Camshaft prelube
liquidrush
liquidrush is offline
PostPosted: Fri Feb 07, 2020 12:43 pm    Post subject: Camshaft prelube Reply with quote
We used to use GM EOS in V8's for cam break in, is there anything specific for the VW engines you recommend? Is the procedure the same? We used to run em up between about 1800 and 3000 for 20 or so minutes while varying the rpms between those ranges and changing the oil and filter after the first run. Also, on the CB performance oil pump that has the spin on oil filter cover, is that a PH8A type filter that it takes? I was gonna buy a couple for engine run in.
Dale M.
Dale M. is offline
PostPosted: Fri Feb 07, 2020 1:14 pm    Post subject: Re: Camshaft prelube Reply with quote
The cams I have uses all came with its own little "pot" of lube with no name or numbers so can't recommend lube ...
Probably 2000 RPM for 20 minutes is what others are going to say....
Oil pump cover should take anything that is 3/4 X 16 threads....
Prefer WIX or NAPA brand filter over Fram... But then everyone has own opinion of what is best filter...
Dale
Howard 111
Howard 111 is offline
PostPosted: Fri Feb 07, 2020 3:25 pm    Post subject: Re: Camshaft prelube Reply with quote
Hold the PH8A in one hand, and anyone else's in the other, and the difference is amazing. I wouldn't use any Fram filter on any car these days. They use to be THE filter, but I think China bought them out.
1973 Karmann Ghia
Turbocharged, Fuel Injected
http://www.thesamba.com/vw/forum/viewtopic.php?t=531270
jeffrey8164
jeffrey8164 is offline
PostPosted: Fri Feb 07, 2020 3:39 pm    Post subject: Re: Camshaft prelube Reply with quote
CB will send you a Mahle 83a.
I did the same thing and ordered four oil filters and sump gaskets to go through all the break in maintenance.
There are many assembly lube products.
I’ve never been let down with the Permatex brand of anything.
Volkswagen!
(Compression 8.7:1)
67rustavenger
67rustavenger is offline
PostPosted: Fri Feb 07, 2020 3:51 pm    Post subject: Re: Camshaft prelube Reply with quote
http://www.cam-shield.com/acatalog/CamShaft_Assembly_Paste.html
Works for me!
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
volksworld
volksworld is offline
PostPosted: Fri Feb 07, 2020 7:47 pm    Post subject: Re: Camshaft prelube Reply with quote
cam break in is cam break in....usual techniques apply...whatever break in lube you decided to use should have been applied to the cam and lifters at the time of assembly...if you didnt use anything at all some EOS and high zddp oil would be a lot better than nothing
slalombuggy
slalombuggy is offline
PostPosted: Fri Feb 07, 2020 8:32 pm    Post subject: Re: Camshaft prelube Reply with quote
I use CamShield on the lobes and lifter faces. For oil I use Lucas Hot Rod & Classics with the proper amount of zinc already in it. I used to use EOS but now I just get oil with zinc
brad
jason
jason is offline
PostPosted: Sat Feb 08, 2020 9:14 am    Post subject: Re: Camshaft prelube Reply with quote
Never understood the cam lube. It wipes off after like two revolutions.
Dan Ruddock
Dan Ruddock is offline
PostPosted: Sat Feb 08, 2020 9:58 am    Post subject: Re: Camshaft prelube Reply with quote
Me too, this is why I like to overfill the case with enough oil to bathe the cam.
Dan
slalombuggy
PostPosted: Sat Feb 08, 2020 1:06 pm    Post subject: Re: Camshaft prelube Reply with quote
There's still a film of lube even after a few revolutions and that's all it takes. Better a film of lube than metal on metal.
brad
nsracing
nsracing is offline
PostPosted: Sat Feb 08, 2020 3:32 pm    Post subject: Re: Camshaft prelube Reply with quote
I use the Permatex assembly lube -red color...for cam /lifter face lube, valve stems and tips. All else gets the 30W oil for assembly. Worked for me for years.
