69 doesn't like to accelerate
grewp
grewp is offline
PostPosted: Mon Aug 19, 2019 4:56 pm    Post subject: 69 doesn't like to accelerate Reply with quote
My 69 beetle starts fine, idles fine but when I accelerate, even a tiny bit, it coughs and gasps. It has been running well until now. I filled the tank the day before.
Any ideas are greatly appreciated.
Pat
69 Beetle
glutamodo Premium Member
The Android
glutamodo is offline
PostPosted: Mon Aug 19, 2019 5:09 pm    Post subject: Re: 69 doesn't like to accelerate Reply with quote
Sounds like the carburetor's "accelerator pump" is not functioning properly. This is a nozzle that should start to shoot extra fuel down the carburetor whenever you open the throttle.
Also sounds like a carburetor/distributor mismatch.
Add the two together and you get Brick wall
Andy T.
grewp
grewp is offline
PostPosted: Mon Aug 19, 2019 5:16 pm    Post subject: Re: 69 doesn't like to accelerate Reply with quote
Thank you. I will look into the pump. Any advice on how to test this?
Pat
69 Beetle
andk5591
andk5591 is offline
PostPosted: Mon Aug 19, 2019 5:46 pm    Post subject: Re: 69 doesn't like to accelerate Reply with quote
Yeah - take the air cleaner off. You will see a nozzle or two toward the top of the carb. When you work the throttle, you should see a stream of gas coming out shooting down the throat of the carb. Should be a nice spray.
But you said it was fine until now, correct?
D-Dubya Manx clone 1914. Ex wifes car.
Maxine 61 Cal-look bug - Ex-wifes car.
There's more, but not keeping them...
sb001
sb001 is offline
PostPosted: Mon Aug 19, 2019 5:53 pm    Post subject: Re: 69 doesn't like to accelerate Reply with quote
This is absolutely the only thing you did before it started acclerating poorly? You did not touch or replace anything at all?
I'm the humblest guy on this board.
1600 SP engine
Solex 30 PICT 3 carburetor
Bosch 113905205AE autostick distributor
The Android
PostPosted: Mon Aug 19, 2019 5:55 pm    Post subject: Re: 69 doesn't like to accelerate Reply with quote
Yeah, I think I see where this line of inquiry is going as I've twice over the years been affected by contaminated fuel - both times I strongly suspect diesel got mixed in with gasoline
Andy T.
grewp
grewp is offline
PostPosted: Sat Oct 05, 2019 10:02 am    Post subject: Re: 69 doesn't like to accelerate Reply with quote
Sorry for being so late in responding ... yes, I have done no repairs at all. Been driving it all summer. Just jumped in the one day and as I was driving it began acting up. Idled it in first gear all the way home.
69 Beetle
VW_Jimbo Premium Member
VW_Jimbo is offline
PostPosted: Sat Oct 05, 2019 10:10 am    Post subject: Re: 69 doesn't like to accelerate Reply with quote
Super easy to check!
Plugged up acceleration circuits are very common. Probably the most common complaint with carburetored cars.
Jimbo
TDCTDI wrote:
67rustavenger wrote:
