Help reconnecting blue wire on alternator!
Hexie
Hexie is offline
PostPosted: Tue Jan 05, 2021 9:38 am    Post subject: Help reconnecting blue wire on alternator! Reply with quote
Hey all. After having a dead van the past few weeks, I finally discovered (thanks to this forum) that the blue wire running out of my alternator may be disconnected, which may be resulting in my resulting in a very dead battery.
It feels loose in the plastic connector (picture attached), but I can't really find a way to re-secure it or even open the connector. Any recommendations here? Or is it best to just yank the wires out and find some spade ends to re-attach them to the alternator?
Thanks for the help!
fxr
fxr is offline
PostPosted: Tue Jan 05, 2021 10:26 am    Post subject: Re: Help reconnecting blue wire on alternator! Reply with quote
Just looking at that connector - isn't there a tab each side where the wires come out? Just prise these gently apart and the connector body should hinge open, giving access to the terminals.
Jim Crowther
Vespa GTS 300
Hexie
Hexie is offline
PostPosted: Tue Jan 05, 2021 10:30 am    Post subject: Re: Help reconnecting blue wire on alternator! Reply with quote
That's what it seems like, but when I trued to pry them apart both snapped. It almost looks like the connector body is glued shut.
VicVan
VicVan is offline
PostPosted: Tue Jan 05, 2021 10:59 am    Post subject: Re: Help reconnecting blue wire on alternator! Reply with quote
If you want to keep the connector, and it is glued shut, you could cut it open at the seam using a small cutting whell (i.e. Dremel) or a saw with qa metal blade. You can reclose it using glue, or a zip tie and/or silicon
'90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH)
crazyvwvanman
crazyvwvanman is offline
PostPosted: Tue Jan 05, 2021 11:40 am    Post subject: Re: Help reconnecting blue wire on alternator! Reply with quote
If you are handy, replacing that connector is one way to go, all new parts.
Either a new pigtail with wires or new shell and pins.
https://www.ebay.com/itm/Lucas-Alternator-Repair-P...905481257?
https://www.ebay.com/itm/Bosch-Alternator-Harness-...815251184?
https://www.ebay.com/itm/Bosch-Lucas-Alternator-Ha...074546259?
Mark
Hexie
Hexie is offline
PostPosted: Wed Jan 06, 2021 8:08 am    Post subject: Re: Help reconnecting blue wire on alternator! Reply with quote
Worked with it a bit more yesterday and had no luck prying the connector apart. It seems to either be glued or molded shut, and I don't have much slack to pull it out of the engine bay to get a better shot at it for prying open.
Would you all recommend to just cut the wires off to get it out, then just buy a new one of these connectors? I assume its a pretty standard Bosch fitting. It looks like I can also attach the wires with spade fittings, but then the terminals would not be insulated. Not sure how important insulation is here, but it looks like later vans don't even have this plastic connector.
Hexie
Hexie is offline
PostPosted: Wed Jan 06, 2021 8:11 am    Post subject: Re: Help reconnecting blue wire on alternator! Reply with quote
Mark
Awesome, thanks! I see the pigtail one has a 14 AWG wire for the blue one, while the Bentley specifies it as 20. Would this still fit/be good to use?
crazyvwvanman
PostPosted: Wed Jan 06, 2021 9:18 am    Post subject: Re: Help reconnecting blue wire on alternator! Reply with quote
Yes, that is fine. In wire size the smaller wire has the bigger number.
So 14 is heavier wire than 20.
Mark
buspor63
buspor63 is offline
PostPosted: Wed Jan 06, 2021 8:55 pm    Post subject: Re: Help reconnecting blue wire on alternator! Reply with quote
Hexie,
That Westy in your pic looks familiar, did you get it from Bryan and Nicole?
Imagine that, theres not an "h" in either Westfalia or Syncro?
Hexie
Hexie is offline
PostPosted: Thu Jan 07, 2021 12:21 pm    Post subject: Re: Help reconnecting blue wire on alternator! Reply with quote
buspor63 wrote:
Hexie,
I did! Got it from them back in November. They are the coolest people and we still stay in contact. I see you're from Knoxville... I imagine Delilah was definitely hard to miss around town!
Hexie
Hexie is offline
PostPosted: Sun Jan 10, 2021 8:21 am    Post subject: Re: Help reconnecting blue wire on alternator! Reply with quote
Quick update that I could use some assistance on:
I purchased this connector that was recommended above, and am going to keep working today to get my old one off.
Could anyone give me some tips on how to seat the wires into these sort of connectors? I'm unfamiliar if you need a special crimping tool, etc.
Thanks!
DanHoug
DanHoug is offline
PostPosted: Sun Jan 10, 2021 8:50 am    Post subject: Re: Help reconnecting blue wire on alternator! Reply with quote
if you still have the bare, female, disconnect on the end of the wire it, inserts into the housing and there is a barb on the disconnect that latches into the housing when inserted far enough. it is common for the barbs to get folded flat so just bend it back so the tooth sticks up a tad.
-dan
www.thefixitworkshop.com
