Motorcycle turn signals?
Bkhansen93
Bkhansen93 is offline
PostPosted: Fri Feb 22, 2019 7:12 pm    Post subject: Motorcycle turn signals? Reply with quote
Hey guys. I cant remember, what is the motorcycle turn signal people use on buggies? I remember them being kind of tucked away under the hood area. A ducati or kawasaki set maybe?
Dale M.
Dale M. is offline
PostPosted: Fri Feb 22, 2019 7:37 pm    Post subject: Re: Motorcycle turn signals? Reply with quote
Find anything on a stalk (to move it out a bit from body) and make a mount bracket... Boom you are done ... Brand has no bearing.... Find something that is visual appealing to you... If you want turnsignal only a single filament bulb is all it has to have, if you want parking/marker lights and turnsignal lamps be sure it has dual filament bulb....
Dale
Bkhansen93
PostPosted: Fri Feb 22, 2019 10:53 pm    Post subject: Re: Motorcycle turn signals? Reply with quote
Thanks for the help Dale.
Gary0302
Gary0302 is offline
PostPosted: Sat Feb 23, 2019 8:26 am    Post subject: Re: Motorcycle turn signals? Reply with quote
Just as an example, this is the motorcycle turn signal that I am using (part #25-2205). This particular part # has a 3-wire setup, allowing me to use them both as a front turn signals and night running lights (dual filament bulbs required). I was able to find this product online at cheaper prices, but I wanted to send you a link where it specifically lists this item with 3 wires.
I liked the fact that the black stem blends into the background, if that makes sense. I can't remember if the bulbs themselves were included, or not.
https://www.denniskirk.com/k-and-s/front-left-righ...210252.sku
Gary David Holbrook
Facebook and YouTube
Coastal North Carolina
Check out my videos on Youtube
"It's a buggy not a space shuttle...." - Dale M.
"When in doubt, blame it on the previous owner" - Gary0302
Gwoolsey56
Gwoolsey56 is offline
PostPosted: Mon Feb 25, 2019 7:25 am    Post subject: Re: Motorcycle turn signals? Reply with quote
I know this is not what you are wanting but here is what I am going to use. got it off of ebay. https://www.ebay.com/itm/152423012067?hash=item237d1e96e3
ONEBADBUG
ONEBADBUG is offline
PostPosted: Mon Feb 25, 2019 9:20 am    Post subject: Re: Motorcycle turn signals? Reply with quote
Honda CB750 is one of the most common, readily available on Ebay.
markdam
markdam is offline
PostPosted: Wed Feb 27, 2019 12:29 am    Post subject: Re: Motorcycle turn signals? Reply with quote
Sorry to hijack but that flake is delicious.
