Clutch Slave Cylinder Shafts - They're Different
shadetreemech
shadetreemech is offline
PostPosted: Fri Dec 17, 2021 1:31 pm    Post subject: Clutch Slave Cylinder Shafts - They're Different Reply with quote
Bought a Slave Cylinder for my '88 Westy a few months ago new from Bus Depot. Pulled the old leaky one out this morning. Comparing new to old, the shafts are different diameters and lengths.
The old shaft is on the left. The new shaft has no receiver for the actuator rod.
I tried to call Bus Depot: they're closed 'til after New Year's while they relocate.
Any input is appreciated.
Dan
'84 GL 1.9
'01 Volvo V70 T5
'88 Westy - "MZDRTHY"
CessnaJon
CessnaJon is offline
PostPosted: Sat Dec 18, 2021 11:50 am    Post subject: Re: Clutch Slave Cylinder Shafts - They're Different Reply with quote
Ran into this last week while replacing my clutch slave cylinder. I reused the old longer plunger. Seems to work fine.
1973 Westy (shared birthday)
1990 Westy Multivan
2015 Passat TDI 6sp
2015 Sportwagon TDI 6sp
LR-JET, Gulfstream 159
shadetreemech
PostPosted: Sat Dec 18, 2021 5:07 pm    Post subject: Re: Clutch Slave Cylinder Shafts - They're Different Reply with quote
(thumbs up)
'84 GL 1.9
'01 Volvo V70 T5
connorsvw2
connorsvw2 is offline
PostPosted: Sat Dec 18, 2021 6:24 pm    Post subject: Re: Clutch Slave Cylinder Shafts - They're Different Reply with quote
This might be to compensate for different slave piston diameters and therefore different travel distance. Ask me how I know...
'85 Westy Wolfsburg camper/2002 2.5 Subaru since 2003.
'85 GTI 1.8L 1-owner 8v-gave up on 9A 2.0L 16v transplant. Keeping her stock!
'99 Passat 1.8T Variant-AKA "The Money Pit". Still limping along...
'09 Subaru Outback XT 5-speed, 245 hp rocket (wife's car)
Rorke
Rorke is offline
PostPosted: Sun Dec 19, 2021 6:10 am    Post subject: Re: Clutch Slave Cylinder Shafts - They're Different Reply with quote
Jeff at AutoVentures fixed this for me.
He placed a spare small socket head on the rod before installing. This brought the length to stock. It worked.
Ultimately, I took it out and replaced with a different one from my parts collection.
Good luck.
ZsZ
ZsZ is offline
PostPosted: Sun Dec 19, 2021 6:50 am    Post subject: Re: Clutch Slave Cylinder Shafts - They're Different Reply with quote
The left is the FTE type one, the right is the ATE type one.
Aftermarket cylinders are usually copies of the ATE version.
Zoltan
1.9 MTdi 2wd Multivan (ex Caravelle)
Van since 2006, engine since 2008
patrickgreen
patrickgreen is offline
PostPosted: Sun Dec 19, 2021 7:54 am    Post subject: Re: Clutch Slave Cylinder Shafts - They're Different Reply with quote
Ironically I am swapping out my slave cylinder today on my 82 diesel Westy. What is the difference between FTE and ATE? Do they require different fluids? I seem to have some sort of leak with my slave cylinder every four years or so and was wondering if the fluid I am using is not compatible with the seals in the cylinder.
ZsZ
ZsZ is offline
PostPosted: Sun Dec 19, 2021 8:17 am    Post subject: Re: Clutch Slave Cylinder Shafts - They're Different Reply with quote
They are just different OEM manufacturers who designed different cylinders.
The working dimensions of the whole assemblies are identical.
One has a shorter piston and longer rod while the other vice versa.
It is OK to use either of them. Just be careful not to mismatch the components.
The rubber parts of the new aftermarket parts are crap they harden within a few years.
The aftermarket cylinders are identical - whichever brand you buy - to the point you can assume they are made in the same (chinese) factory.
Zoltan
patrickgreen
PostPosted: Sun Dec 19, 2021 10:29 am    Post subject: Re: Clutch Slave Cylinder Shafts - They're Different Reply with quote
Thank you for that useful information.
Taking the old cylinder off of course I broke the hydraulic line going right into the slave cylinder. Looking for replacements I see that there are after-market rubber ones for other vehicles. Are there any better solutions to the stock setup?
Not that that one is rocket science material. Would be happy with a stock replacement if I can source that. Back to internet searching.
ZsZ
ZsZ is offline
PostPosted: Sun Dec 19, 2021 12:30 pm    Post subject: Re: Clutch Slave Cylinder Shafts - They're Different Reply with quote
Early vans had a metal line with a rubber hose at the gearbox mount to allow some movement. Later it was changed to the plastic pipe. Probably to reduce costs (and the steel lines were rusting)
Probably a cunifer line and some off the self brake hose would be a good and cheap enough solution.
Zoltan
4Gears4Tires
4Gears4Tires is offline
PostPosted: Sun Dec 19, 2021 1:49 pm    Post subject: Re: Clutch Slave Cylinder Shafts - They're Different Reply with quote
Dan
This just happened to me too! What's going on over there?
shadetreemech
PostPosted: Sun Dec 19, 2021 3:58 pm    Post subject: Re: Clutch Slave Cylinder Shafts - They're Different Reply with quote
Twiddlin' my thumbs 'til next year.
Dan
'84 GL 1.9
'01 Volvo V70 T5
ALIKA T3
ALIKA T3 is offline
PostPosted: Sun Dec 19, 2021 8:24 pm    Post subject: Re: Clutch Slave Cylinder Shafts - They're Different Reply with quote
I had some clutch issues a few months ago in El Salvador stuck on a beach with my van. Pilot bushing for the input shaft was at fault ( a custom made part that turned out to be a downgrade Mad )
I was playing with slave cylinders.
Like mentioned above, original VW slaves made by FTE or ATE differ by pistons and rod pairing from the aftermarket.
I tried a longer rod to gain more travel, it doesn't matter, as you just compress the cylinder inside the slave while static, the travel remains the same, given by the master cylinder.
It is worth noting the arm on the bellhousing is clocked differently between gasser and diesel. I have a gasser arm on a diesel bellhousing, and indeed it doesn't change anything, you just work the slave more on the last part of the travel of the piston rather than the early part of the travel. Still works, at least for me ( single mass flywheel and clutch, and I later switched to dual mass flywheel and clutch).
It is worth noting the Topran brand slave cylinder is not threaded deep enough to accomodate the Syncro factory banjo, the seal washers don't get crushed enough and it pisses like a sieve. I had to cut the banjo bolt with a Dremel on the beach.... Rolling Eyes
Syncro banjo bolt in Topran clutch slave cylinder
Same in FTE slave cylinder
I annealed the crush washers and rubbed them on a file. I was going nuts bc it kept pissing fluid just sitting there! It took me a few times to understand...
Then I cut the bolt
FTE rod vs Topran rod. Don't mix parts and you'll be fine. In my case I tried mixing them, it was still fine Laughing
35 years old ATE factory rubber cap vs cheap chinese rubber cap from Topran
