how to I tell if flywheel is 36hp?
ragtop man
ragtop man is offline
PostPosted: Sat Aug 18, 2018 11:40 am    Post subject: how to I tell if flywheel is 36hp? Reply with quote
I just bought a 36hp engine. it is missing the flywheel. the person I bought it from said it runs, but I have no way to tell with out a flywheel on it. I have some flywheels but do not know if they are correct for that engine. they are 6v but not sure if they are 40hp or earlier. is there a way to tell if it is a 36hp flywheel?? any help will be appreciated! Confused Confused
parker007
parker007 is offline
PostPosted: Sat Aug 18, 2018 11:53 am    Post subject: Re: how to I tell if fltywheel is 36hop?? Reply with quote
4 small dowels.
ragtop man
PostPosted: Sat Aug 18, 2018 3:44 pm    Post subject: Re: how to I tell if fltywheel is 36hp?? Reply with quote
so the dowel pins will be smaller than a 40hp flywheel?
Robert Chambers
Robert Chambers is offline
PostPosted: Sat Aug 18, 2018 6:18 pm    Post subject: Re: how to I tell if fltywheel is 36hp?? Reply with quote
Yes, the 4 dowel pins are smaller in diameter. Same 6 volt flywheel size and 180mm clutch.
'63 OG 117 Herbie Replica
'56 Euro Oval Deluxe
'52 Standard Zwitter
'63 OG 117
esde
esde is offline
PostPosted: Sat Aug 18, 2018 8:07 pm    Post subject: Re: how to I tell if fltywheel is 36hp?? Reply with quote
40hp, 1500-1600 use 8mm dowels
36hp use 6mm dowels
modok wrote:
