jeffros 58 Samba Member
Joined: January 01, 2009 Posts: 369 Location: jackson mi
Posted: Sun Dec 26, 2021 6:51 pm Post subject: What transmission do I have |
Looking to see what transmission is in my truck . Works as it should just engine is running hi rpm at cruising speed . I am running a 1776cc engine. Would like to ether change ring and pinion or forth gear ratio to help with this .
FarmerBill  Samba Member
Joined: July 25, 2017 Posts: 893 Location: New England
Posted: Sun Dec 26, 2021 7:51 pm Post subject: Re: What transmission do I have |
If that first character in the sn is an H, it's probably a 64ish bus transaxle. Could be anything inside as far as gearing now though, a lot can happen in 57 years.
https://www.thesamba.com/vw/forum/viewtopic.php?p=5788948 |
Posted: Sun Dec 26, 2021 8:11 pm Post subject: Re: What transmission do I have |
Thanks I have been looking also after two hours I found a post in the performance engine and transmission forum . That’s what I found out also just ten mins ago . Do they offer a better forth gear for that transmission? Or would it be better to change the ring and pinion ?
Lind Samba Member
Joined: November 06, 2000 Posts: 10273 Location: idaho
Posted: Sun Dec 26, 2021 10:19 pm Post subject: Re: What transmission do I have |
Don't change your gearing unless you have a massive increase in power. It might look good on paper, but it will not perform well. _________________ .
Wanted:
74 Thing Samba Member
Posted: Mon Dec 27, 2021 10:11 am Post subject: Re: What transmission do I have |
| There are charts where you can put your car in each gear then turn the crankshaft one revolution and see how many revolutions your wheel turns to calculate each gear ratio. Do a search since these cars are old and more than likely the tranny has been gone throuhg and may not have the stock gear ratios. |
Clara  Samba Member
Posted: Mon Dec 27, 2021 10:44 am Post subject: Re: What transmission do I have |
| jeffros 58 wrote: |
| Looking to see what transmission is in my truck . Works as it should just engine is running hi rpm at cruising speed . |
What is "high rpm'?
What speed are you using as 'cruising speed'?
Do you know what VW had as cruising speed for a truck of yours year? and what rpm that was? (it's in the owners manual) Are you running higher rpm than that?
The gearing in that tranny might not be what it was when new, FWIW. What boxes does it have now? _________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
RWK Samba Member
Posted: Tue Dec 28, 2021 6:45 am Post subject: Re: What transmission do I have |
Also, engine needs to run at a "high" rpm to cool, If you are not use to an a.c. VW it will seem high. _________________ 73 Type 181
63 Type 113
63 Type 261- 428 071
62 Type 241-378 025 178 530 |
ToolBox Samba Member
Joined: January 27, 2004 Posts: 3447 Location: Detroit, where they don't jack parts off my ride in the parking lot of the 7-11
Posted: Wed Jan 05, 2022 10:03 am Post subject: Re: What transmission do I have |
| Clara wrote: |
| jeffros 58 wrote: |
What is "high rpm'?
The gearing in that tranny might not be what it was when new, FWIW. What boxes does it have now? |
Also, what size tire are you running? |
