SyncroButter Samba Member
Joined: February 02, 2016 Posts: 401 Location: Seattle
Posted: Mon Jun 03, 2019 10:59 am Post subject: Product recommendation: Blue Sea "EasyID" blade fuses |
Hi All,
I'm not normally one to shill for a product, but I thought this one was worth sharing. I was installing a gauge that connects to my OBDII port on my Bostig install and I blew the fuse that protects the OBDII connection. To my surprise the fuse that blew lit up with a little LED light. I had never seen this before, I had used the fuses that Bostig provided with their kit and had no idea that these fuses were special in any way.
After researching a bit, there appear to be a few companies that offer something like this (I bought some from Blue Sea that are called "easyID"). Note that there are also some that offer a fuse that lights up only when the fuse is *not* blown in case you want a christmas tree fuse block, so be sure you ID the type before buying.
Anyway, maybe I'm late to the party and you are all using type of product already but it was news to me so wanted to share the recommendation with all of you all since it makes it so easy to identify at a glance that you have an electrical issue. _________________ Grant
In the stable: 1986 Syncro Westfalia/Bostig, 1989 Doka Tristar, 1974 Vespa Rally 200, 1973 Vespa Primavera 125, 1963 Solex 2200, 1938 Buick Special
Gone but not forgotten: 1989 Porsche 944, 1973 Standard Beetle |
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12325 Location: Santa Cruz, CA
Posted: Mon Jun 03, 2019 12:14 pm Post subject: Re: Product recommendation: Blue Sea "EasyID" blade fuses |
I have been using them for 7 years and they have proven themselves to be useful. No.need to guess if it is a fuse issue, just pop open the cover and the tattletail LED let's you know which fuse has popped. |
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5930 Location: Tsawwassen, BC
