space Samba Member
Posted: Thu Jul 29, 2021 5:23 pm Post subject: Best "tap" for fog lights |
Installed some fog lights on an 82 westy
looking where to power them up
there is a 12awg wire (red) that looks like it might be the fuse block feed
Is this the case?
Would like to tap into it if so
TIA
T _________________ 82 westy
w:
2.5 JDM Subie
Rear discs |
Vanagon Nut Samba Member
Joined: February 08, 2008 Posts: 10497 Location: Sunshine Coast B.C.
Posted: Thu Jul 29, 2021 11:06 pm Post subject: Re: Best "tap" for fog lights |
Trace (follow) where that red #12 wire goes. It might be a supply wire from fuse panel to kitchen equipment.
Bentley diagram shows a #8 supply wire from battery to fuse panel.
If you carefully lower the fuse panel, at the forward side of it, you might find a spare open male connector that is B+ aka "always on". It might be ok to run a new fused supply wire from there. But...
Would the added fog light load increase the total potential amount of Amps going through that #8 supply wire from battery higher than what it's rated for? But, i doubt that's an issue. Especially if fog lights are LED type. (do they exist?).
On my '81, for the fog lights, I ran a new fused wire from the battery positive post to a relay in front of the glove box area. The fuse is in the battery box, which isn't ideal if it ever blows, but it's not too hard to get at. I installed a spare Vanagon defog switch at the blank spot in instrument cluster to control the relay.
(VW Gas I4)
1988 Westy DIY 50º ABA
VE7TBN |
jimf909 Samba Member
Posted: Thu Jul 29, 2021 11:13 pm Post subject: Re: Best "tap" for fog lights |
Vanagon Nut wrote: |
On my '81, for the fog lights, I ran a new fused wire from the battery positive post to a relay...
Neil. |
This is exactly what I have for fog lights and a Stebel Nautilus (loud) horn. I routed the wires out the vent that exits into the front wheel well. _________________ - Jim
Butcher wrote: |
This is the main fault with DIY'ers, they get together on these forums and pat themselves on their backs spreading bad information. |
Guilty as charged.
Red Ryder Samba Member
Joined: June 26, 2021 Posts: 1185 Location: PNW — Washington
Posted: Fri Jul 30, 2021 8:31 am Post subject: Re: Best "tap" for fog lights |
Yep. Just ran a pair (+ and -) 10 gauge wires from my battery terminals to a new fuse block installed behind the glovebox. Now I have 6 new potential circuits that are isolated from the factory fuse block. Perfect location to take power for fog or driving lights. I can insert proper amp fuses for each circuit as needed depending on the load. _________________ “Most everyone’s mad here. You may have noticed I am not quite all there myself.” — Cheshire Cat, Adventures of Alice in Wonderland
“Scarlett” — 1990 Vanagon Carat Wolfsburg Edition (Tornado Red)
“Nigel” — 1999 Jaguar XK8 convertible (Alpine Green Metallic) |
PDXWesty Samba Member
Joined: April 11, 2006 Posts: 6344 Location: Portland OR
Posted: Fri Jul 30, 2021 9:24 am Post subject: Re: Best "tap" for fog lights |
Your fog lights are 50-55w each? Adding those to an existing circuit would most likely overload it. Tap into one of the 12v terminals on the fuse block, or like others have mentioned, direct to the battery. In all cases you should use a relay to power the lights. _________________ 89 Westy 2.1 Auto |
space Samba Member
Posted: Sun Aug 01, 2021 3:19 pm Post subject: Re: Best "tap" for fog lights |
PDXWesty wrote: |
Your fog lights are 50-55w each? Adding those to an existing circuit would most likely overload it. Tap into one of the 12v terminals on the fuse block, or like others have mentioned, direct to the battery. In all cases you should use a relay to power the lights. |
Why a relay?
To lessen the load on the switch?
w:
2.5 JDM Subie
Rear discs |
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6930 Location: Fort Lauderdale, Fl.
Posted: Sun Aug 01, 2021 3:52 pm Post subject: Re: Best "tap" for fog lights |
space wrote: |
PDXWesty wrote: |
Why a relay?
To lessen the load on the switch? |
Exactly. Not only that, but you can run a smaller diameter wire to the switch where as a thicker wire might not fit because of everything being crowded under the dash.r _________________ This free advice is worth exactly what you paid for it.
Captain Pike Samba Member
Joined: December 30, 2003 Posts: 3437 Location: Talos IV, Piedmont Arizona
Posted: Sun Aug 01, 2021 3:59 pm Post subject: Re: Best "tap" for fog lights |
I never tap, Any new power supply is a new circuit. Fuse on the +. Established ground.
Your gonna fuck up and burn up another Vanagon.
Lights need AMPs.
Relay that shit. _________________ LEARN TO SELF RESCUE
....Bad Sneakers.... |
