.
slalombuggy
PostPosted: Tue Jul 31, 2018 5:05 pm    Post subject: Re: 1964 VW bug how low can you go in the rear? Reply with quote
2 outer splines starts to wear out tires and bearings quickly. So I guess the answer you're looking for is one spline. You can use the RLR kit and raise your transaxle 1 inch and use an early bus nose cone and keep the shift rod in the tunnel. Or you can do what I did on my 57 and drop it one spline and raise the torsion housing 3 inches. Was slammed and rode like a dream
brad
