Giorgio Udine Samba Member
Joined: April 20, 2014 Posts: 29 Location: Udine - Italia
Posted: Wed Apr 07, 2021 12:56 pm Post subject: Muffler split 1200cc |
the mufflers for vw split 1200cc (shape as original) are no longer reproduced ... how do you do, modify those of the beetle by plugging an outlet?
Grazie Giorgio |
mandraks Samba Member
Joined: November 28, 2004 Posts: 7117 Location: Lawrenceville, Ga
Posted: Thu Apr 08, 2021 4:32 am Post subject: Re: Muffler split 1200cc |
Thanks Mandraks!
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 26062 Location: Olympia Wash Rinse & Repeat
Posted: Thu Apr 08, 2021 4:45 pm Post subject: Re: Muffler split 1200cc |
1200cc 30 BPH or 34 BPH?? Both are not easily interchangeable. Requires cutting and welding. _________________ In Stereo, Where Available! |
Posted: Fri Apr 09, 2021 12:39 am Post subject: Re: Muffler split 1200cc |
Hi,
muffler for bus 1200cc August 62 with preheaters, engine I think 34 hp
Eric&Barb wrote: |
1200cc 30 BPH or 34 BPH?? Both are not easily interchangeable. Requires cutting and welding. |
Posted: Fri Apr 09, 2021 8:45 am Post subject: Re: Muffler split 1200cc |
Giorgio Udine wrote: |
Hi,
By "preheaters" guessing it is a fresh air heating system on your 34 BHP (40 HP SAE) engine. If so, not the stock engine which would be stale air heated till mid DEC62. Not that it really matters, just as long as it gets you down the road. _________________ In Stereo, Where Available! |
Posted: Fri Apr 09, 2021 8:59 am Post subject: Re: Muffler split 1200cc |
with August 62 it becomes version 63 therefore with preheaters system, the engine is correct version ...
Quote: |
By "preheaters" guessing it is a fresh air heating system on your 34 BHP (40 HP SAE) engine. If so, not the stock engine which would be stale air heated till mid DEC62. Not that it really matters, just as long as it gets you down the road. |
Posted: Fri Apr 09, 2021 9:33 am Post subject: Re: Muffler split 1200cc |
Except for VW did not ALWAYS make ALL changes at that point in the year. See entry in the upper right of the image below from the "Progressive Refinements" that was a VW dealer only manual on changes at the factory:
The exception to this was the bus only 1500 optional engine package that came right off in AUG62 with fresh air heating. _________________ In Stereo, Where Available! |
Posted: Fri Apr 09, 2021 9:41 am Post subject: Re: Muffler split 1200cc |
More of the "Progressive Refinements" manual and much much more good to know VW stuff here:
http://www.oacdp.org/ _________________ In Stereo, Where Available! |
PEPPE Samba Member
Joined: August 24, 2003 Posts: 1072 Location: Roma Italy
Posted: Thu Apr 15, 2021 11:20 am Post subject: Re: Muffler split 1200cc |
in europe sometimes they come out cheap as NOS, due to the very low requests for purchasing.
early 40hp (34ps for us) in addition of the muffler exit modification, requires also the adaptation of the lenght and diameter of the rear, #1 and #3 cylinders.
You wil need to fabricate a tube or weld a sleeve to the heat exchangers. Than slightly enlarge the hole in the lower cylinder control box. |
bobrk Samba Member
Joined: March 07, 2002 Posts: 290 Location: Beautiful Downtown San Jose
Posted: Thu Apr 15, 2021 12:58 pm Post subject: Re: Muffler split 1200cc |
Eric&Barb wrote: |
http://www.oacdp.org/ |
This site is awesome, it answered the question about the difference between the small nut 3/4 ton and small nut 1 ton brake drums and axles I had. 5 silly millimeters. _________________ 1959 Single Cab “Otto”
1500 single port | 1963 small nut/big brake transaxle | CSP Disc Brakes | dual circuit m/c | Deutsch Polster seats |
