engine tuning, 34 PICT questions??
tkgeorge_99
tkgeorge_99 is offline
PostPosted: Fri May 08, 2020 9:32 am    Post subject: engine tuning, 34 PICT questions?? Reply with quote
So I recently replaced the original, yes the original 1500 SP engine out of my bus. Its a 67 Brazilian. I was given a "new" 1600 DP a few years ago from a friend of a friend that has been sitting around in my shop. The clutch was slipping on old engine and it was time to swap it out.
So I put in new engine and ordered a new 34 PICT 3 EMPI carb. I know EMPI... but it has quite a few good reviews about running right out of box. Anyways, short story is I couldn't get it to idle so I took it to my trusty vw shop. They messed with it a bit ( 3 hours)and still can't get it tuned right. They put in slightly bigger jets but it still wan't to die when idling. I suspect it has a dished cam as it has that "stumble" idle going on. It has 009 distributor and is timed at just a few degrees before tdc. Shop didn't seem to thing it was a distributor or timing issue but I don't know. The shop did smoke test for vacumm leaks and says all good. Its also hard to start when cold. I have to floor it and let it crank for a little bit. Upside, is that on the road its peppy and runs strong with plenty of power. Once its well warmed up it will idle but still wants to die when I come to stop unless I rev it up a little and then it will settle into an idle. Its idling right at 900 rpm. The shop is good and I watched the mechanic mess with it so I am not sure what to do next
I am frustrated and at a loss. If the mechanic can't get it to work and is basically out of options, what next? I thought about making sure auto choke is adjusted properly, which I will check. I just want it to fire up when I turn the key and not die at stop lights! Anyone's thoughts???
andk5591
andk5591 is offline
PostPosted: Fri May 08, 2020 10:24 am    Post subject: Re: engine tuning, 34 PICT questions?? Reply with quote
The Empi 34 is fine. I have installed quite a few and keep at least one in stock for someone that doesnt need a rebuilt Solex. The carb comes with detailed set up instructions that MUST be followed. If you threw them out, go through this.
http://vw-resource.com/34pict3.html
You need to set the choke stepped cam adjuster properly, then you go through the adjustment screws. Usually the jetting they come with is fine.
If all that is good and done, verify the idle cut off solenoid is working properly...in fact, do that first, because if it isnt, you can't tune it.
I have never done a smoke test for vac leaks, but they must use it successfully.
We are also assuming that they verified the choke operation.
And your 009 is ONLY is to be timed at full advance (28-32 degrees), which usually puts idle between 5 and 12 degrees.
D-Dubya Manx clone 1914. Ex wifes car.
Maxine 61 Cal-look bug - Ex-wifes car.
There's more, but not keeping them...
Who.Me?
Who.Me? is offline
PostPosted: Fri May 08, 2020 10:40 am    Post subject: Re: engine tuning, 34 PICT questions?? Reply with quote
I chased ghosts in my engine trying to get it to idle. I tried solex and empi carbs, but the problem persisted. (hard starting, rough idle, but ran great at high revs)
Eventually I pulled the engine apart and found that it had an engle w110 cam in it. Apparently they're a nightmare to get to idle correctly with a single carb.
I'm replacing it with a stock cam.
Pull the oil pump and look for makings on the face of the cam. Aftermarket cams are often marked and you can read the type through the oil pump hole.
Loosen the case bolts nearest the pump and use an oil pump puller to extract the pump without damaging the case. You don't need to drain the oil, or pull the engine, but you need to remove the valance panel, rear tin, pulley and pulley tin. Takes about an hour and you'll know one way or the other.
Andy
Looking for info on my truck's history. Are you from Campbell California or nearby. Do you recognise it? ... http://www.thesamba.com/vw/forum/viewtopic.php?t=636786
tkgeorge_99
PostPosted: Fri May 08, 2020 10:50 am    Post subject: Re: engine tuning, 34 PICT questions?? Reply with quote
thanks for replies. Yes I have instructions and actually took them with me to shop and reviewed them with mechanic. He agrees with them and followed them best he could. I still need to check choke position and I will check idle cut off. How do I check idle cut off?
I really think carb is adjusted best it can be... I am hoping its might be choke position. I don't think its idle cut off because it does idle, just not very well. Especially when cold but once its warmed up it will hold idle but just wants to die when coming off throttle. It actually does better if I let off throttle abruptly instead of down shifting to a stop.
I suspect it has engle w110 cam..... mechanic suspects a non stock cam as well. It has same symptoms as described... hard starting, rough idle... but runs great at higher revs. Wondering if anyone has had any success with working through issue with keeping engle w110 cam in engine? Dual carbs? Running out of money on project and just want to have it start in morning and run with out dying at the stoplights....
I appreciate comments and any further suggestions
Who.Me?
Who.Me? is offline
PostPosted: Fri May 08, 2020 11:36 am    Post subject: Re: engine tuning, 34 PICT questions?? Reply with quote
Was the engine a new build or bought used? If it's a new build, ask the builder what cam they used.
If the engine is new, or you know that it's sound and you can confirm that it has a W110 or similar cam, I'd look in to dual carbs.
I only looked at dual carbs briefly, but the kits weren't exactly cheap, so if you don't know the engine's history, I'd ask your garage to check the engine's health before throwing money at it. Get them to check that the crank end float is within spec, no metal flakes in oil, good compression etc., or do those checks yourself.
If the engine turns out to be worn out; it'll need a rebuild/exchange anyhow. Not cheap, but you could then go with a stock profile cam.
Andy
tkgeorge_99
PostPosted: Fri May 08, 2020 12:08 pm    Post subject: Re: engine tuning, 34 PICT questions?? Reply with quote
I wish I knew more history on engine. It is a new rebuild, it came with the used bearings in the boxes of the new bearings. I did compression test, all 100+ psi. I think the engine is good, just not sure of what cam is in it. No way to check with original builder. I was told its got less than 1000 mile on it.
I'm guessing dual carb set up is $500 ish? anyone have any suggestions on a good reliable set up?
turkis-deluxe
Samba Security
turkis-deluxe is offline
PostPosted: Fri May 08, 2020 2:05 pm    Post subject: Re: engine tuning, 34 PICT questions?? Reply with quote
For a stock motor even with a 110 a set of Kadron's should do you fine. Just need to make sure you get them rebuilt properly. They take very little adjustment and is not overkill. Anything larger with stock heads you're likely to have more issues.
Before going down this path though you should really find out as much as you can about the motor.
tkgeorge_99
PostPosted: Fri May 08, 2020 2:50 pm    Post subject: Re: engine tuning, 34 PICT questions?? Reply with quote
I have a set of kadrons on my Baja bug. They have been great. I may have to explore that option
Can anyone explain why dual carbs will help over single?
andk5591
andk5591 is offline
PostPosted: Fri May 08, 2020 4:11 pm    Post subject: Re: engine tuning, 34 PICT questions?? Reply with quote
if you cant get it to run with a single, not sure why you would be able to get it to run with duals....Just sayin.....I cant say I know first hand if you have the cam that you may suspect would kill idle, so keep that in mind....
And you have redone the timing, correct? Set at max advance....And for shits an giggles, swapping the distributor might be worth trying. I have had an 009 that the advance was way messed up and also had them where it was stuck...Takes 5 minutes.....and you can rule that out....BUT I assume that they are confirming its advancing properly....BUT concerned that they are timing it at idle...
turkis-deluxe
Samba Security
PostPosted: Fri May 08, 2020 4:42 pm    Post subject: Re: engine tuning, 34 PICT questions?? Reply with quote
As Ank5991 commented if you have other issues changing carbs won't help. Need to make sure basic things like timing and valves are all set first before messing with carbs. If those are correct then carb could be bad.
Dual Kadrons will get you more HP out of the motor. I run them on my Westy due to the added weight and it's a huge help and also my deluxe just for the hell of it.
wcfvw69
Samba Purist
wcfvw69 is offline
PostPosted: Fri May 08, 2020 4:58 pm    Post subject: Re: engine tuning, 34 PICT questions?? Reply with quote
My bus had a brand new EMPI 34-3 carb on it when I bought it a few years back. It ran and idled terrible. Curious, I went to see if I could adjust it to work correctly. I took it all apart and was horrified with the build quality and poor tolerances of the carb and it's parts. I couldn't get it to run correctly nor idle.
I had already sent a German Solex to [email protected] to install new throttle shaft bushings. I got that carb back, finished rebuilding it with a new kit and put it on. It adjusted nicely and with a slightly bigger pilot jet, it idled beautifully.
Some folks have luck with EMPI carbs or products. Personally, I avoid them and all the Chinese VW parts as most are terrible. Most veterans of this site simply send their original German Solex carbs to Tim who makes them like new again.
Check out Tim's site.
The Samba member since 2004.
tkgeorge_99
PostPosted: Fri May 08, 2020 5:38 pm    Post subject: Re: engine tuning, 34 PICT questions?? Reply with quote
Thanks to all who have chimed in. I will go back through the basics as suggested. I'll recheck valves. Check auto choke. Change fuel filter.
Vw shop checked timing. Says it's a few degrees BTC and advancing properly. They had carb apart and cleaned jets and then re jeted it. I would hope they would have noticed if things were messed up.
I figure it's just down to basics of fuel, air, and timing. I'm just at a loss that the professionals can't seem to figure it out. I'm a part time wrench turnedr but I'm trusting the experts and they seem baffled.
I'm not opposed to trying dual kadrons but don't want to spend additional $500 to find I have same problem. At this point I'm trying not to throw good $ after bad. I guess I'm just frustrated. I do most of my own work and mess stuff up all the time due to ignorance and lack of experience but I always figured if I ponied up $ and went to shop, they should be able to fix it. They spent 3 hours on it, so I would think they could figure it out.
Still open to anymore thoughts or suggestions
wcfvw69
Samba Purist
wcfvw69 is offline
PostPosted: Fri May 08, 2020 6:25 pm    Post subject: Re: engine tuning, 34 PICT questions?? Reply with quote
Be mindful that there's not a worse miss-match of carb/distributor than a 34-3 carb and a mechanical only 009 distributor. There's thousands of threads about the dreaded "flat spot" or off idle hesitation with that combo.
You'd be much better off replacing the mechanical only 009 with an SVDA distributor. It cures any flat spots and provides a much better driving experience.
earlywesty
earlywesty is offline
PostPosted: Sat May 09, 2020 8:10 am    Post subject: Re: engine tuning, 34 PICT questions?? Reply with quote
As has been said multiple times...Check and re-check everything yourself, do not trust the 'expert shop' got it right. Their timing method does not instill confidence. Get rid of the 009, it's a poor match for any 34pict3. Get a properly restored SVDA distributor from the above quoted poster and send a proper german Solex to Tim for a rebuild. Make sure your fuel pump is providing correct fuel pressure as well. Ensure valves are set correctly, is the exhaust in good condition with no holes? Makes a difference. With all of these items in good condition, follow the correct setup/tuning procedure to a tee. It should work well and be good for a very long time. That will be money well spent, as opposed to throwing money at dual carbs and hoping it fixes it.
tkgeorge_99
PostPosted: Sat May 09, 2020 9:04 am    Post subject: Re: engine tuning, 34 PICT questions?? Reply with quote
sound advice. I will locate a SVDA distributor and re check everything. Hopefully, that will fix my troubles. Like I mentioned, I'm not trying to squeeze performance or power out of engine, I just want it to start when I turn the key and not kill at the stop lights.
Quick question about timing. It is a newer mexican case... I have it timed at a few degrees BTC static timing. I am not sure if this in correct. I know some cases are 8 BTC , 0 TDC and * ATDC. I use the old school John Muir method of timing. Since I wasn't sure of exact timing, I decided that right around TDC would be best.
wcfvw69
Samba Purist
wcfvw69 is offline
PostPosted: Sat May 09, 2020 9:24 am    Post subject: Re: engine tuning, 34 PICT questions?? Reply with quote
There's a bunch of different "009" out there today. German, Brazilian, China, etc. The best way to set the timing on any 009 is to rev the engine to 2800 RPM. Let the distributor reach full mechanical advance. Set the all in or advanced timing to 28-30* BTDC and let the idle timing fall where it may.
tkgeorge_99
PostPosted: Sat May 09, 2020 9:54 am    Post subject: Re: engine tuning, 34 PICT questions?? Reply with quote
sounds good. I will get a timing light. If I switch to a SVDA is the procedure similar?
BarryL Premium Member
BarryL is offline
PostPosted: Sat May 09, 2020 11:49 am    Post subject: Re: engine tuning, 34 PICT questions?? Reply with quote
As others have asked are you certain your idle cutoff is electrically functional?
tkgeorge_99
PostPosted: Sat May 09, 2020 12:00 pm    Post subject: Re: engine tuning, 34 PICT questions?? Reply with quote
it has power at the connection with ignition on... how else would I check it? It idles okay once warmed up, with a bit of a stumble, when it seems to die is when I am coming to a stop after driving. Maybe I don't understand symptoms of idle cutoff malfunction but it doesn't seem to be that.
I searched several threads on timing with SVDA, so I think I have that covered now.
BarryL is offline
PostPosted: Sat May 09, 2020 12:07 pm    Post subject: Re: engine tuning, 34 PICT questions?? Reply with quote
Take it out and when power is on touch the cutoff to the carb body and see if the plunger is retracting.
