Dry sump pulleys OR electric scavenge pump
porkchop-rob
porkchop-rob is offline
PostPosted: Sat Aug 04, 2018 4:57 am    Post subject: Dry sump pulleys OR electric scavenge pump Reply with quote
I am having a hard time finding a pulley kit to fit with a dry sump pump and to also keep the stock ratio for the cooling fan.
I am open to any suggestions. I would love to find a serpentine kit....but v-belt is fine too.
I have looked at the 356/912 pulleys, but I’m not seeing a lot of options and the ratio still isn’t perfect.
Thanks!
EDIT** Instead of using the 1 1/2 stage oil pump and changing pulleys, I can run a 12V scavenge pump for the turbo. Does anyone have experience with these 12v setups?
1965 Beetle
1968 Beetle Baja (Son's First Car)
1976 Bus with Subaru (Wife's Riviera Camper)
andy198712
andy198712 is offline
PostPosted: Sat Aug 04, 2018 12:27 pm    Post subject: Re: Sry sump pulleys Reply with quote
VWSPEEDSHOP in the UK sell a kit, defiantly worth a look!
Alstrup wrote:
I like 5,5inchers in the rear at least.
porkchop-rob
PostPosted: Sat Aug 04, 2018 2:15 pm    Post subject: Re: Dry sump pulleys Reply with quote
Edited the original post.
1965 Beetle
Ebel
Ebel is offline
PostPosted: Sun Aug 05, 2018 10:00 am    Post subject: Re: Dry sump pulleys OR electric scavenge pump Reply with quote
If you are using a regular stock sized oil pump you might be able to replace it with the pump from an autostick. It has an extra set of smaller gears that might work to scavenge the turbo oil. And since its thinner then a dry sump pump you should be able to use stock pulleys I think.
Dale M.
Dale M. is offline
PostPosted: Sun Aug 05, 2018 10:31 am    Post subject: Re: Dry sump pulleys OR electric scavenge pump Reply with quote
Are you looking for pump to just scavenge oil from turbo, or full dry sump system?
Dale
porkchop-rob
PostPosted: Sun Aug 05, 2018 1:24 pm    Post subject: Re: Dry sump pulleys OR electric scavenge pump Reply with quote
Dale
Just to scavenge the Turbo.
I was going to run an Autocraft 1 1/2 stage pump...but then I realized my CB Performance Serpentine kit wont fit.
1965 Beetle
Dale M.
Dale M. is offline
PostPosted: Sun Aug 05, 2018 4:03 pm    Post subject: Re: Dry sump pulleys OR electric scavenge pump Reply with quote
porkchop-rob wrote:
Dale
I would look at the autotrans pump concept Ebel suggested... Several in Classified at $20-40 (or a little more).... But it will depend on how much clearance behind pulley....
Dale
Tobias Bylund
Tobias Bylund is offline
PostPosted: Sun Aug 05, 2018 10:44 pm    Post subject: Re: Dry sump pulleys OR electric scavenge pump Reply with quote
I am using a CB dry sump pulley, the one with the steel hub and aluminium outer, and then a porsche 356 alternator pulley, that puts the ratio closer to original, i have not assembled the engine yet though so i cannot report on how it actually works... Smile
mark tucker
mark tucker is offline
PostPosted: Mon Aug 06, 2018 9:09 am    Post subject: Re: Dry sump pulleys OR electric scavenge pump Reply with quote
add a pully. Shocked kinda like the added pully for AC. or.....use a longer belt and re route to the pump.
