195 tires on a 4.5 rim?
Kafer Wolf
Kafer Wolf is offline
PostPosted: Fri Jun 05, 2020 6:22 am    Post subject: 195 tires on a 4.5 rim? Reply with quote
Will it work?
How would it handle?
Will I damage the tire in the long run?
Jimbug57
Jimbug57 is offline
PostPosted: Fri Jun 05, 2020 6:31 am    Post subject: Re: 195 tires on a 4.5 rim? Reply with quote
I've run 205x70x15's with stock wheels on the back many times with no issues.
Go to the tire shop and have one of the 195's mounted, and ask them what they think.
Use this calculator to make sure the sidewall height keeps the diameter close to stock - you didn't give the whole tire size in your post.
The only issue i can see is rubbing in tight turns on the fronts.
https://www.miata.net/garage/tirecalc.html
Repeat after me "I am smarter than metal!"
Kafer Wolf
PostPosted: Fri Jun 05, 2020 7:06 am    Post subject: Re: 195 tires on a 4.5 rim? Reply with quote
Sorry.
I'm looking at 195 65 r15
H2OSB
H2OSB is offline
PostPosted: Fri Jun 05, 2020 7:51 am    Post subject: Re: 195 tires on a 4.5 rim? Reply with quote
I'd dew eet.
H2OSB
(o\_i_/o) Funny thing about pigs, they're cleaner than you and me. Well....you.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Fri Jun 05, 2020 7:53 am    Post subject: Re: 195 tires on a 4.5 rim? Reply with quote
Should be on a 5.5 rim, But sure, you can mount them on 4.5"
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Kafer Wolf
PostPosted: Fri Jun 05, 2020 9:30 am    Post subject: Re: 195 tires on a 4.5 rim? Reply with quote
This is what I've heard. 195's on 5.5's
But I'm wondering how the ride quality or durability would be on 4.5's
TDCTDI
Samba Advocatus Diaboli
TDCTDI is offline
PostPosted: Fri Jun 05, 2020 9:53 am    Post subject: Re: 195 tires on a 4.5 rim? Reply with quote
It's not a problem. At all. The only problem you might run into is the tire shop refusing to do it.
You might experience a little bit of "wallow" as you lean into a curve at speed as the side wall will flex a bit.
I'm running 215/75/15 on a 4.5" wheel.
Mr. 010
Glenn is offline
PostPosted: Fri Jun 05, 2020 10:00 am    Post subject: Re: 195 tires on a 4.5 rim? Reply with quote
And what would be their reason?
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Dal Churchill
Dal Churchill is offline
PostPosted: Fri Jun 05, 2020 10:13 am    Post subject: Re: 195 tires on a 4.5 rim? Reply with quote
Lack of imagination.
Mechanical dogma.
Fear of liability ... ?
Who knows how the brains of trained chimps work?
1974 Beetle. Bus/Porsche/Rover V8 (Buick 215ci) Baja. (Unfinished project)
1979 Beetle. 1641. Ex-Modern Day Luftwaffe Airfield Radio Car. (Daily driver)
raydog
raydog is offline
PostPosted: Fri Jun 05, 2020 10:17 am    Post subject: Re: 195 tires on a 4.5 rim? Reply with quote
Liability... can't really blame them now-a-days
Kafer Wolf
PostPosted: Fri Jun 05, 2020 10:31 am    Post subject: Re: 195 tires on a 4.5 rim? Reply with quote
Thanks for the replies, guys!
brando90gl
brando90gl is offline
PostPosted: Fri Jun 05, 2020 11:07 am    Post subject: Re: 195 tires on a 4.5 rim? Reply with quote
Same reason most good tire shops won’t plug anymore and only patch. Raydog said it first, liability.
67 Type 1
68 Campmobile
70 Single Cab
Dal Churchill
PostPosted: Fri Jun 05, 2020 11:45 am    Post subject: Re: 195 tires on a 4.5 rim? Reply with quote
Hah! That proves I'm fucking invisible on this site!
Mr. 010
Glenn is offline
PostPosted: Fri Jun 05, 2020 11:48 am    Post subject: Re: 195 tires on a 4.5 rim? Reply with quote
Dal Churchill wrote:
I agree Brando.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
brando90gl
PostPosted: Fri Jun 05, 2020 11:52 am    Post subject: Re: 195 tires on a 4.5 rim? Reply with quote
😄 Nope, I see you now!
Edit: Sorry! Churchill said it first.
67 Type 1
68 Campmobile
70 Single Cab
H2OSB
H2OSB is offline
PostPosted: Fri Jun 05, 2020 12:01 pm    Post subject: Re: 195 tires on a 4.5 rim? Reply with quote
Mechanical dogma.
Lol. I almost spit coffee.
Nitramrebrab72
Nitramrebrab72 is offline
PostPosted: Fri Jun 05, 2020 12:12 pm    Post subject: Re: 195 tires on a 4.5 rim? Reply with quote
I've really gone off increasing tyre size, I've found the original tyre sizes give a great feel of the road and handling, better performance, I prefer to stay as close as possible to original and use the saved money to go with a really high quality tyre.
Some of the very first 911 turbos where factory fitted with only 185s on the front, as they found it gave the best overall performance, and at the time porsche had one of the best facilities for testing tyres.
I fitted 195s on my 914 and really regretted it. I lost on agility and 0-60 and overall fun.
Jimbug57
Jimbug57 is offline
PostPosted: Fri Jun 05, 2020 2:13 pm    Post subject: Re: 195 tires on a 4.5 rim? Reply with quote
I put 4 Nexen SB802 165/80R15's on my car a year ago. They are a great tire, and I've bought many sets of tires over the last 50 years. Great in rain and snow, take massive potholes no problem, and they stick like glue in the corners.
Seriously, I can't recommend a tire more, and they are inexpensive. They are made in a brand new factory in, I think, Korea. I called the office in California and they let me talk to one of the back house people - I don't remember what his title was. They developed this tire for our cars.
I never hesitate to call the manufactures of products I buy for more information.
raydog
raydog is offline
PostPosted: Fri Jun 05, 2020 2:35 pm    Post subject: Re: 195 tires on a 4.5 rim? Reply with quote
Don't feel bad, sometimes I feel the same way!!! But I'll take the credit.
Seriously though, there seem to be a lot of tire chains, as in franchises, that have to go by "allowed" tire size vs wheel size. But just think, what if some guy gets in an accident and injures or kills someone because his new tire rolled off the rim while cornering, and it was some fat tire installed on a narrow wheel.
Kafer Wolf
PostPosted: Sun Jun 07, 2020 3:49 am    Post subject: Re: 195 tires on a 4.5 rim? Reply with quote
165 80 r15 tires are hard to find here in Manila.
The only option for this size is Nankang.
I've been using Nankang tires since I first replaced
the old tires that came with my car.
My current tires have been serving me for around 9 years now.
I changed rims and now running tubeless.
The front passenger tire keeps leaking air,
but the shop couldn't find any puncture.
Recently, the rear passenger tire went dead flat.
So I thought, it's probably best to get new tires.
Thanks again for the replies, guys!
