Gutter drain?
JaimeH Premium Member
JaimeH is offline
PostPosted: Sat Nov 16, 2019 6:57 am    Post subject: Gutter drain? Reply with quote
In the rear corner of the rain gutter on my '78 there is a small slit. Is this supposed to be a drain? Or is this an area that needs attention before painting?
1978 Transporter 2.0 FI, BA6
Special Thanks to Razor's Customs, Boscawen, NH
alman72
alman72 is offline
PostPosted: Sat Nov 16, 2019 7:06 am    Post subject: Re: Gutter drain? Reply with quote
close to the drain location, hard to be sure. but much smaller than factory. painted or filled in the past reduced the size.
from the gallery-
Ride_On
Ride_On is offline
Yes, there's a slit drain at the rear corners, just behind the intake ears. Need them or water in the channel would only be able to exit over the top of the channel or out the front. Yours looks short/small. Since you are painting, I'd probe it to open it up to its full size.
1977 Westfalia 2.0 FI Skills EJ25 w SubaruGears 5sp
https://www.thesamba.com/vw/forum/viewtopic.php?t=687254
2018 Golf Sportwagen 4MO DSG (Dieselgated 2013 Golf Wagon TDI DSG)
JaimeH is offline
PostPosted: Sat Nov 16, 2019 8:50 am    Post subject: Re: Gutter drain? Reply with quote
Thank for the quick responses.
