Left Turn Signal
blinkwatt
blinkwatt is offline
PostPosted: Fri Oct 04, 2019 3:51 pm    Post subject: Left Turn Signal Reply with quote
Hi,
My cars left turn signal was working, when bought 3-4 months ago, but the automatic release(to indicate not turning anymore) doesn't work. I was told when the Momo steering wheel was put on they lost the auto release feature.
Now that I've driven the car a far share the left turn signal indicator flashes once, then stops.
Anyone have a clue? I'm not opposed to just replacing the steering switch if need be, but from searches it seems the aftermarket aren't as good as OEM. I just want it to work.
70'.
VW_Jimbo Premium Member
VW_Jimbo is offline
PostPosted: Fri Oct 04, 2019 5:00 pm    Post subject: Re: Left Turn Signal Reply with quote
Have you looked at the bulbs and the wiring attached to the housing and the ground points?
My bet is a ground issue.
Jimbo
TDCTDI wrote:
67rustavenger wrote:
blinkwatt
PostPosted: Fri Oct 04, 2019 5:35 pm    Post subject: Re: Left Turn Signal Reply with quote
I can take a look tonight.
As far the turn signal releasing, I was told when they put the Momo wheel on they didn't have a specific part for it to work. Do you know what they were referencing?
blinkwatt
PostPosted: Fri Oct 04, 2019 6:48 pm    Post subject: Re: Left Turn Signal Reply with quote
Thank you good sir! The driver side rear turn signal bulb was loose.
VW_Jimbo is offline
PostPosted: Sat Oct 05, 2019 10:15 am    Post subject: Re: Left Turn Signal Reply with quote
The cancellation ring. It screws onto the bottom of the steering wheel and has a tab which directly interacts with the cams of the turn signal switch.
Jimbo
