Thread search Help (Burley rear disc spacer)
detoxed
detoxed is offline
PostPosted: Sat Jun 20, 2020 6:37 am    Post subject: Thread search Help (Burley rear disc spacer) Reply with quote
I have searched and searched; there is a thread about the Burley rear brake kit addressing the possible need for a shim/ spacer to fill the gap on the hub and the rotor being supplied with the kit.
Any help with finding this thread link would be appreciated. Thanks
vwhammer
vwhammer is offline
PostPosted: Sat Jun 20, 2020 7:33 am    Post subject: Re: Thread search Help (Burley rear disc spacer) Reply with quote
While I can't help you find the original one you could do what I did and have some 3d printed.
Mine are only plastic and probably won't last very long but its enough to center the rotor until you get the wheel on and bolted down to hold every thing in place.
Have a few extras printed to keep onboard in case you need to remove the wheel at a later time and your spacer is trashed.
I did buy some material to make some aluminum pieces but my machine shop buddy has been out of the shop since march so the plastic parts are getting me by until then.
Pretty normal daily driver build
https://www.thesamba.com/vw/forum/viewtopic.php?t=708418&highlight=
4x4 build
https://www.expeditionportal.com/forum/threads/volkswagen-vanagon-4x4-conversion.162055/
View user's profile Send private message Yahoo Messenger Instagram Classifieds Feedback
nij_tp
nij_tp is offline
PostPosted: Mon Aug 03, 2020 10:01 am    Post subject: Re: Thread search Help (Burley rear disc spacer) Reply with quote
[quote="vwhammer"]While I can't help you find the original one you could do what I did and have some 3d printed.
Hi did you have the 3d files for use by the masses? Thanks in advance
1990 Vanagon GL _ Brunhilda (marked up as a Caravelle from new!) Just over 1/4 million miles, custom exhaust
1985 Vanagon GL - Josepha 140,000, Has a 2006 Forester 2.5 VVT custom exhaust
1989 Wolfsburg (Bluestar) - Walpurga
1989 Vanagon GL a parts bus
1984 Westralia
2006 Audi A4 2.0T with a unitronic tune
2007 Toyota Sequoia
1976 Mercury Capri 2.3l
1986 Honda Shadow VT700
2000 Suzuki Intruder VS800
1988 Kawasaki Voyager XII
2018 Chonda Hawk 250cc
1995 Subaru SVX (possible 3.3. swap)
ALIKA T3
ALIKA T3 is offline
PostPosted: Mon Aug 03, 2020 10:39 am    Post subject: Re: Thread search Help (Burley rear disc spacer) Reply with quote
That was a discussion on Facebook.
They`re not hub centered nor from the hub OD into the rotor`s hat.
vwhammer
vwhammer is offline
PostPosted: Mon Aug 03, 2020 10:49 am    Post subject: Re: Thread search Help (Burley rear disc spacer) Reply with quote
Well I just drew the part up in Onshape and a friend took it from there and printed it at home.
It's nothing fancy and could be drawn up by anyone that has some software in about 3 minutes.
I assume you have to sign up for Onshape to see this link but here is a link to the part if anyone want's to give it a shot.
https://cad.onshape.com/documents/d27c25251c333249...cd9c032f4e
4x4 build
pjn_wyo
pjn_wyo is offline
PostPosted: Mon Aug 03, 2020 11:17 am    Post subject: Re: Thread search Help (Burley rear disc spacer) Reply with quote
So they are centered off the studs and no spacer is needed?
vwhammer
vwhammer is offline
PostPosted: Mon Aug 03, 2020 11:26 am    Post subject: Re: Thread search Help (Burley rear disc spacer) Reply with quote
My rotor was definitely not centered without the spacer ring.
If one was better at measuring than I was and took the time to indicate the hub before machining you could get the OD of the hub just right so that it fits in the rotor hat perfectly and centers the rotor on the hub.
4x4 build
Franklinstower
Franklinstower is offline
PostPosted: Mon Aug 03, 2020 12:21 pm    Post subject: Re: Thread search Help (Burley rear disc spacer) Reply with quote
i believe they need to be 65mm x 68mm to center the rotor on the hub snout unless your hub od is machined to fit the hat of the rotor.
https://www.urotuning.com/products/apikol-rotor-ce...2697269303
These however are not tall enough, the chamfer on the rotor is too big for these to work. I have a set of those in the link for sale if anyone needs them.
Paul
'89 Westy - EJ25/22 Frank 4.44 5mt
'75 Miami Blue Sunroof FI Standard Bug
YITB
