CLK Wheels and Hi Lift Jack?
beach_creature
beach_creature is offline
PostPosted: Mon Apr 01, 2019 4:56 pm    Post subject: CLK Wheels and Hi Lift Jack? Reply with quote
Looking for advice.
I have a Hi Lift - Lift Mate, used to jack up vehicles by their wheels. It doesn't seem to be compatible as is with the CLK wheels.
But using a climbing sling, I can run it through one or two spokes. The sling is rated to 22 kN or about 10 000 lbs. I would use two slings thus making it 20,000 lbs.
Would the CLK wheels withstand lifting the vehicle like this? I wouldn't want to damage the wheels, or have them break while lifting.
Placing behind two spokes is less force on the wheel, but then increases the angle of the sling and then the sling is not as strong.
Using one spoke, has a good angle for sling strength, but more force on one spoke.
What do people think about this?
Is this safe?
84 Westy
1.9TD AAZ
5spd manual with Locking Peloquin TBD
beach_creature
PostPosted: Mon Apr 01, 2019 5:00 pm    Post subject: Re: CLK Wheels and Hi Lift Jack? Reply with quote
Lift Mate in action.
84 Westy
1.9TD AAZ
SCM
SCM is offline
PostPosted: Mon Apr 01, 2019 5:21 pm    Post subject: Re: CLK Wheels and Hi Lift Jack? Reply with quote
Are the wheel’s spikes rounded enough to not worry about cutting the webbing?
How would change a flat tire using the jack that way?
'91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine
beach_creature
PostPosted: Mon Apr 01, 2019 5:46 pm    Post subject: Re: CLK Wheels and Hi Lift Jack? Reply with quote
The spokes are pretty smooth and should not cut the sling.
This would only be for lifting a wheel to fill underneath it in recovery situations. I have the GW hi lift adapter for the stock jack location for a tire change.
84 Westy
1.9TD AAZ
tencentlife
tencentlife is offline
PostPosted: Tue Apr 02, 2019 3:18 pm    Post subject: Re: CLK Wheels and Hi Lift Jack? Reply with quote
With the dynamic loading webbing can take, you're fine, you're just static lifting.
Experience is death to doctrine.
Zeitgeist 13
Zeitgeist 13 is offline
PostPosted: Tue Apr 02, 2019 3:50 pm    Post subject: Re: CLK Wheels and Hi Lift Jack? Reply with quote
The Fuchs rims are forged, so I assume they're stronger than regular cast aluminum rims.
Casey--
'01 Weekender --> full camper
y u rune klassik?
beach_creature
PostPosted: Tue Apr 02, 2019 4:41 pm    Post subject: Re: CLK Wheels and Hi Lift Jack? Reply with quote
And any thoughts on lifting from One spoke versus Two spokes?
84 Westy
1.9TD AAZ
SyncroHead
SyncroHead is offline
PostPosted: Tue Apr 02, 2019 8:03 pm    Post subject: Re: CLK Wheels and Hi Lift Jack? Reply with quote
I'm concerned that there may not be enough clearance behind the spokes and in front of the brakes to get the strap through there.
I'd say if you can actually get it through with the wheels on the van, go for it.
Jim
"A Vanagon? It's not a car or a van. It's a hobby!"
Check out:
www.VANAVATION.com
www.SyncroSafari.org and
www.Vanagons.org
sphet wrote:
I have *no* idea what the previous owner carried in his Westy... angry donkeys?
AZ Landshaper
AZ Landshaper is offline
PostPosted: Tue Apr 02, 2019 8:22 pm    Post subject: Re: CLK Wheels and Hi Lift Jack? Reply with quote
Think it has limited uses and would see action "maybe" twice in my life time.
I grew up on the beach and never needed anything like that w the exception of the one time my Rabbit got stuck. by the time we got it out the water was up to the windows. Ok so I needed one of these once in 15 years.
Support Small Business.
85 Weekender w/ EJ22
Previously
64, 71, 72, 73, 76, 81, 84, 85 & 87 Campmobiles and Westfalias
and a 67 bug.
jimf909
jimf909 is offline
PostPosted: Tue Apr 02, 2019 9:30 pm    Post subject: Re: CLK Wheels and Hi Lift Jack? Reply with quote
AZ Landshaper wrote:
...by the time we got it out the water was up to the windows. Ok so I needed one of these once in 15 years.
That deserves an accompanying photo!
- Jim
Butcher wrote:
Guilty as charged.
markswagen
markswagen is offline
PostPosted: Wed Apr 03, 2019 7:09 am    Post subject: Re: CLK Wheels and Hi Lift Jack? Reply with quote
Why not use something like this, they work very well, and weigh a LOT less than the high lift Jack's, easy to use, especially in sand or soft ground.
https://www.ebay.com/itm/New-Arrival-4Ton-Exhaust-...ect=mobile
619 201 0310
raoul mitgong
raoul mitgong is offline
PostPosted: Wed Apr 03, 2019 8:20 am    Post subject: Re: CLK Wheels and Hi Lift Jack? Reply with quote
Just be sure to retire that sling from your climbing rack. Shocked
-d
84 Westy with a 2.1 (Groover)
86 Tintop Syncro (Crow)
86 Tintop Syncro to Westy project (Tom Servo)
91 Westy (Only the top 12 inches of this van (a burn victim))
beach_creature
PostPosted: Wed Apr 03, 2019 10:35 am    Post subject: Re: CLK Wheels and Hi Lift Jack? Reply with quote
Ya I was going to get new slings for the wheels. That sling in the photo I only use to sort my draws.
As far as the exhaust jack goes...
https://m.youtube.com/watch?v=T5I4gae00Ho
84 Westy
1.9TD AAZ
