Big brake disks 312mm Audi A6
Italjohn
Italjohn is offline
PostPosted: Wed Mar 18, 2020 5:05 am    Post subject: Big brake disks 312mm Audi A6 Reply with quote
Just got my new 312mm Audi A6 brake disks, that I will use on my vanagon.
I have the needed Epytec spindle/adapter, so now I'm waiting for some warmer weather Very Happy
Link to Epytec https://bit.ly/3b6YPrz
Follow me on facebook: https://www.facebook.com/norwayvanagon
My youtube channel: https://www.youtube.com/c/Italjohn
Instagram: https://www.instagram.com/italjohn/
View user's profile Send private message Visit poster's website Facebook Instagram Classifieds Feedback
Steve M.
Steve M. is offline
PostPosted: Wed Mar 18, 2020 5:08 am    Post subject: Re: New brake disks 312mm Audi A6 Reply with quote
Better not use them. There too pretty to scratch! Laughing
Are you putting them on a 2wd or Syncro?
Jake de Villiers
Jake de Villiers is offline
PostPosted: Wed Mar 18, 2020 8:17 am    Post subject: Re: New brake disks 312mm Audi A6 Reply with quote
Very nice! I'm just in the process of getting a set of adapters to put those A6 discs on the front of my van.
I'm currently running the 288mm discs but - bigger is better! Very Happy
What are you going to use for pads? I had EBC Yellowstuff which were slow to bite when cold, then absolutely terrific. Currently running Akebono which are not nearly as good...
I'm planning to go with the Redstuff with the new discs.
'84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com
Jake de Villiers
PostPosted: Wed Mar 18, 2020 8:18 am    Post subject: Re: New brake disks 312mm Audi A6 Reply with quote
Not that I know very much about them but I thought that Syncros already had the separate hubs?
www.thebassspa.com
Italjohn
Italjohn is offline
PostPosted: Thu Mar 19, 2020 12:55 am    Post subject: Re: New brake disks 312mm Audi A6 Reply with quote
I have a 2wd
Italjohn
Italjohn is offline
PostPosted: Thu Mar 19, 2020 1:11 am    Post subject: Re: New brake disks 312mm Audi A6 Reply with quote
I did order this Very Happy
Jake de Villiers
PostPosted: Thu Mar 19, 2020 8:16 am    Post subject: Re: New brake disks 312mm Audi A6 Reply with quote
I'll be interested to hear your thoughts on those pads after some miles. Your van is going to stop a LOT better!
www.thebassspa.com
Italjohn
Italjohn is offline
PostPosted: Fri Mar 20, 2020 5:34 am    Post subject: Re: New brake disks 312mm Audi A6 Reply with quote
The 312mm Audi A6 brake discs and the ATE 57 caliper fits nicely into the 16" Mercedes CLK rims.
bobbyblack Premium Member
bobbyblack is offline
PostPosted: Fri Mar 20, 2020 7:30 am    Post subject: Re: New brake disks 312mm Audi A6 Reply with quote
Very well done video showing the new hardware, and also the video of rebuilding the calipers from VW Sharan. I am glad you have been able to source all these parts from Norway!!
For those of us in North America, are there any folks over here familiar with sourcing these parts, kits, and perhaps what Makes/Models of VW/Audi/etc those calipers would be sourced from? There is a Pull-A-Part (Junk Yard) I frequently visit, perhaps I could keep a list of vehicles to grab these calipers from.
I am looking forward to the next video or two of how you install these. Keep us posted!!
-bobby
Jac25
Jac25 is offline
PostPosted: Fri Mar 20, 2020 8:09 am    Post subject: Re: Big brake disks 312mm Audi A6 Reply with quote
I just ran the part numbers on rockauto looks everything is available.
https://epytec.de/en/brake-system/adapters/2015/vw...RCjh04ZUqQ
Brake Rotors Audi A6 z.B. 4B0 615 301 A
https://www.rockauto.com/en/partsearch/?partnum=4B0+615+301+A
Calipers Audi 100/A6 C4 calipers Girling / ATE part No. 57: 4A0615123A and 4A0615124A
https://www.rockauto.com/en/partsearch/?partnum=4A0615123A+
garbaldie
garbaldie is offline
PostPosted: Fri Mar 20, 2020 8:12 am    Post subject: Re: New brake disks 312mm Audi A6 Reply with quote
-bobby
I've got the Syncro version of these Epytec adapters, calipers for this kit can be sourced from an B5/5.5 Passat or Audi A4 with 288mm brakes.
DigiMatrix
DigiMatrix is offline
PostPosted: Fri Mar 20, 2020 8:22 am    Post subject: Re: Big brake disks 312mm Audi A6 Reply with quote
I have been considering that set-up as well. Very interested in how you like it. Any chance you could get a measurement from the center of hub to center of caliper piston. I have built a spreadsheet to calculate the amount of improvement over stock. With a value of the Caliper mean radius estimated at 5.392" my calculations show and expected improvement of 12.4% over the stock brakes.
Jake de Villiers
PostPosted: Fri Mar 20, 2020 1:40 pm    Post subject: Re: Big brake disks 312mm Audi A6 Reply with quote
I'll just point out here that ItalJohn is installing the 312mm front discs.
I already have the 288mm discs (4B0 615 301 A ) and I'm going to use the new Epytec adapters to install the Audi A4 B6 3.0 V-6 312mm discs (8E0 615 301R) on my van, too.
My G57 calipers will carry over.
www.thebassspa.com
syncrodoka
syncrodoka is offline
PostPosted: Fri Mar 20, 2020 4:36 pm    Post subject: Re: Big brake disks 312mm Audi A6 Reply with quote
What proportioning valve are you running? What do you have in the rear?
Italjohn
Italjohn is offline
PostPosted: Wed Mar 25, 2020 2:41 am    Post subject: Re: Big brake disks 312mm Audi A6 Reply with quote
I really don't know if there is an proportioning valve on my 2wd vanagaon?
If there is one, I was hoping to use it as it is.
I will upgrade the rear brakes to discs as well, but will concentrate on the front first. Will use these calipers together with the epytec kit for the rear. The challenge will be the parking brake.
https://smallcar.com/rear-brake-instructions.html
Steve M.
Steve M. is offline
PostPosted: Wed Mar 25, 2020 5:03 am    Post subject: Re: Big brake disks 312mm Audi A6 Reply with quote
Yep! It is on the passenger side/right side. Follow the hard brake line from the right front wheel and it will be mounted on the inside of the forward chassis structure. (If memory serves me correct!) Or close to it. Usually covered in road gunk.
Italjohn
Italjohn is offline
PostPosted: Wed Mar 25, 2020 7:36 am    Post subject: Re: Big brake disks 312mm Audi A6 Reply with quote
It's approx. 13cm
Italjohn
Italjohn is offline
PostPosted: Wed Mar 25, 2020 7:40 am    Post subject: Re: Big brake disks 312mm Audi A6 Reply with quote
Got my new EBC yellow stuff brake pads today Very Happy
DigiMatrix
PostPosted: Fri Mar 27, 2020 6:26 pm    Post subject: Re: Big brake disks 312mm Audi A6 Reply with quote
Italjohn wrote:
It's approx. 13cm
Thanks for the info - I appreciate you taking the time.
blee
blee is offline
PostPosted: Wed Apr 15, 2020 7:43 am    Post subject: Re: Big brake disks 312mm Audi A6 Reply with quote
what was needed to prep the hub for bearings? are they already set up for them?
