pegscraper Samba Member
Joined: November 17, 2021 Posts: 2 Location: San Diego
Posted: Wed Nov 17, 2021 10:34 am Post subject: 010 trans pressure test |
Anyone have any info on main pressure, test. 010 transmission. I know what it should be. Not sure how to do it. Trying to test the pump before I remove the trans.
Thanks in advance  |
jlrftype7 Samba Member
Posted: Wed Nov 17, 2021 11:36 am Post subject: Re: 010 trans pressure test |
I don't have my Bentley in front of me since I'm at work, but I thought you needed to remove the test port plug that's on the Drivers Side, outer casing of the Trans, and hook up a Transmission Test Gauge/ hose to it.
Maybe someone can post the page from the manual if you don't have access to one. _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
‘84 Tin Top - Hilga....Auto |
kourt Samba Member
Joined: August 13, 2013 Posts: 2305 Location: Austin, TX
Posted: Wed Nov 17, 2021 1:18 pm Post subject: Re: 010 trans pressure test |
Greetings,
Nice first post.
The Vanagon has the VW 090 automatic. Since this is the Vanagon forum, I assume you are asking about the 090 automatic, and not the 010, which dates from 1972.
The pressure testing for the 090 is covered in Bentley 37.17-37.18.
What kind of problem are you trying to solve? It sounds like you believe the ATF pump may be underperforming.
kourt |
Posted: Wed Nov 17, 2021 3:52 pm Post subject: Re: 010 trans pressure test |
This has the 010. I think jlrftype7 has solved my problem. This one has the oil cooler connected to the test port. |
