Wire plug
pjtaxi
pjtaxi is offline
PostPosted: Wed Oct 30, 2019 8:17 am    Post subject: Wire plug Reply with quote
Does anyone know what this is. Engine compartment 1969 bay
jmstu76
jmstu76 is offline
PostPosted: Wed Oct 30, 2019 8:24 am    Post subject: Re: Wire plug Reply with quote
Drivers side?
Can you post a broader picture? so that we have some reference of were the plug is and where the wire it's attached to goes...
It possibly is the power to your reverse lights. The positive power comes off the positive side of the coil.
James
'76 Deluxe Sage Green Westy
2258 cc GD case 78mm CW crank, 2.0 H-beam rods 5,325” 22mm pin, JE forged pistons with 15cc dish, JE rings, type 11 clearanced oil pump, CB Eagle 2205 Type-2 “Torque Special” hydraulic cam with matched lifters fed by CB Dual Weber 40 IDF MX with 6” foam air filters, currently 55 idle, 130 main, 200 air correction, 32 mm venturis. 27in General Grabber AT2 All Terrains, Berg Shifter, stock '76 exhaust HPC Ceramic Coated. 11/18/2020
View user's profile Send private message Send e-mail Yahoo Messenger MSN Messenger Instagram Gallery Classifieds Feedback
pjtaxi
pjtaxi is offline
PostPosted: Wed Oct 30, 2019 8:30 am    Post subject: Re: Wire plug Reply with quote
Thanks I’ll check. The other piece of that connection is missing. The lead comes out of a loom on driver side next to wires from backup light switch in trans
SamboSamba22
SamboSamba22 is offline
PostPosted: Wed Oct 30, 2019 8:50 am    Post subject: Re: Wire plug Reply with quote
The angle of your picture is weird, but that is the fuse connector coming from the transaxle. It is plugged into a two-spaded switch in the side of the transmission that operates your back up lights.
The other half of the connector that is missing helps saddle and contain the fuse, which has a pigtail wire that runs to the ignition coil, hot lead, terminal #15.
The Bus Barn Ltd. Co.
Oct. ’67 Double Cab (’68 Crew Cab)
[url=http://www.vw-mplate.com/mplate-44412.png]Click to view image[/URL]
March '69 Delivery (Panel Bus)
[url=http://www.vw-mplate.com/mplate-44414.png]Click to view image[/URL]
74 Thing
74 Thing is offline
PostPosted: Wed Oct 30, 2019 10:21 am    Post subject: Re: Wire plug Reply with quote
https://www.thesamba.com/vw/classifieds/detail.php?id=1819837
It is half of the fuse holder for the reverse light switch that is installed in the nosecone of the tranny-line is supposed to connect to the + side of the coil with the fuse inline.
pjtaxi
pjtaxi is offline
PostPosted: Wed Oct 30, 2019 10:30 am    Post subject: Re: Wire plug Reply with quote
Thanks everyone for all the info. This a great site for vw info. I try to figure things out with the manual and hopefully a little common sense but if that fails you guys bail me out. 👍
aeromech
aeromech is offline
PostPosted: Wed Oct 30, 2019 1:50 pm    Post subject: Re: Wire plug Reply with quote
That is a fuse holder for the back up lights but can be replaced with many other types of fuse holders
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
