Thoragaverung Samba Member
Joined: September 15, 2018 Posts: 81 Location: Saint Paul
Posted: Wed Mar 31, 2021 6:39 am Post subject: Symptoms of bad automatic transmission cooler? |
Hi,
I may be going to look at a 1985 vanagon with the auomatic transmision later this week.
I am aware of the pressing need to install a standalone transmission cooler before the integrated unit fails. What I'm wondering is, how can I check the bus to ensure it hasn't already failed? Would I see water on the AT dipstick (is there one?), or AT fluid in the radiator? What shuld I look for so I don't buy a problem?
Thanks. _________________ Happy to help, but my advice comes with no guarantees. Use at own risk. |
mikemtnbike Samba Member
Joined: March 26, 2015 Posts: 2930 Location: North Carolina
MarkWard Samba Member
Joined: February 09, 2005 Posts: 18695 Location: Retired South Florida
Posted: Wed Mar 31, 2021 7:29 am Post subject: Re: Symptoms of bad automatic transmission cooler? |
Depending on how it failed internally, you'd find strawberry milkshake in the main coolant tank or the ATF would be pink in color after it's run. If it's been sitting the water will separate out of the ATF and be in the bottom of the trans pan. Same is true but in reverse, the ATF will collect at the top of the main coolant tank.
In other words, you need the blender going to get the milkshake. |
Posted: Wed Mar 31, 2021 9:32 am Post subject: Re: Symptoms of bad automatic transmission cooler? |
MarkWard wrote: |
Thank you both.
Sounds pretty standard-- I'd be checking the fluids for weirdness in any event. Milkshakes are never good no matter where you find them. _________________ Happy to help, but my advice comes with no guarantees. Use at own risk. |
kourt Samba Member
Joined: August 13, 2013 Posts: 2309 Location: Austin, TX
Posted: Wed Mar 31, 2021 10:33 am Post subject: Re: Symptoms of bad automatic transmission cooler? |
Here's some actual ATF/coolant "strawberry milkshake" photos.
Report back and tell us what you find!
kourt
Posted: Wed Mar 31, 2021 2:14 pm Post subject: Re: Symptoms of bad automatic transmission cooler? |
That doesn't look like a strawberry milkshake. More like an infected wound... ugh _________________ Happy to help, but my advice comes with no guarantees. Use at own risk. |
SCM Samba Member
Joined: January 26, 2011 Posts: 3357 Location: Bozeman MT
Posted: Wed Mar 31, 2021 2:17 pm Post subject: Re: Symptoms of bad automatic transmission cooler? |
Thoragaverung wrote: |
Milkshakes are never good no matter where you find them. |
https://www.marksbeefburgers.com/
You're welcome. _________________ '91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine |
Abscate  Samba Member
Joined: October 05, 2014 Posts: 23777 Location: NYC/Upstate/ROW
Posted: Wed Mar 31, 2021 2:23 pm Post subject: Re: Symptoms of bad automatic transmission cooler? |
The fact that itβs installed is the problem
Iβm not a fan of ersatz engineering followed by bush league implementation, with apologies to those who know what they are doing _________________ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ π π π |
Posted: Wed Mar 31, 2021 4:00 pm Post subject: Re: Symptoms of bad automatic transmission cooler? |
You also need to check that the ATF and gear oil have not mixed, if one or the other is higher than it should be this might be the case. |
