Bunky67 Samba Member
Joined: July 05, 2012 Posts: 142 Location: SW Michigan
Posted: Mon Apr 06, 2020 8:16 am Post subject: drop spindles or stock ? |
I have a 67 Beetle and I dropped the front with drop spindles and an adjustable beam. I have the beam cranked all the way up and with the girlfriend and I in the car were bottoming out quite often. Oh and I have smart car tires on the front as well.
I'm thinking I want to put stock spindles back on and just lower the beam some.
Anyone have suggestions? |
Joined: August 31, 2013 Posts: 13289 Location: North Carolina
Posted: Mon Apr 06, 2020 8:45 am Post subject: Re: drop spindles or stock ? |
Bunky67 wrote: |
I have the beam cranked all the way up and with the girlfriend and I in the car were bottoming out quite often. |
Don't do that sort of thing in the Beetle.  _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
andrewda Samba Member
Joined: September 26, 2018 Posts: 54 Location: Middletown, NJ
Posted: Mon Apr 06, 2020 10:57 am Post subject: Re: drop spindles or stock ? |
Depending on the condition of your whole suspension setup, lowering the car does make the ride a bit harsher. I would go with stock spindles and an adjustable beam. But before you go back, what is the condition of your shocks and torsion bars? Worn out shocks are not as good as fresh good quality ones |
toxicavenger70 Samba Member
Posted: Mon Apr 06, 2020 12:31 pm Post subject: Re: drop spindles or stock ? |
Bunky67 wrote: |
you should do it at home or in a van. |
Acab77 Samba Member
Joined: August 09, 2015 Posts: 104 Location: Edgwood, WA
Posted: Mon Apr 06, 2020 12:55 pm Post subject: Re: drop spindles or stock ? |
toxicavenger70 wrote: |
Bunky67 wrote: |
 _________________ SOLD '67 Beetle, "Rose"
SOLD '71 Super Beetle
'64.5 Ford Mustang
'67 Datsun Roadster
'72 Chevy LUV |
Sharp64 Samba Member
Joined: August 27, 2015 Posts: 5304 Location: Central Florida
Posted: Mon Apr 06, 2020 6:25 pm Post subject: Re: drop spindles or stock ? |
Define “bottoming out”. Are the fenders rubbing on the tires? Are the tires hitting the headlight buckets? Or are the shocks bottoming out? _________________ 1960 Indigo Blue Ragtop (Blue Barry)
1967 Ghia
1985 Westy Money Pit
“...some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn.” - Michael Caine |
61SNRF Samba Member
Joined: March 29, 2009 Posts: 4656 Location: Whittier 90602
Posted: Tue Apr 07, 2020 7:38 am Post subject: Re: drop spindles or stock ? |
Stock a BJ beam has about ~4" of travel.
Wth an adjustable beam and stock spindles you lose some of that travel when you lower it.
When you do get it adjusted to where you like the look you will probably need to use short shocks too.
This combo makes for a bouncy ride and can often bottom out too.
If you just want a ~2-2.5" drop using the stock beam with dropped spindles will give you the best ride because you maintain the stock travel and shocks. _________________ -Bruce
An ounce of prevention is worth a pound of cure. |
robert hogaboam Samba Member
Posted: Thu Apr 09, 2020 8:55 pm Post subject: Re: drop spindles or stock ? |
I used 2.5 inch drop spindles and stock suspension with new shocks. I run stock tires and no rub on my 67. The 63 has a adjustable beam and drop spindles. Running widened Porsche steel wheels and bigger than stock wheels. Rubs and rides much worse. But the look is better for this car.
