MaggieMay Samba Member
Joined: December 27, 2015 Posts: 48 Location: La jolla CA
Posted: Sun Nov 29, 2020 5:12 pm Post subject: Is this doghouse fan correct? Gene berg fan does not fill shroud |
I recently installed this gene Berg fan in a doghouse shroud.
Clearance between the front backing plate and the fan is 2mm.
Fan measures 34.5 mm between the plates, and 37mm total.
As you can see the clearance in the rear between the fan and the shroud is 6 mm. From what I have been led to understand this tolerance should be much tighter. Is this the wrong fan?
Howard 111 Samba Member
Posted: Sun Nov 29, 2020 5:31 pm Post subject: Re: Is this doghouse fan correct? Gene berg fan does not fill shroud |
What was the GB # on the fan, and where did the shroud come from? _________________ 1973 Karmann Ghia
Turbocharged, Fuel Injected
http://www.thesamba.com/vw/forum/viewtopic.php?t=531270 |
grvwsic Samba Member
Joined: June 14, 2004 Posts: 113 Location: Coastal Cal
Posted: Sun Nov 29, 2020 7:36 pm Post subject: Re: Is this doghouse fan correct? Gene berg fan does not fill shroud |
The fan looks correct- it measures the same as the one in my spare box.
Are the spacer(s) install? |
evanfrucht Samba Member
Joined: July 24, 2016 Posts: 2186 Location: Laurel Canyon, CA
Posted: Sun Nov 29, 2020 7:43 pm Post subject: Re: Is this doghouse fan correct? Gene berg fan does not fill shroud |
Its probably because either the fan or shroud is aftermarket. Install a venturi ring on it, seal in place, and dont worry about it. Having a small gap similar to that is pretty normal. _________________ 1967 Bug ( the daily rod )
1964 Fury Wagon ( the pavement shredder ) |
croSSeduP Samba Member
Joined: June 13, 2004 Posts: 1150 Location: Western Washington State
Posted: Sun Nov 29, 2020 8:42 pm Post subject: Re: Is this doghouse fan correct? Gene berg fan does not fill shroud |
There's a factory spec on the spacing there in the Bentley manual. I believe it is achieved through the use of spacers. I agree, though, that if it is a OEM fan with an aftermarket fan shroud,...all kinds of fitment problems occur. _________________ Please check my '67 sedan project progress!
http://www.thesamba.com/vw/forum/viewtopic.php?t=502253&highlight= |
spencerfvee Samba Member
Posted: Mon Nov 30, 2020 5:35 am Post subject: Re: Is this doghouse fan correct? Gene berg fan does not fill shroud |
hi i run into this all the time . you can thank china for all ways making vw parts that dont fit. right you just have to deal with it .like the guy said put a power ring on the fan housing . good luck spencerfvee |
74 Thing Samba Member
Posted: Mon Nov 30, 2020 10:38 am Post subject: Re: Is this doghouse fan correct? Gene berg fan does not fill shroud |
You are supposed to use shims (the same shims used for your alternator pulley halves) to shim the fan forward to take up the gap. It is in the Bentley manual. |
mark tucker Samba Member
Joined: April 08, 2009 Posts: 23950 Location: SHALIMAR ,FLORIDA
Posted: Mon Nov 30, 2020 10:47 am Post subject: Re: Is this doghouse fan correct? Gene berg fan does not fill shroud |
shim it or make a new spacer or a better plate to attach the alt too.... |
kreemoweet Samba Member
Joined: March 13, 2008 Posts: 4090 Location: Seattle, WA
Posted: Mon Nov 30, 2020 10:48 am Post subject: Re: Is this doghouse fan correct? Gene berg fan does not fill shroud |
74 Thing wrote: |
Wrong. What's in the Bentley manual is how to shim the fan so the gap between it and the REAR cover plate is correct, which
the OP has said he did and is correct. There is no spec for the gap between the fan and FRONT opening in the fan shroud. _________________ '67 bug: seized by the authorities
Posted: Mon Nov 30, 2020 1:47 pm Post subject: Re: Is this doghouse fan correct? Gene berg fan does not fill shroud |
mark tucker wrote: |
..................................................................................................mark did you see how big that gap is . i wonder if he is using the right .year hard ware kit .to me it would take a lot of shims .and it would not be enough to close the gap what do you think mark?. |
Posted: Mon Nov 30, 2020 2:01 pm Post subject: Re: Is this doghouse fan correct? Gene berg fan does not fill shroud |
As stated, and reasserted later, the spec is for the fan to the alternator backing plate. The fan shroud is an original VW part. No amount of shimming will rectify this, only the fan being too short, which according to gene berg is a vw german fan. |
Ohio Tom Samba Member
Joined: February 09, 2006 Posts: 1662 Location: Marshallville Ohio
Posted: Mon Nov 30, 2020 2:15 pm Post subject: Re: Is this doghouse fan correct? Gene berg fan does not fill shroud |
Normal. |
Posted: Mon Nov 30, 2020 2:24 pm Post subject: Re: Is this doghouse fan correct? Gene berg fan does not fill shroud |
MaggieMay wrote: |
Ah, yes. I had it backwards. Derp. Man. Sorry; I need to read more carefully in the future.
Here's a stupid question: Are you sure that's a fan for a doghouse? As you're probably aware, the earlier fans were narrower. _________________ Please check my '67 sedan project progress!
Posted: Mon Nov 30, 2020 3:15 pm Post subject: Re: Is this doghouse fan correct? Gene berg fan does not fill shroud |
kreemoweet wrote: |
74 Thing wrote: |
the OP has said he did and is correct. There is no spec for the gap between the fan and FRONT opening in the fan shroud. |
My mistake. You are correct. The Bentley indicates shims so that there is spacing between the backing plate and the fan.
Typically if I am using all OEM parts it only takes 2-3 shims and the fan will rub on the shroud so I remove one and all is good.
For the OP you are measuring 6mm. Are you using all OEM parts? I have seem some really poor aftermarket fan mounting hubs. |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 52746 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Mon Nov 30, 2020 3:56 pm Post subject: Re: Is this doghouse fan correct? Gene berg fan does not fill shroud |
I wonder if there's a bus 38 amp fan hub in play?, I've never tried one with bug tin (probably just lock up the fan against the backing plate), but they do put the fan closer to the generator. Bus one on right below:
_________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
BFB Samba Member
Posted: Mon Nov 30, 2020 4:24 pm Post subject: Re: Is this doghouse fan correct? Gene berg fan does not fill shroud |
i just took an engine apart and someone had installed the alt / gen mounting plate on backwards, so the side with the raised edge was towards the shroud. i didnt look but youd think that would have to have offset the fan inwards like OP's.
OP, you sure thats not the case with yours? _________________ "how am i supposed to torque the rear wheel nut to 250 ft lbs??? " - clonebug
Most experts aren't. |
Posted: Thu Dec 03, 2020 8:32 am Post subject: Re: Is this doghouse fan correct? Gene berg fan does not fill shroud |
The backing plate is in correctly the hub is an OEM Volkswagen. All parts are German original. The fan is a gene berg fan advertised as a dog house I have included pictures and measurements of it.
I have ordered a venturi ring |
Posted: Thu Dec 03, 2020 11:13 am Post subject: Re: Is this doghouse fan correct? Gene berg fan does not fill shroud |
There are two types of fan hubs. One uses a thick washer and the other doesn't (it has the "thick washer" cast into the hub) They can get mixed up. So if you have the earlier style hub, and someone lost the washer at some point, its possible that might affect it _________________ 1967 Bug ( the daily rod )
Teeroy  Samba Member
Joined: April 20, 2003 Posts: 3840 Location: Eastern WA
Posted: Thu Dec 03, 2020 7:20 pm Post subject: Re: Is this doghouse fan correct? Gene berg fan does not fill shroud |
Cant be a hub problem, op said fan was spaced per spec from the backing plate _________________ Pres. Rivercity VW Club www.rcvwclub.org
Founder Derr Wheat Panzers (DWP)
ARR #3
www.autosportsnorthwest.org |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 79442 Location: Sneaking up behind you
Posted: Thu Dec 03, 2020 7:25 pm Post subject: Re: Is this doghouse fan correct? Gene berg fan does not fill shroud |
_________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
