tonyd0822 Samba Member
Posted: Tue Jan 11, 2022 12:20 am Post subject: type 1 transmission cover plate threads |
Hey guys. Hoping someone has some advice for me. I am fixing the transmission leaks on a type 1 and a few of the holes for the studs for the cover plates are really stripped. I tried to clean the threads up with a thread chaser and they seem to be beyond that. Would it be smart to tap them one size bigger so I can start fresh? Has anyone had this issue before and whats the best remedy? Looks like I can't use a helicoil because I won't be able to really torque them down enough. Thanks in advance for any help or guidance!
-Tony |
RWK Samba Member
Posted: Tue Jan 11, 2022 7:08 am Post subject: Re: type 1 transmission cover plate threads |
Helicoil or step studs will be ok, when drilling by hand note that the drill will make hole oversize more then normally, making threads not as tight as they should be.
I will sometime use a slightly smaller drill i.e for an M8 I use a .250 drill over a .265,when drilling by hand, Often I ream to size just because I have reamers, and its a one time fix, that has to be correct.
Biggest problem with helicoil is this, hole oversize, drilled crooked, tapping crooked. ect. VW used helicoils in several places in their engines. _________________ 73 Type 181
63 Type 113
63 Type 261- 428 071
62 Type 241-378 025 178 530 |
Chickensoup Samba Member
Joined: January 06, 2018 Posts: 5395 Location: Good Hope, GA
Posted: Tue Jan 11, 2022 7:14 am Post subject: Re: type 1 transmission cover plate threads |
do yall think there is enough meat between the casing and the diff housing to allow a 10mm to 8mm stud? _________________ -'85 c10 5.3 LS, cam, heads, long tubes, x pipe, 3 inch spin tech's
-'01 e46 325ci *tree modded
'65 Tourist Delivery Build
'66 RIP |
Cusser Samba Member
Joined: October 02, 2006 Posts: 33479 Location: Hot Arizona
Posted: Tue Jan 11, 2022 12:32 pm Post subject: Re: type 1 transmission cover plate threads |
| Chickensoup wrote: |
| do yall think there is enough meat between the casing and the diff housing to allow a 10mm to 8mm stud? |
If not, 3/8" SAE is about 9.5mm if you want to go that path. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
61SNRF Samba Member
Joined: March 29, 2009 Posts: 4658 Location: Whittier 90602
Cusser Samba Member
