'90 Sinka 5-speed gearing
oasis
oasis is offline
PostPosted: Mon Feb 01, 2021 7:43 pm    Post subject: '90 Sinka 5-speed gearing Reply with quote
I have been reading a lot in general while waiting to be able to give updates (answers, decisions, or follow-up questions) on other threads of mine. Some stuff I'm learning; some I'm relearning from when I had a Vanagon in the '90s; and some are outside my knowledge base. Whatever, I appreciate it all.
My problem with my single cab is the owner's manual is in Italian, and my Italian is a no so good a.
My 5-speed is set up where first gear is doglegged left-and-down, and the H-pattern is 2nd-thru-5th gears. It reminds me of a 914 pattern.
If memory serves me correctly, Syncros had that pattern, too, although it was a granny gear that was doglegged and one had a "normal" 1st-thru-4th as the H-pattern with normal meaning 1st-thru-4th is actually geared similarly or the same as my '85.
I only ever drove one Syncro once so correct me if I'm wrong. I never drove a 2wd Vanagon with a 5-speed but I always thought the H-pattern was 1st-thru-4th and 5th gear was doglegged right-and-up -- like all other VW 5-speeds I have owned.
The part that has me flummoxed is my 1st gear seems really low. I mean really low.
I can get moving somewhat okay from a standstill in 2nd if I'm on flat ground or slightly on a decline, but it doesn't feel like what I think I remember from my '85 in 1st.
So, to be safe, I always start from my 1st gear when at a dead stop.
Was my Italian Transporter geared differently? If so, how? And why?
Now: 2003 New Beetle Turbo S / 1990 Single Cab Transporter / 2014 Tiguan R-Line 4motion / 2013 Tiguan S / 2002 Golf GLS TDI
Past: 1974 Thing Acapulco / 2009 Eos Komfort / 1997 Jetta GT / 2002 Cabrio GLX / 2002 Passat GLS / 1971 Super Beetle / 1993 EuroVan MV Westfalia / 1981 Pickup LX / 1985 Vanagon / 1986 Jetta GLI
syncrodoka
syncrodoka is offline
PostPosted: Mon Feb 01, 2021 7:49 pm    Post subject: Re: '90 Sinka 5-speed gearing Reply with quote
The dogleg 1st gear to a standard H pattern is the correct pattern for a 2wd 5 speed.
They came with different gear ratios. If it is a diesel they are usually geared pretty low. There is a 3 letter code on the case that will help people figure out your gear ratios from the factory.
AndyBees
AndyBees is offline
PostPosted: Mon Feb 01, 2021 9:06 pm    Post subject: Re: '90 Sinka 5-speed gearing Reply with quote
'84 Vanagon Tin-top, ALH TDI, two trips to Alaska, 2014 & 16. 1989 Tin-top unmolested.
1983 Air-cool, 225k miles, 180k miles mine, seven trips to Alaska from 1986 thru 2003. 1975 Bay hopeful.
oasis
oasis is offline
PostPosted: Tue Feb 02, 2021 7:29 pm    Post subject: Re: '90 Sinka 5-speed gearing Reply with quote
Thank you, both. Always learning. When the weather gets a better and I am able, I will look for the three-letter code.
Based on the right-hand column of the chart, mine's not listed ... although all of the Euro diesels that are listed with 5-speeds are the same (except for the ring & pinion). Looking at the chart and assuming my '90 is the same as one of the Euro listings, that seems about right comparing to what I remember from my '85.
My side project will be to look up how the ring & pinion ratio works in conjunction with the gear ratios. Thanks again!
AndyBees
AndyBees is offline
PostPosted: Tue Feb 02, 2021 8:36 pm    Post subject: Re: '90 Sinka 5-speed gearing Reply with quote
?Waldo?
?Waldo? is offline
PostPosted: Tue Feb 02, 2021 8:49 pm    Post subject: Re: '90 Sinka 5-speed gearing Reply with quote
If your doka has a 1.6TD (or had one) then it will have the 4.8 R+P That is a little bit shorter 1st than the stock WBX trans, but not outrageously. Definitely not a granny gear and should be used on all starts from a stop. The 5th gear is similar or the same ratio as the 4th gear is on a stock WBX trans so the gearing is just tighter together. If you have an upgraded engine conversion, then an R+P change to 4.57 or 4.14 can make all the gears more useful. A 4.14 swap actually results in a 1st gear slightly taller than there is with the stock WBX trans.
hdenter
hdenter is offline
PostPosted: Wed Feb 03, 2021 7:41 am    Post subject: Re: '90 Sinka 5-speed gearing Reply with quote
If the OP's 1st gear is that low, I'm thinking he may have a variant closer to a DX with the 5.43 r/p.
Hans
'79 triple white convertible bug
'84 sunroof vanagon
'85 weekender
oasis
oasis is offline
PostPosted: Wed Feb 03, 2021 8:30 am    Post subject: Re: '90 Sinka 5-speed gearing Reply with quote
There is nothing about my '90 that tells me anyone did anything as far as modding it is concerned. The seller had only owned it for about a year, and most of that was taken up in importing it when COVID-19 hit. I have all of his receipts, and while a fair amount of work was done, it was all repairs and general maintenance. The only mod I can spot is someone had a rack built for the bed that left some cosmetic scarring behind.
My speedo doesn't work, but if I'm doing about 3-4 MPH, I feel the engine rev is telling me to shift. At an estimated 5-7 MPH in 1st, I feel like I'm really revving.
However, I always do start from 1st if at a standstill. The two or three times I tried from 2nd "worked," but it didn't seem natural at all--and those couple of experiments were on level ground.
My memory of my '85 1.9L gas model is more than 20 years old. Nevertheless, 1st now by comparison seems really low, and 2nd now feels like 1st-and-a-half by comparison.
It's probably normal. It was a work truck.
I'm totally new to this not counting what I can compare to my '85. My Sinka seems very happy in 3rd, 4th, and 5th ... and it is much happier on the Interstate than my '85 ever was with the 1.9L. I'm still getting used to the gearing and the H-pattern, but it's a blast.
Thanks for the answers and follow-ups.
?Waldo?
?Waldo? is offline
PostPosted: Wed Feb 03, 2021 8:42 am    Post subject: Re: '90 Sinka 5-speed gearing Reply with quote
More info would give a better picture, e.g. what engine and what trans code.
Changing the ratio of a single gear, changes that gear only. Changing the R+P ratio adjusts all of the gear ratios proportionately. If a taller R+P is used, then all the individual gears are proportionately taller.
That effect can be seen in the following two pics. The first is a graph showing the speeds at given RPMs using stock size tires and the stock DX transaxle with stock R+P:
This second pic shows the speeds at given RPMs using the DX transaxle with all gears stock except the R+P swapped to a 4.14. You can see that all of the speeds change proportionately in all gears for any given speed:
As can be seen in the graphs, even with the shortest 5-speed ratio, a speed of 5-7 MPH is below 2000 RPMs. That is LOW rpms for any 5-speed and a shift up to 2nd at that speed will lug the engine. Getting the speedo working or using a speedo from a GPS or smartphone would give a better picture.
What engine does it have?
oasis
oasis is offline
PostPosted: Wed Feb 03, 2021 8:56 am    Post subject: Re: '90 Sinka 5-speed gearing Reply with quote
Thanks ?Waldo?! Maybe I'm wrong about my speed... or revs, but I didn't even think I was doing 7-8 MPH at 2000-2500 RPMs. Then again, I thought I was dealing with Interstate traffic better than the 53 MPH @ 3000 RPMs would indicate. At any rate, I like the explanation and will look further into my specific situation.
oasis
oasis is offline
PostPosted: Wed Feb 03, 2021 8:59 am    Post subject: Re: '90 Sinka 5-speed gearing Reply with quote
Oops ... didn't see the paragraph below the charts.
It's a JX turbo diesel. I don't yet know any of the other particulars.
(I was amused by the 139 MPH at 6000 RPMs.)
hdenter
hdenter is offline
PostPosted: Wed Feb 03, 2021 9:09 am    Post subject: Re: '90 Sinka 5-speed gearing Reply with quote
Is there a 4.14 available for five-speed manuals?
Hans
'84 sunroof vanagon
'85 weekender
hdenter
hdenter is offline
PostPosted: Wed Feb 03, 2021 9:16 am    Post subject: Re: '90 Sinka 5-speed gearing Reply with quote
I have an ASS with a 4.83 out of a JX TD bolted to my stock 1.9 gas engine now in my work van. First gear is short, but not that bad. With a bit of feathering I can get it to pull out in second. It has made a world of difference in driving on hills and freeway on-ramps.
Hans
'84 sunroof vanagon
'85 weekender
?Waldo?
?Waldo? is offline
PostPosted: Wed Feb 03, 2021 6:07 pm    Post subject: Re: '90 Sinka 5-speed gearing Reply with quote
Hans
Yes, I installed one recently into a van with an mTDI AHU. The rest of the trans was stock DX gearing just like the charts above. It's a really nice end result, IMO. I got the R+P here: https://www.vwbulliparts.de/en/vw-t3-power-pack-29-7-2wd-5-speed-gearbox.html
Jake de Villiers
Jake de Villiers is offline
PostPosted: Thu Feb 04, 2021 9:38 am    Post subject: Re: '90 Sinka 5-speed gearing Reply with quote
What size are the tires on the vehicle?
'84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com
