Coroded as21 case
Vw1600dellortoGR
Vw1600dellortoGR is offline
PostPosted: Mon Oct 19, 2020 6:11 pm    Post subject: Coroded as21 case Reply with quote
Hello everybody,
I have an AS21 case that had a small hole at the sump, when I ground the corrosion in turned into a bigger hole, I ground off all of the corrosion and used JB weld, will it hold, or should I through away the case?
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Mon Oct 19, 2020 6:21 pm    Post subject: Re: Coroded as21 case Reply with quote
Depends on your budget, what size engine you're building and where you're going.
If you're building a "floor sweeper" and staying local.. .sure drive it till it blows.
If you're building a performance engine and gonna drive it long distances... i'd get a new case.
Years ago I tightened the oil sender too much and cracked the case. I used JB Weld and it held for years until the case cracked at #3 behind the flywheel.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Danwvw
Danwvw is offline
PostPosted: Mon Oct 19, 2020 6:31 pm    Post subject: Re: Coroded as21 case Reply with quote
There are some epoxy products that are for machining and using on engine blocks. JB weld is a bit runny and I would want something that had wire mesh in it. Needs to withstand 300 degrees.
1960 Beetle And 1679cc DP W-100 & Dual Zeniths!
Chickensoup
Chickensoup is offline
PostPosted: Mon Oct 19, 2020 6:47 pm    Post subject: Re: Coroded as21 case Reply with quote
yeah, i know where your comming from buddy,
i too have a virgin as21 case. the water destroid the poor thing.
i have another case that has a crater of corrosion in the sump area. not all the way through, but close enough to make you worry. so i will be watching as well. i guess you just need something that wont start to disolve or degrade.
i would try to save it if you can. got a pic 4 us?
'65 Tourist Delivery Build
'66 RIP
Chickensoup
PostPosted: Mon Oct 19, 2020 6:55 pm    Post subject: Re: Coroded as21 case Reply with quote
look into this stuff
Belzona 1121
heres a thread of a guy using it round the sump blate holes,
https://www.thesamba.com/vw/forum/viewtopic.php?t=704548&start=501
'66 RIP
Chickensoup
PostPosted: Mon Oct 19, 2020 7:07 pm    Post subject: Re: Coroded as21 case Reply with quote
MURZI wrote:
We use a product called Belzona on these types of repairs at work. (Block repair on Caterpillar Diesel engines). Works fantastic. Your JB weld repair will work.... I rep'd that product for 8 years and saw all kinds of "everlasting repairs" and heard tons of testimonials.
https://www.thesamba.com/vw/forum/viewtopic.php?t=732751&highlight=case+corrosion
https://www.thesamba.com/vw/forum/viewtopic.php?t=...p;start=40
'66 RIP
nsracing
nsracing is offline
PostPosted: Tue Oct 20, 2020 8:15 pm    Post subject: Re: Coroded as21 case Reply with quote
you just cannot save them all. Very Happy
breaks your heart every time to see a case go die on you.
