Windsurfa1 Samba Member
Joined: September 12, 2020 Posts: 6 Location: Honolulu, Hawaii
Posted: Mon May 02, 2022 9:10 pm Post subject: Brake lights 65 vw beetle |
My brake lights work fine during the day. When I drive at night , and turn on my headlights. My brake lights dont come on, though my headlights and running lights , signal lights all work!! 12v converted. |
GArBa Samba Member
Joined: January 27, 2014 Posts: 2127 Location: Milano, Italy
Posted: Tue May 03, 2022 8:09 am Post subject: Re: Brake lites 65 vw beetle |
easiest explanation: bulbs wired incorrectly or wrong bulb used in the socket so that the brake lights are fed back 12V from ground when the headlights are on. _________________ cars:
'97 type 1 1600i
'14 type AA Seat Mii (sadly dead after 270.000 km)
'22 type C1 T-Cross
'23 type AC3 Hyundai I10 (VW no longer makes small cars!)
moped:
'82 Benelli Magnum 3v |
ashman40 Samba Member
Joined: February 16, 2007 Posts: 16590 Location: North Florida, USA
Posted: Tue May 03, 2022 9:16 am Post subject: Re: Brake lites 65 vw beetle |
I believe in '65 the taillight assemblies grounded thru the fenders and then thru the fender bolts. This grounding connection is notorious for causing trouble as the connections start to corrode/rust. What is likely happening is your brake lights are grounding backward thru the parking light circuit. While the parking lights are OFF the different bulbs in the circuit provide multiple paths to ground. If your taillights have a bad ground the current will prefer the path thru the parking lights. When you turn on the parking lights the brake bulbs loose their path to ground and stop working.
TEST: Remove the taillight lens covers and with a jumper wire (a jumper wire with alligator clips will be easiest) ground the metal body of the light assembly to a known good ground point. Test your brake lights with and without the parking lights on. They should work as expected. This confirms your taillight housing ground is bad.
Fix is to run a dedicated ground wire. Affix one end to the metal body of the light assembly and run the wire into the engine compartment along with the three other wires. Ground the other end to the side of the engine compartment with a sheetmetal screw. If you don't like the idea of adding holes in the body of the car, run the wire to an existing ground point. Just make sure it is clean and provides a low resistance path to ground out of the elements. Coat the ground point in dielectric grease to protect it from corrosion. _________________ AshMan40
KTPhil  Samba Member
Joined: April 06, 2006 Posts: 35919 Location: Conejo Valley, CA
Posted: Tue May 03, 2022 10:36 am Post subject: Re: Brake lights 65 vw beetle |
Windsurfa1 wrote: |
When did this problem start? Any recent work? |
