aircooled body air intake rust
charleslabri
charleslabri is offline
PostPosted: Sat Jul 25, 2020 7:26 am    Post subject: aircooled body air intake rust Reply with quote
the stock method for dealing with rust below the air intake vents seems flawed: hope it doesnt rust down there, factory put a small bleeder hole.
anyone done anything back here to help with rust prevention? a shelf of some sort to divert water or something?
charleslabri
PostPosted: Sun Jul 26, 2020 7:41 am    Post subject: Re: aircooled body air intake rust Reply with quote
Bump.. am I blazing ground here?
jlrftype7
jlrftype7 is offline
PostPosted: Sun Jul 26, 2020 8:24 am    Post subject: Re: aircooled body air intake rust Reply with quote
Well, I don’t have any rust issues in that area , yet, on my ‘84.
I think the drainage plus air flow constantly drying, both intake in , and hot air rising after shut off of the engine keep it drier than one would think.
Strong paint layer, with a spray coating of body cavity wax on top of that once you’ve sanded the rust spots you currently have. Treat the spots with converter before priming and painting?
‘84 Tin Top - Hilga....Auto
MarkWard
MarkWard is offline
PostPosted: Sun Jul 26, 2020 8:38 am    Post subject: Re: aircooled body air intake rust Reply with quote
Buses had the same design. Luckily the battery got moved out of that spot with the vanagon. It used to really rust in the r/r corner.
danfromsyr
danfromsyr is offline
PostPosted: Sun Jul 26, 2020 11:28 am    Post subject: Re: aircooled body air intake rust Reply with quote
there is NOT ANY RUST in there in that picture... at least from my north eastern eyes that's near brand new in there... find something else to worry about it'll (possibly) outlive you.
charleslabri
PostPosted: Mon Jul 27, 2020 6:35 am    Post subject: Re: aircooled body air intake rust Reply with quote
all the rust is right at the drop point.. the vw engineers made the X pattern there where the pic is for water drainage.
rust is between the seam on the panel in the back of the channel
charleslabri
k- makes sense. Will do
T3 Pilot
T3 Pilot is offline
PostPosted: Mon Jul 27, 2020 6:51 am    Post subject: Re: aircooled body air intake rust Reply with quote
It is interesting to see that drain hole in the X. The later vans do not have a hole there from factory. On My Van with AC I did put a hole there to drain condensate.
1988 Vanagon
The most important part in every vehicle is the nut behind the wheel......
tencentlife
tencentlife is offline
PostPosted: Mon Jul 27, 2020 7:38 am    Post subject: Re: aircooled body air intake rust Reply with quote
You're probably right on the aircooleds, and for the left side on watercooleds, but the wbx's had a blocking panel on the right side that mostly closed it off. On those its common to see lots of debris and moisture accumulate there, especially the 2.1's which ducted engine air all the way thru. The 1.9's had an intake air horn that pulled from behind the blocking panel so at least the engine air flowed thru to help dry that area, but it became a mostly stagnant dead-end with the 2.1 wbx's.
Experience is death to doctrine.
jlrftype7
PostPosted: Mon Jul 27, 2020 10:12 am    Post subject: Re: aircooled body air intake rust Reply with quote
My blocking panel had rotted away by the time I got this Vanagon. But, the sheet metal was still pretty pristine, all things considered.
I didn't know VW deleted the drain hole, not sure if I have one[ I don't think I do], in that X stamping section. Maybe they were worried about paint not holding well to the sharp edges of the hole versus no hole at all, with water draining through all the time...... Confused Confused
