Uneven wear on rear drum.
Adriel Rowley
Adriel Rowley is offline
PostPosted: Mon Feb 03, 2020 7:57 pm    Post subject: Uneven wear on rear drum. Reply with quote
Pulled the right rear drum to find a lip of about a millimeter and a half on one side tapering to no lip on the opposite side (other side different brand drum and has no lip all the way around). What would cause this uneven wear?
The drum is stamped made in Japan and has no oil passage. Should the drum be replaced?
Thank y'all in advance! Smile
Please consider I am Autistic, so I process information differently and still working on social skills. Thanks.
Dad's 1964 Beetle purchased September 1968.
https://www.thesamba.com/vw/forum/viewtopic.php?p=9252810#9252810
1971 Sunroof Squareback with Fuel Injection
http://www.thesamba.com/vw/forum/viewtopic.php?t=219811&highlight=squareback+rejuvenation
vwoldbug
vwoldbug is offline
PostPosted: Mon Feb 03, 2020 9:29 pm    Post subject: Re: Uneven wear on rear drum. Reply with quote
Can you get a picture, do the brakes pulsate . The drum may be savable, it's tough to find good new brake drums.
Adriel Rowley
PostPosted: Mon Feb 03, 2020 9:37 pm    Post subject: Re: Uneven wear on rear drum. Reply with quote
Tried to get a picture unsuccessfully, any tips?
Not sure if pulses, hasn't been on the road since 2002 or 2003. Drums are available new. Consider rather be safe then risk, why replaced all the hard lines as were rusty and didn't want to risk a leak on a single circuit system (have lost the rear going down a grade and wasn't fun). Now that think about it, wonder if could mount it on the axle and check the exterior and interior runout? Been meaning to invest in a guage as need for setting front bearings on another vehical. Just a thought...
RWK
RWK is offline
PostPosted: Tue Feb 04, 2020 4:30 am    Post subject: Re: Uneven wear on rear drum. Reply with quote
are the rubber lines new? old lines will cause shoe dragging, insides degrade and act as a check valve, after replacing several sets of shoes, while bleeding the brakes again i noticed the line bulging while assistant was pumping the pedal.
73 Type 181
63 Type 113
63 Type 261- 428 071
62 Type 241-378 025 178 530
Eric&Barb
Eric&Barb is offline
PostPosted: Tue Feb 04, 2020 8:30 pm    Post subject: Re: Uneven wear on rear drum. Reply with quote
Would guess the tool/spindle the drum was installed on to lathe the inner diameter at the factory was somehow off. Maybe a metal chip stuck in the dead/live center end. Would not worry about it, now that it has been trued up with the actual brake shoes.
In Stereo, Where Available!
Adriel Rowley
PostPosted: Thu Feb 06, 2020 8:05 pm    Post subject: Re: Uneven wear on rear drum. Reply with quote
Well, got the drum on, and where the high spot is, even with the shoes all the way in, rubs. What you make of that?
mukluk
mukluk is offline
PostPosted: Thu Feb 06, 2020 8:36 pm    Post subject: Re: Uneven wear on rear drum. Reply with quote
Are the shoes not sitting square to the backing plate?
Is the backing plate bent?
How well do the ends of the shoes fit in the slots in the adjusters and wheel cylinders?
Adriel Rowley
PostPosted: Sun Feb 23, 2020 1:32 pm    Post subject: Re: Uneven wear on rear drum. Reply with quote
I somehow missed this reply until attempting to combine the threads per feedback into the build thread (https://www.thesamba.com/vw/forum/viewtopic.php?p=9283462#9283462), how about replying there?
In summery, all seems to fit, so once driving, will keep a feel for pulsations, then will replace the rear drums.
toxicavenger70
toxicavenger70 is offline
PostPosted: Sun Feb 23, 2020 1:42 pm    Post subject: Re: Uneven wear on rear drum. Reply with quote
Are the pads evenly adjusted?
