Doghouse oil cooler VS vacuum leak
Bugeye54487
Bugeye54487 is offline
PostPosted: Thu Sep 16, 2021 6:53 pm    Post subject: Doghouse oil cooler VS vacuum leak Reply with quote
I have been chasing a rough start idle along with a warm start issues. Have not found any vacuum leaks yet. Is it possible to have a vacuum leak from oil cooler seals being bad? Pretty sure that it is leaking oil. Running 1600 single port, 30-pict 3, 205T distributor.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Thu Sep 16, 2021 7:03 pm    Post subject: Re: Doghouse oil cooler VS vacuum leak Reply with quote
You'd have oil leaking not air.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Bugeye54487
PostPosted: Fri Sep 17, 2021 7:24 pm    Post subject: Re: Doghouse oil cooler VS vacuum leak Reply with quote
I should have mentioned it is leaking oil. Sorry. I meant along with the oil leak, can u have a vacuum leak?
Busstom
Busstom is offline
PostPosted: Fri Sep 17, 2021 9:13 pm    Post subject: Re: Doghouse oil cooler VS vacuum leak Reply with quote
Yes, you can definitely have vacuum leaks and oil leaks at the same time.
But your rough running and warm start problems are not related to your leaking oil seals, and your oil leaks are not related to any potential vacuum leaks that you may discover.
Cusser
Cusser is online now
PostPosted: Sat Sep 18, 2021 6:59 am    Post subject: Re: Doghouse oil cooler VS vacuum leak Reply with quote
I'd address the oil leak first !
And if you really do have a doghouse oil cooler on a 1600cc single port, I'd triple check that you are using the correct type of oil seals between engine case and the doghouse adapter. Difference between a 1500cc "H" case and a later 1600cc "B" case or 1971-on case.
