O2b Right hand drive flange oil seal
Capt Ken
Capt Ken is offline
PostPosted: Thu Sep 26, 2019 2:07 pm    Post subject: O2b Right hand drive flange oil seal Reply with quote
Tried the easy trans leak fixes. Slowed it down, but didn't stop after 500 miles. Time to replace. Bentley's makes it sound too hard for DIY. Anybody tackle this before? Are special tools really needed. Thanks in advance.
Capt Ken
Capt Ken is offline
PostPosted: Tue Oct 01, 2019 5:21 am    Post subject: Re: O2b Right hand drive flange oil seal Reply with quote
Somebody out there must have done this repair.
Zeitgeist 13
Zeitgeist 13 is offline
PostPosted: Tue Oct 01, 2019 7:58 am    Post subject: Re: O2b Right hand drive flange oil seal Reply with quote
[youtube]https://m.youtube.com/watch?v=WyD646NEX0k[/youtube]
Hmmm...not sure this isn't posting correctly. I recently did this on a Corrado, and it was similar.
Casey--
'89 Bluestar ALH
'01 Weekender --> full camper
NEAT, no ICE.
CdnVWJunkie Premium Member
CdnVWJunkie is offline
PostPosted: Tue Oct 01, 2019 9:22 am    Post subject: Re: O2b Right hand drive flange oil seal Reply with quote
Are you talking about the actual output seal or the large internal O-ring inside the right "leg" ? (brain cramp, can't recall technical term right now)
I've replaced the internal O-ring on several T4 gearboxes. Be very careful with how you handle and remove them. They're cast aluminum and can be brittle. Remove the RT half shaft. Remove the four perimeter bolts around the flange into the main trans housing. Remove the leg support. I suggest some penetrant sprayed liberally between the flange and housing. Gently pry and use a plastic dead blow hammer to persuade them apart. It does make it a bit easier if you pull the axle out of the housing ahead of removing the flange. It is held in with internal C-clip.
Capt Ken
Capt Ken is offline
PostPosted: Tue Oct 01, 2019 2:52 pm    Post subject: Re: O2b Right hand drive flange oil seal Reply with quote
Not sure which seal is leaking, seeing it on the ground by the front right wheel. Hoping it is the output seal. Don't have the facilities to drop the trans.
Capt Ken
Capt Ken is offline
PostPosted: Tue Oct 08, 2019 2:36 pm    Post subject: Re: O2b Right hand drive flange oil seal Reply with quote
I can't find anyone that stocks this. Is it also know as the differential shaft seal?
Corteco Differential Seal - Right
Corteco logo Corteco Differential Seal Click to Enlarge
(Read reviews)
Our List Price:
$10.73
Quantity:
1
(35) In Stock
Part Number: 7399-08005491
Notes: Differential Output Shaft Seal (45 X 60 X 8 mm)
Position: Right
Condition: New
Zeitgeist 13
PostPosted: Tue Oct 08, 2019 6:30 pm    Post subject: Re: O2b Right hand drive flange oil seal Reply with quote
https://www.jimellisvwparts.com/showAssembly.aspx?...evel=18859
This might help
Casey--
'89 Bluestar ALH
NEAT, no ICE.
Mr Brown
Mr Brown is offline
PostPosted: Mon Dec 02, 2019 9:24 pm    Post subject: Re: O2b Right hand drive flange oil seal Reply with quote
Sure it is the gearbox leaking? I rebuilt my gearbox( some time ago so a little fuzzy) and while I didn't change the seal in the van it should be pretty straight forward. The image shown in the previous reply shows what you need to know. I pulled the RH shaft out with the flange as I was doing a rebuild. Hopefully you can pull the flange from the shaft without disengaging the circlip in the diff, not a big deal either way probably. You may need some bolts with long threads to pull off the flange or shaft, was quite tight as far as I remember. You might want to have something around to put between jacking bolts and leg so as not to damage anything.
I just bought a new seal from the dealer last week as I need to replace the driver side one so they are still available.
