vwy2k Samba Member
Posted: Sat Apr 11, 2020 3:43 pm Post subject: 1957 Bus Lowering Airkewld complete Kit Questions |
Hi
Does anyone have experience using this kit?
Does it include everything you need? one of the videos it says i have to replace the rear brakes for the kit. is that true?
Is the transmission included in the kit top quality? I do plan on getting welded gears and super diff
I am buying a new 2110 engine. Should i upgrade any of the below items?
steel shift forks
chromoly axles
Heavy duty side plates
New Erco/Weddle gears
upgraded case _________________ 1957 Bus ongoing restoration |
chrisflstf Samba Member
Joined: February 10, 2004 Posts: 4159 Location: San Diego
Posted: Sat Apr 11, 2020 5:27 pm Post subject: Re: 1957 Bus Lowering Airkewld complete Kit Questions |
Ask the seller, start there. |
vwy2k Samba Member
Posted: Sat Apr 11, 2020 5:32 pm Post subject: Re: 1957 Bus Lowering Airkewld complete Kit Questions |
They are closed on the weekend and I want to buy tomorrow because they have 10% off till tomorrow or I would... _________________ 1957 Bus ongoing restoration |
flemcadiddlehopper Samba Member
Joined: December 05, 2011 Posts: 2345 Location: Kelowna, BC. Canada.
Posted: Sat Apr 11, 2020 5:56 pm Post subject: Re: 1957 Bus Lowering Airkewld complete Kit Questions |
Whoa there...you have got a shit tonne of questions all wrapped up into one post that has nothing to do with the product you have in the title.
Let's start with the welded gears bit. Welded gears are for drifters or 4x4ers, and it's either welded gears or a super diff. So, if you ever plan on driving this bus around a corner without burning rubber? ...go with the super diff.
Now as far as all of the other stuff goes, it all depends on how you answered that last question.
As far as I know Airkewld sells suspension and brakes and it looks like good stuff. If I was to bag a bus and swap to disk brakes at the same time, getting it all from one supplier would be the way to go.
Just my humble opinion, Gordo. _________________ Everybody Dies....Some Never Live.
Retrograde Garage. Vintage Aircooled, and others. |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 53053 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sat Apr 11, 2020 6:21 pm Post subject: Re: 1957 Bus Lowering Airkewld complete Kit Questions |
vwy2k wrote: |
..... I want to buy tomorrow because they have 10% off till tomorrow or I would... |
Buying before doing some serious research with the vendor (as well as here) will always cost you way more than 10%, don't get conned into a panic buy, take your time and figure out just what you need, what's included and what's effected by installing it.
There will be other sales in the future, take your time and avoid buying something you don't really need/want. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
vwy2k Samba Member
Posted: Sat Apr 11, 2020 7:14 pm Post subject: Re: 1957 Bus Lowering Airkewld complete Kit Questions |
Great looks like a nice kit. And, not that I would want to knock any business that is out there putting together a kit like this, but... If you have the ability to install this kit yourself, you should be able to do the majority of what this kit is. A straight axle swap (reduction box delete/ring gear flip) and a spindle flip (link pin relocate and weld support). Things needed to buy for this is much less than that whole kit. I know profit is not a dirty word, but for me, my time is worth way less than that price tag.
vwy2k Samba Member
Posted: Sat Apr 11, 2020 8:04 pm Post subject: Re: 1957 Bus Lowering Airkewld complete Kit Questions |
I do have the ability owning a custom welding fabrication shop but the time it would take me to do this I think it is worth it to have them do it and get it done right the first time....
I will be installing everything myself _________________ 1957 Bus ongoing restoration |
BarryL  Samba Member
Joined: November 01, 2004 Posts: 15364 Location: Casa de Oro, California
Posted: Sun Apr 12, 2020 6:42 pm Post subject: Re: 1957 Bus Lowering Airkewld complete Kit Questions |
vwy2k wrote: |
steel shift forks
upgraded case |
Welded 3rd and 4th is a good idea as it keeps the gear syncro hub from separating from the gear. Pic borrowed from mcmscott.
Super diff makes 4 spider gear contacts instead of 2 so much stronger.
Steel shift forks are a must. Most bus trannys already have them.
Stronger side covers help as there is force trying to blow the crown gear side out that side. Stronger-longer side cover studs, too.
Upgraded case could be anything from Rhino to specialty like Mendeola, Albins, Weddle, Auto-Craft. |
67_SO42 Samba Member
Joined: August 27, 2006 Posts: 672 Location: Germany via Arizona
Posted: Mon Apr 13, 2020 5:02 am Post subject: Re: 1957 Bus Lowering Airkewld complete Kit Questions |
Them airkewld boys make quality stuff. Have good support too.
I dunno who is building their transmissions but you could probably use their Instagram to get ahold of Pete there and ask.
I’ve bought their bug air kit a long time ago and was happy with it. _________________ 58 Binz DC #151 "Nacho"
65 Swedish, Westfalia 400 trailer "Melania"
57 Binz scooter “Micha” |
vwy2k Samba Member
Posted: Mon Apr 13, 2020 5:24 am Post subject: Re: 1957 Bus Lowering Airkewld complete Kit Questions |
Thanks for all the input. I bought the kit last night. I will report back once I have it installed. _________________ 1957 Bus ongoing restoration |
orangebug60guy Twin #1
Joined: June 28, 2003 Posts: 1517 Location: South Hadley Mass
Posted: Mon Apr 13, 2020 5:50 am Post subject: Re: 1957 Bus Lowering Airkewld complete Kit Questions |
 _________________ Arachibutyrophobia- Fear of peanut butter sticking to the roof of the mouth.
Coprastasophobia- Fear of constipation. |
teahead Samba Member
Joined: October 30, 2019 Posts: 326 Location: Seattle
Posted: Mon Apr 13, 2020 11:12 am Post subject: Re: 1957 Bus Lowering Airkewld complete Kit Questions |
I would have gone IRS if removing RGBs. That's my plan. _________________ '63 German Walk-Thru Deluxe 15-window - SOLD |
FreddyWanKenobi Samba Member
Joined: June 06, 2020 Posts: 36 Location: Pomona California
Posted: Sat Jul 11, 2020 10:30 am Post subject: Re: 1957 Bus Lowering Airkewld complete Kit Questions |
vwy2k wrote: |
Thanks for all the input. I bought the kit last night. I will report back once I have it installed. |
Just curious do you have any updates? |
