Fuse chart for 1969 Beetle
Curtpg
Curtpg is offline
PostPosted: Mon Aug 05, 2019 11:43 am    Post subject: Fuse chart for 1969 Beetle Reply with quote
HELP! I'm trying to determine the correct sizes (current) for the fuses in my 69 Beetle. The only chart I found indicated 10 amp for all 10 fuse positions. But that's not what's currently in the fuse panel. Help Please!
mukluk
mukluk is offline
PostPosted: Mon Aug 05, 2019 12:13 pm    Post subject: Re: Fuse chart for 1969 Beetle Reply with quote
Assuming the car has stock electrical, just go by the owner's manual. All positions are 8 amp.
Curtpg
Curtpg is offline
PostPosted: Mon Aug 05, 2019 4:20 pm    Post subject: Re: Fuse chart for 1969 Beetle Reply with quote
Thanks for the chart. My Bug had 8, 16 and 25 amp fuses in it. That's what worried me. But you are confirming what I found so I guess it will be all 8 amps. Thanks again! Curt
KTPhil Premium Member
KTPhil is offline
PostPosted: Mon Aug 05, 2019 5:08 pm    Post subject: Re: Fuse chart for 1969 Beetle Reply with quote
Are there any high-current accessories added? That might explain the larger fuses. I'm thinking big stereo, foglamps, aux heater, etc.
Curtpg
Curtpg is offline
PostPosted: Mon Aug 05, 2019 5:27 pm    Post subject: Re: Fuse chart for 1969 Beetle Reply with quote
Not a thing, totally stock.
mukluk
mukluk is offline
PostPosted: Mon Aug 05, 2019 5:39 pm    Post subject: Re: Fuse chart for 1969 Beetle Reply with quote
I've found often the reason you find a number of 16 and 25 amp fuses installed in a Bug where 8 amp fuses are called for is simply because most of the replacement fuse kits at parts stores came with a mix of 8, 16, and 25 amp fuses -- many VW owners won't throw away perfectly good fuses and will use what they have, even if they're the wrong rating.
