how do you add a steering damper to a lowered/narrowed bus?
santacruz72
santacruz72 is offline
PostPosted: Fri May 07, 2021 1:08 pm    Post subject: how do you add a steering damper to a lowered/narrowed bus? Reply with quote
My beam doesn't have the bracket to mount too, nor does my steering arm.
View user's profile Send private message Send e-mail AIM Address Classifieds Feedback
sanhozeezee
sanhozeezee is offline
PostPosted: Fri May 07, 2021 1:30 pm    Post subject: Re: how do you add a steering damper to a lowered/narrowed bus? Reply with quote
my arm does have it but my beam didn't. in any event, you can take it to a muffler shop and have them fab a tab.
c21darrel
c21darrel is offline
PostPosted: Fri May 07, 2021 2:25 pm    Post subject: Re: how do you add a steering damper to a lowered/narrowed bus? Reply with quote
As an idea...I have one of these on my type 1
https://www.dansperformanceparts.com/aluminum-billet-steering-damper-mount.html
https://www.dansperformanceparts.com/latest-rage-750103-billet-steering-damper-mount-each.html
GhiaBuild
1967 DC build
panel
panel is offline
PostPosted: Fri May 07, 2021 4:41 pm    Post subject: Re: how do you add a steering damper to a lowered/narrowed bus? Reply with quote
I wonder if you can buy the swing lever steering arm with the hole already there? Expensive from CIP but maybe you can find a used one.
https://www2.cip1.com/ProductDetails.asp?ProductCode=VWC%2D211%2D415%2D741%2DD
My '65 Bus~Subaru EJ20 Megasquirted Turbo conversion
Krustybus
Krustybus is offline
PostPosted: Fri May 07, 2021 6:58 pm    Post subject: Re: how do you add a steering damper to a lowered/narrowed bus? Reply with quote
Late busses had the hole in the swing lever and a bracket on the beam.
Early busses had a clamp style bracket on the swing lever and a bracket welded to the inside of the left frame rail.
Pictures of both in this thread:
https://www.thesamba.com/vw/forum/viewtopic.php?t=254324&highlight=early+steering+damper
Tim
JonL Premium Member
JonL is offline
PostPosted: Sat May 08, 2021 6:10 pm    Post subject: Re: how do you add a steering damper to a lowered/narrowed bus? Reply with quote
I just installed one today on a CB beam that didn't have a provision/bracket as well. I bought an aluminum bracket similar to the one shown above that I found on IG (I don't remember the business, but I could find it) As a heads up, it was a little oversized even when completely tight to the beam, so I had to add a strip to make it fit tight. Very straight forward, once you put the one side on the idler arm, it will become clear what angle you will put the bolt on bracket on the beam so it's even/won't bind.
58 356a
57 Convertible
