josh32cb Samba Member
Joined: August 28, 2011 Posts: 26 Location: Massachusetts
Posted: Fri Jun 12, 2020 11:06 am Post subject: In a pickle about tire size |
So, I have a 65 split, everything is stock height. I have 15" BRMs, bought 205/70/15 tires to have proper load ratings and safe driving abilities but they just look to damn big on there, especially with an aftermarket wheel. What would be an acceptable size tire to toss on there? I've read forum after forum about tire size and what not and I just cant seem to find an answer. Are 175/55s or 185/55s a reasonable option? Any help would be extremely appreciated. _________________ '65 Splitty- JuiceBox
'59 Ragtop- Dorothy
"Life's a beach, Dig it"! |
widehatch Samba Member
Joined: May 27, 2007 Posts: 777 Location: Memphis, TN aka The Armpit of the South
Posted: Fri Jun 12, 2020 1:14 pm Post subject: Re: In a pickle about tire size |
205/70R15 will work. both the 175/55 and 185/55 will be to small of a tire for a stock bus. the 185/55 will work if you lowered the bus. _________________ Missouri Micros
mandraks Samba Member
Joined: November 28, 2004 Posts: 7117 Location: Lawrenceville, Ga
Posted: Fri Jun 12, 2020 5:16 pm Post subject: Re: In a pickle about tire size |
not sure what part bothers you? width or diameter?
i like how the 195/65/15s on 5.5s looked on my stock height 66.
They are not super wide.Stock would have been 7.00x14s which are huge in diameter, and they have a huge amount of rubber around the rim, pretty wide, too.
In reality your tires probably look just right. take some speedbumps without slowing down, report back. I bet you will like them better then. _________________ regards
Uli
sled Samba Member
Posted: Fri Jun 12, 2020 8:36 pm Post subject: Re: In a pickle about tire size |
josh32cb wrote: |
So, I have a 65 split, everything is stock height. I have 15" BRMs, bought 205/70/15 tires to have proper load ratings and safe driving abilities but they just look to damn big on there, especially with an aftermarket wheel. What would be an acceptable size tire to toss on there? I've read forum after forum about tire size and what not and I just cant seem to find an answer. Are 175/55s or 185/55s a reasonable option? Any help would be extremely appreciated. |
technically a 205/70r15 tire has a slightly smaller diameter than a 7.00-14 tire
so...they sounds like the perfectly acceptable tire to me. Do you understand that if you run a smaller tire your RPM's will increase proportionately?
as mentioned, 175/55 and 185/55 are too small for a stock height bus, it will look ridiculous. _________________ drive your split. |
ozark23 Samba Member
Posted: Thu Jun 10, 2021 6:06 pm Post subject: Re: In a pickle about tire size |
So Im with the original poster.....Just had a tire blow off the tread, looking for some new ones.
Stock 65 split bus,
The threads on tire are overwhelming....thinking about bigger tires/big meats, but not sure....so
will these work:
Posted: Fri Jun 11, 2021 5:58 am Post subject: Re: In a pickle about tire size |
aren't those the same size tires he already has?
to answer your question, yes they will work just fine. _________________ Missouri Micros |
Lind Samba Member
Joined: November 06, 2000 Posts: 10225 Location: idaho
Posted: Fri Jun 11, 2021 7:16 am Post subject: Re: In a pickle about tire size |
Have you considered stock rims? They look just fine with big tires, and they also look good with a curvy bus, unlike the angular BRM rims. _________________ .
Wanted:
BulliBill Samba Member
Joined: July 09, 2004 Posts: 4781 Location: St Charles, MO
Posted: Fri Jun 11, 2021 8:44 am Post subject: Re: In a pickle about tire size |
Be sure to buy a "C" or "D" rated tire, NOT the cheaper passenger car tire. Increase your odds of safety as well as those driving around you! You want to see "C" or "D" on the tire for load rating.
Bill _________________ I'm looking for these license plate frames for my fleet:
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help! |
RWK Samba Member
Posted: Fri Jun 11, 2021 1:22 pm Post subject: Re: In a pickle about tire size |
X2, no P 205.... _________________ 73 Type 181
63 Type 113
63 Type 261- 428 071
62 Type 241-378 025 178 530 |
