bnam Samba Member
Joined: July 02, 2006 Posts: 3481 Location: El Dorado Hills CA/ Bangalore, India
Posted: Tue Jul 16, 2019 9:56 am Post subject: Help deciphering a Syncro |
Hi!
A friend here in India just picked up a VW Syncro T3. These were never officially sold here and were typically private, consular, or govt imports.
The seller had 2 Typ 3s. One was this syncro and the other a camper (without its TD engine).
We're trying to decipher some inconsistencies and need help on this.
The Syncro is RHD with a DJ code engine.
As I looked up the info, somethings did not seem to fit together well. The manf plate and m-code sticker are both there.
Here's the data --
Manf plate:
Typ - 253 - 299 (this was confusing as it indicates a LHD with 1.6L TD engine if I've interpreted it correctly).
Chassis number: WV2ZZZ25ZHG051167 (this shows up on one site as an 87 Combi 2WD). Go Westy says:
W - germany
V - VW
2 - MPV
Z - camper
Z - ?
Z - ?
25 - Vanagon
Z - check digit
H - 1987
G - Graz (normally for Syncro)
In my search I came across both Westy's and a Doka Syncro that came with ZZZ - so could ZZZ in this case refer to the syncro?
M-code sticker:
ENGINE CODE/Trans Code: DJ AAK
PAINT NO/INTERIOR: LH1B/LH9D AK
M-options: DWZ HS8 018 183 187 343 545 573 999
THe paint (Bamboo yellow lower, white on top) and other options seem to match.
I did not get info on DWZ and HS8.
So, what's going on here? Is the manf ID consistent with a Syncro?
If it is consistent with a Syncro, then the remaining inconsistencies would be: (1) the TYP showing as 253 which is listed in all the lists as a LHD while this is clearly a RHD. My friend believes he has seen instances of UK RHD Syncros with 253 as typ.
(2) typ 253-299 --> the engine seems to point to a 1.6L TD while the Mcode shows a DJ engine. Is it possible that in this case the 299 just refers to M299 (syncro option)?
(3) the DJ engine has a carb and looks factory. My friend was expecting DJs to be FI only.
Thanks! _________________ 1971 1302LS Convertible (RHD) owned since '74
Click to view image
1952 Citroen TA 11BL |
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12351 Location: Santa Cruz, CA
Posted: Tue Jul 16, 2019 11:00 am Post subject: Re: Help deciphering a Syncro |
ZZZ is a european vin code |
termuehlen  Samba Member
Joined: May 02, 2012 Posts: 1033 Location: Redwood City
Posted: Tue Jul 16, 2019 12:04 pm Post subject: Re: Help deciphering a Syncro |
As you indicate in your VIN reading, the last G means it was built in Graz. Only syncros were assembled in Graz.
As Syncrodoka said, the ZZZ was issued for non-US models. The GoWesty VIN decipher key is intended for US models only. So the meaning of the ZZZ letters is not listed in their key. _________________ 1988 Westfalia automatic Subaru OBD1
1986 syncro tintop wbx |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 18840 Location: Retired South Florida
Posted: Tue Jul 16, 2019 12:59 pm Post subject: Re: Help deciphering a Syncro |
My Syncro does have a ZZZ in the chassis number stamped into the frame near the rf jack point. The door jam and dash have the same number minus the ZZZ. It’s a North American Syncro. |
Arne@kleinersyncro Samba Member
Joined: May 04, 2011 Posts: 74 Location: Australia VIC
Posted: Tue Jul 16, 2019 1:25 pm Post subject: Re: Help deciphering a Syncro |
Nice find of your friend
The 253-299 is the number for the chassis variant.
253 = window van with up to 9 seats
-299 = add on for Syncro
It doesn’t tell anything about Engine or RHD/LHD. Same with theChassis number, this won’t tell you anything too apart if identifying the car. The multiple Z’s in the European VIN numbers are used as spacer!
The sticker under the dashboard is relevant for engine code, gearbox, paint code and add on’s (M-Codes).
M-Codes List:
http://vwt3.com/t3-tech/t3-data/vw-t3-m-codes-options-list/
Cheers Arne _________________ 1991 Syncro self made camper van, cruising around the Black Forrest area (Germany)
1990 Syncro converted by Camperize NSW, cruising around Australia |
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6932 Location: Fort Lauderdale, Fl.
Posted: Tue Jul 16, 2019 1:27 pm Post subject: Re: Help deciphering a Syncro |
Think you have all the lines sorted, but this might help. (This VIN # is mine hence the M for 1991 while yours is "H" for 1987.) _________________ This free advice is worth exactly what you paid for it.
Posted: Tue Jul 16, 2019 1:40 pm Post subject: Re: Help deciphering a Syncro |
a good website for info is
http://syncro.org/how-to-fix-a-vw-syncro/ _________________ This free advice is worth exactly what you paid for it.
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 10403 Location: Orbiting San Diego
The assembly plant depends some on the year. When the Hannover plant was switching over to T4 they diverted 2wd T3 production to Graz as there was still demand. So a 90 or 91 2wd could be built in either place, 92 2wd Graz only afaik.
For example, these in the classifieds.
A 90 2wd from Graz
https://www.thesamba.com/vw/classifieds/detail.php?id=2291869
A 91 2wd from Graz
https://www.thesamba.com/vw/classifieds/detail.php?id=2286233
Mark
termuehlen wrote: |
As you indicate in your VIN reading, the last G means it was built in Graz. Only syncros were assembled in Graz. |
Posted: Tue Jul 16, 2019 4:09 pm Post subject: Re: Help deciphering a Syncro |
Mark:
Thanks for clarifying the late T3 production move to Graz. I had no idea! _________________ 1988 Westfalia automatic Subaru OBD1
bnam Samba Member
Posted: Tue Jul 16, 2019 5:41 pm Post subject: Re: Help deciphering a Syncro |
Thanks guys! I will relay the confirmation to my friend.
Any ideas on the DWZ and HS8 codes?
And, were the 2.1l DJ engines also offered with carb option? _________________ 1971 1302LS Convertible (RHD) owned since '74
Click to view image
Posted: Wed Jul 17, 2019 3:58 am Post subject: Re: Help deciphering a Syncro |
Don’t know what the other two codes are, could have been something internal.
The DJ was always EFI via Digijet.
bnam Samba Member
Posted: Wed Jul 17, 2019 6:07 pm Post subject: Re: Help deciphering a Syncro |
Arne,
This is the engine in the syncro. The engine is a DJ. Factory stamping. But running on carb. It looks like a factory conversion. Definitely not something that would have been done in India.
The syncro was offered by the German Govt to the Indian govt for some social program. We're wondering if it was special ordered with a conversion to carb as FI would not have been maintainable in the rural locations that the van was being destined for. Perhaps the unexplained option codes in the sticker account for it?
Click to view image
Posted: Wed Jul 17, 2019 7:50 pm Post subject: Re: Help deciphering a Syncro |
That is looking exceptionally clean! If the rest of it is like this then you have made a good deal! _________________ This free advice is worth exactly what you paid for it.
bnam Samba Member
Posted: Wed Jul 17, 2019 8:09 pm Post subject: Re: Help deciphering a Syncro |
MY friend with his new syncro...
Click to view image
bnam Samba Member
Posted: Wed Jul 17, 2019 8:12 pm Post subject: Re: Help deciphering a Syncro |
On the m-code sticker, the AAK apparently refers to open differential. Any ideas on what the AK in the second line stands for? _________________ 1971 1302LS Convertible (RHD) owned since '74
Click to view image
kamzcab86 Samba Moderator
Posted: Wed Jul 17, 2019 9:31 pm Post subject: Re: Help deciphering a Syncro |
bnam wrote: |
Any ideas on what the AK in the second line stands for? |
Upholstery code.
And, nice-looking two-tone Syncro!  _________________ ~Kamz
2016 Golf GTI S
SyncroButter Samba Member
Joined: February 02, 2016 Posts: 401 Location: Seattle
Posted: Thu Jul 18, 2019 9:16 am Post subject: Re: Help deciphering a Syncro |
Exceptionally clean Syncro, never seen a two tone before... clean looking carb conversion as well. Neat! _________________ Grant
In the stable: 1986 Syncro Westfalia/Bostig, 1989 Doka Tristar, 1974 Vespa Rally 200, 1973 Vespa Primavera 125, 1963 Solex 2200, 1938 Buick Special
Gone but not forgotten: 1989 Porsche 944, 1973 Standard Beetle |
Posted: Thu Jul 18, 2019 9:20 am Post subject: Re: Help deciphering a Syncro |
bnam wrote: |
If he owns that why isn't he smiling from ear to ear?  _________________ This free advice is worth exactly what you paid for it.
Posted: Thu Jul 18, 2019 9:37 am Post subject: Re: Help deciphering a Syncro |
PS: tell your friend to change out his gas lines! _________________ Grant
bnam Samba Member
Posted: Thu Jul 18, 2019 6:04 pm Post subject: Re: Help deciphering a Syncro |
SyncroButter wrote: |
Exceptionally clean Syncro, never seen a two tone before... clean looking carb conversion as well. Neat! |
Too clean to have been done here. That's why we suspect it was a factory conversion (as a special order) or possibly a dealer conversion in Germany before it was shipped to India. _________________ 1971 1302LS Convertible (RHD) owned since '74
Click to view image
