harrymarlin Samba Member
Joined: June 07, 2018 Posts: 783 Location: Washington, DC
Posted: Thu May 13, 2021 3:59 pm Post subject: Emblem tab sealing? |
I've seen pictures of what looks like clear putty or wax over the emblem tabs under the bonnet/hood. What years would have had that, and what would it have looked like? _________________ -Harry
1967 Ruby Red Convertible Beetle ("Becky")
ISO Albuquerque "Imported Motors" dealership paraphernalia |
my59 Samba Member
Joined: August 13, 2003 Posts: 3966 Location: connecting the dots
Posted: Thu May 13, 2021 5:25 pm Post subject: Re: Emblem tab sealing? |
I heard the seals called witches hats. The replacement seals in my bug are some kind of squoze on putty _________________ my59: Well son, my grandfather died before I got to drive it, so does that answer your question?
Other:'12 Jetta, '77 Benz 300D, and a 74 MG Midget. |
Posted: Fri May 14, 2021 6:36 am Post subject: Re: Emblem tab sealing? |
my59 wrote: |
I heard the seals called witches hats. The replacement seals in my bug are some kind of squoze on putty |
Ah - so you are suggesting the putty is for replacement seals? _________________ -Harry
KTPhil  Samba Member
Joined: April 06, 2006 Posts: 35849 Location: Conejo Valley, CA
Posted: Fri May 14, 2021 9:00 am Post subject: Re: Emblem tab sealing? |
Does your emblem have pins or tabs? |
Posted: Fri May 14, 2021 9:16 am Post subject: Re: Emblem tab sealing? |
KTPhil wrote: |
Pins. Was the putty used for tabs?
Thanks! _________________ -Harry
KTPhil  Samba Member
Posted: Fri May 14, 2021 9:27 am Post subject: Re: Emblem tab sealing? |
The later models with pins used these, pressed into the hood first, followed by the emblem:
Earlier models used tabs, which I think were sealed with a putty similar to that used to seal the tab gaps on the back (front) of the dash.
But those with early models can confirm or correct. |
KTPhil  Samba Member
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 25882 Location: Olympia Wash Rinse & Repeat
Posted: Fri May 14, 2021 7:19 pm Post subject: Re: Emblem tab sealing? |
Seen some original 1950s beetles that used butyl rubber AKA Dum Dum sealant. That type of sealant comes in a lot of forms from somewhat liquid in a can, to caulking gun tube, to ribbon tape. The last is probably the best for your use if that is your situation. _________________ In Stereo, Where Available! |
