Renogy Solar Panel Sale
shadetreemech
shadetreemech is offline
PostPosted: Tue Oct 22, 2019 7:54 am    Post subject: Renogy Solar Panel Sale Reply with quote
I bought Renogy's 100 Watt Suitcase setup a while back. Bypassed the built-in controller and added a 25' extension to hook the panels up to my Goal Zero Yeti.
Renogy's having a Sale if you're interested:
https://www.renogy.com/on-sale/?utm_source=Renogy+...165ebc25c3
Disclaimer: I am not now nor have I ever been, blah, blah, Renogy, blah, blah.
Also: How to Bypass Renogy Suitcase Controller:
https://thecampingnerd.com/bypass-solar-charge-controller-renogy/
Dan
'84 GL 1.9
'01 Volvo V70 T5
'88 Westy - "MZDRTHY"
kamzcab86
kamzcab86 is offline
PostPosted: Tue Oct 22, 2019 8:20 am    Post subject: Re: Renogy Solar Panel Sale Reply with quote
I've got their first iteration of the suitcase panel... still going strong. Although, I removed the charge controller, installed it inside the van, and permanently connected the panel wires. The controller is wired to the battery (didn't want to deal with alligator clips), and the panels get connected to the controller via Anderson connector in the former city water hookup box.
I did the same thing for my parents' van, except bought the suitcase version without controller (bought controller separately), and used GW's solar hookup box. Built the whole thing at home; when I arrived at their van, installation was practically plug-n-play.
~Kamz Anxious
2016 Golf GTI S
Ahwahnee
Ahwahnee is offline
PostPosted: Tue Oct 22, 2019 10:46 am    Post subject: Re: Renogy Solar Panel Sale Reply with quote
Is this the one you speak of?
https://www.renogy.com/100-watt-12-volt-monocrysta...ontroller/
Does it fit in the well of the luggage rack (assuming you park pointing south)?
Thanks.
Sodo
Sodo is offline
PostPosted: Tue Oct 22, 2019 2:13 pm    Post subject: Re: Renogy Solar Panel Sale Reply with quote
Heres appx dims of the flat floor area.
It gets a little bigger as you rise up out of the rounded corners.
Looks like it will fit in the middle of the cargo area while folded up, then certainly fits when opened and up on the stand.
....KTMs, GasGas, SPOT mtb
Howesight
Howesight is offline
PostPosted: Tue Oct 22, 2019 2:25 pm    Post subject: Re: Renogy Solar Panel Sale Reply with quote
My Renogy 100W folding panel fit nicely:
'86 Syncro Westy SVX
Ride-Fly
Ride-Fly is offline
PostPosted: Tue Oct 22, 2019 9:14 pm    Post subject: Re: Renogy Solar Panel Sale Reply with quote
So I know nothing of electricity. I just got GW’s Aux Batt kit with the LiFePo battery. Next I need solar panels, and was thinking Goal Zero. But if I want permanent panels, I need something like Renogy right? But wondering why bigger isn’t better. To charge a house battery, you need a 12V system, but why wouldn’t Renogy’s 300W 12V system be better for the off-grid Vanagon? Is it just overkill? If it’s overkill, what is the optimum system to go with? Thanks.
kamzcab86
PostPosted: Tue Oct 22, 2019 9:44 pm    Post subject: Re: Renogy Solar Panel Sale Reply with quote
It all depends what your system needs; each van requires its own setup. For me, a 50Ah aux battery that simply powers a 12V fridge, LED lights, faucet pump, and occasional phone charging, 100W/120W* works just dandy... 300W would be overkill.
*I've got the 100W Renogy suitcase and a 120W Solar Blvd. flex panel... which one I use depends on where I am.
~Kamz Anxious
2016 Golf GTI S
shadetreemech
PostPosted: Wed Oct 23, 2019 5:32 am    Post subject: Re: Renogy Solar Panel Sale Reply with quote
I carry my Suitcase setup in the space behind the bunk mattress, safe from the elements.
I chose the portable option so I could position panels toward the Sun at the optimum angle. The extension cord, with MC4 connectors, adds to the versatility.
Dan
'84 GL 1.9
'01 Volvo V70 T5
Syncro Jael
Syncro Jael is offline
PostPosted: Wed Oct 23, 2019 9:32 am    Post subject: Re: Renogy Solar Panel Sale Reply with quote
Just get a 100 watt flexible panel. Light weight, easily stores under the top bunk cushions when traveling.
1987 Syncro Westfalia Hightop - NAHT
Subaru EJ25 Forged Frankenmotor, Triple Knob.
Jael = (Mountain Goat)
