jcgisel Samba Member
Posted: Wed Apr 20, 2022 7:03 am Post subject: Oval sun visor keeps falling down. How do you tighten it? |
I’m sure there is an easy fix, but I can’t seem to keep the sun visor from coming down on it’s own while driving. Thought of spraying hair spay or something tacky on the arm. Anyone have any ideas? |
salty54oval Samba Member
Posted: Thu Apr 21, 2022 8:08 pm Post subject: Re: Oval sun visor keeps falling down. How do you tighten it? |
I experience the same problem and would love to hear how to tighten it up. |
oldsplitvw Samba Member
Posted: Fri Apr 22, 2022 7:47 pm Post subject: Re: Oval sun visor keeps falling down. How do you tighten it? |
The visors slide onto the shaft of the mirror arm and are then secured with a punch. I've seen two kinds: a small circular punch (like a spot weld) or a small straight line.
Take the mirror assembly off the car and take it to your workbench, kitchen table, whatever. Grab your hammer and either a center punch or chisel depending on how the factory secured the visor. Give a few good whacks at the appropriate spot until the visor is firm on the shaft. Throw it back on the car and enjoy
Will |
Posted: Fri Apr 22, 2022 8:18 pm Post subject: Re: Oval sun visor keeps falling down. How do you tighten it? |
Thanks for the clear explanation Will! |
D. Haviland Samba Member
Joined: October 30, 2009 Posts: 536 Location: Burlington, Vermont
Posted: Wed Apr 27, 2022 12:43 pm Post subject: Re: Oval sun visor keeps falling down. How do you tighten it? |
oldsplitvw wrote: |
Will |
What he said. |
gzaharatos67 Samba Member
Posted: Fri May 02, 2025 8:14 pm Post subject: Re: Oval sun visor keeps falling down. How do you tighten it? |
I've done this to no avail and it the constantly dropping visro drives me insane. |
Dan22 Samba Member
Joined: August 30, 2019 Posts: 635 Location: Battle Ground, WA
Posted: Sat May 03, 2025 10:20 am Post subject: Re: Oval sun visor keeps falling down. How do you tighten it? |
Maybe slide the visor off the shaft, then slightly pinch the whole rounded portion in a vice to make it slightly oval. It needs tension to pinch onto the shaft. I am saying very slightly and not to mash it or kink it.
Then slip it back on and peen the dimple to hold it there. _________________ 1-0900722 die langsame grüne Schildkröte
https://www.thesamba.com/vw/forum/viewtopic.php?t=765074 |
Posted: Sat May 03, 2025 7:16 pm Post subject: Re: Oval sun visor keeps falling down. How do you tighten it? |
Appreciate it. I probably mashed it too hard last time I tried to get it to stay put. I made slide them off and glue them in place. With the visor down I can't see the top half of the windshield... I can't imagine ever lowering them. |
smitty24 Samba Member
Joined: April 28, 2008 Posts: 2730 Location: Salem, Oregon
Posted: Sun May 04, 2025 11:55 am Post subject: Re: Oval sun visor keeps falling down. How do you tighten it? |
I had the same issue with new WW visors with old OG mirror. I tried the punch thing. Was tight at first then after a few uses started all over again. Solution that I came up with:
Drilled out rivets and spread the metal slightly. Put a piece of heat sink tubing 1” or so and slightly heat it up. Reinstall assembly and carefully clamp it back together (I used pads in my bench vice and a wrench) then rivet in new rivets. Has worked great for 10+ months now. Still tight. |
